Rearend swap
Rearend swap
i want to swap rear ends in my 3rd gen camaro.. but cant find a dang rearend with a 8.5 carrier. so i heard i can swap a 4th gen in there.. am i wrong? please help me.. thanks much.. oh and im trying to keep it simple as well.. i have roughly 2 months before i ship out for the military so i want to get it back on the road to spank some imports before then
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Rearend swap
And depending what year the diff is that's already in your car, the fourth gen diff isn't much stronger, if at all. If your car is a 1990 then the fourth gen diff is the same strength, just a little wider.
The only bolt in 8.5" available is the rare Dana 44. If you manage to find one in good condition, it will cost you about the same as an aftermarket bolt in 9", 12 bolt or Dana 60.
Re: Rearend swap
well im not so much looking for strength.. cause the one i have should be strong enough im not trying to go wild... just a little mild.. like i said i have 2 months before i leave.. sooo im just trying to do a little something.. but are those rears 8.5 carriers??? cause all the third gens i find have 7.5 and its driving me nuts. but i have stock wheels from a 4th gen with dot slicks on it.. if i swap the rears will those wheels and tires fit in my fenderwells??
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rearend swap
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Car: 87 IROC L98
Re: Rearend swap
Third and fourth gens did not come with an 8.5" diff. Standard issue is the 7.5" which was upgraded to 7.625 around 1986. A few cars from 1986 to 1989 got the BW 9 bolt which is slightly stronger and cars such as the SLP Firehawk got a Dana 44. The Dana 44 was also available over the counter from GM many years ago as an upgrade.
There are no other factory options for a diff.
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
Re: Rearend swap
fwiw I blew up my 9 bolt rear end on a bolt on 350 tpi.... I been through 2 rear ends and Im working on the current Zexel torsen ls1 rear now..... after this one goes its aftermarket for me....
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: Rearend swap
midwest chassis looks like the best bet.. All custom made and as light as stock, and about as strong as a 12 bolt (according to them).
Hello, Michael
Aug 20, 2015 03:19 PM
