WTF fuel problems
Old May 25, 2011 | 07:29 PM
mlopezformula's Avatar
Car: 1989 Firebird Formula
Engine: LB9 305 tpi
Axle/Gears: 3.43
WTF fuel problems
I dont know what the heck is happening!! but my charcoal canister is getting luquid fuel, too much! and causes the car to run real rich. I disconnected it so the car will actually run, cause it was stalling at every stop sign. I did notice that someone had cut the stock fuel lines that come from the fuel sending unit, and used rubber hoses to unite them. I think that getting a new fuel sending unit will solve the problem. Another issue that I have is that whenever I take hard turns I wont get any fuel, and most likely is that the fuel moving around prevents the fuel pump of sucking gas, and I dont think this should happen right? im not sure what is the problem exactly, need help im getting sick of having my car smelling like gas and looking at my passengers gasping for fresh air out the window haha. looking forward for your replies, and thank you for looking!!
Old May 27, 2011 | 12:48 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Are you sure the lines were cut? There is rubber coming off of the hard lines from the pickup.
A couple of the lines may be incorrectly connected, though.
Old May 28, 2011 | 12:16 PM
Engine: LB9 305 tpi
Axle/Gears: 3.43
Re: WTF fuel problems
yeah they are cut, and united with rubber hoses and clamps, I had thought of that but it looks like there connected right because how the lines are positioned, I still need a new fuel sending unit so I might as well get it cause the fuel gauge doesn't work and I have ran out of fuel lol!! thanks
Old May 29, 2011 | 06:26 PM
redCamaroblack's Avatar
Car: 1985 Camaro
Engine: 400sb
Transmission: 700r4 auto
Axle/Gears: posi trac, gears??
your lines are backwards. Its been a while since I had this problem, but i believe its the return and vapor lines that are backwards. I swapped those and it fixed my problem
Old May 31, 2011 | 01:36 PM
Engine: LB9 305 tpi
Axle/Gears: 3.43
ok thanks ill do that asap
Old Jun 1, 2011 | 12:48 AM
Engine: LB9 305 tpi
Axle/Gears: 3.43
can someone tell me wich line is supposed to do? Just know which is the fuel line for sure but I dont know if the vent line is mixed up also with the return line and evap line? please help thanks
Old Jun 1, 2011 | 02:18 AM
Car: 1985 Camaro
Engine: 400sb
If fuel is still showing up in the evap canister, then switch the 2 lines and if it works-which it should- then problem solved. If it hasnt solved the problem, then you ruled out 1 thing and narrowed it down substantially.
Old Jun 12, 2011 | 07:15 AM
devgro2's Avatar
fuel feed is 3/8" line ,return is 5/16" and vapor line is 1/4"
Old Jun 14, 2011 | 11:03 PM
Engine: LB9 305 tpi
Axle/Gears: 3.43
thanks alot I just did it and seems that its running a lil better ill have to check to what size the lines are connected to make sure
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
