85 T/A LQ4 swap
Old Apr 27, 2021 | 11:01 PM
Rileychris's Avatar
85 T/A LQ4 swap
New to the forum, not new to researching but can稚 find a define answer, So lq4 in to a third gen t/a I知 looking at going with the fbody front drive accessories if I can make it fit doing so however I知 confused as to what to order as far as a balancer, waterpump, and all the brackets... I知 sure the answer has been I. Front of my face this whole time and I知 over thinking it.
ls 1 balancer ?
ls3 waterpump?
what about power steering and alt relocate?
Old Apr 27, 2021 | 11:38 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Re: 85 T/A LQ4 swap
The accessory drive spacing is entirely up to you. If your LQ4 came with accessories you could get away with using those as they will fit. (when properly rearranged.) ls3 camaro water pump shares the same offset as truck. Fbody spacing will over a little bit more clearance as it is tighter to the block.
Truck offset with LS3 water pump, Truck ps pump and truck alternator. Factory style r4 compressor
Fbody offset with fbody water pump, ps, alt, Factory style r4 compressor
Old Apr 27, 2021 | 11:46 PM
Rileychris's Avatar
Re: 85 T/A LQ4 swap
So basically I just need brackets more or less I do have all the truck accessories, I misunderstood what people were saying about fitment it痴 really all about relocation. So i could put a ls3 waterpump on and get a bracket for the alt and p/s and utilize the rest of the truck parts if I知 understanding you correctly?
Old Apr 28, 2021 | 12:37 AM
Rileychris's Avatar
Re: 85 T/A LQ4 swap
Scratch that I hear ya loud and clear thank you for all the help!
Old May 3, 2021 | 05:13 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: 85 T/A LQ4 swap
Look up Dirty Dingo, LSSImple or ICT for the brackets. You can even get a highmount style alternator bracket to put the alternator and AC in the same factory locations they are on the TPI engines.
Old May 3, 2021 | 08:20 PM
Rileychris's Avatar
Re: 85 T/A LQ4 swap
I値l check the lssimple and ict thank you
jcrouse90
Oct 2, 2013 07:20 AM
Dave88LX
Mar 1, 2007 12:00 PM
Phatfiddler
Feb 27, 2007 06:24 PM
cootershooter
Mar 16, 2005 09:50 AM
xtreme_taz
Jul 22, 2004 08:52 PM
