LS1 cruise on 3rd gen swap
Old Aug 26, 2021 | 10:03 AM
rearview's Avatar
Car: 1990 LS6 Camaro
Engine: LS6 with a cam basically
Axle/Gears: 4th gen 3.42 rear
I have all the 4th gen parts with my LS1 that I could put into my 1990, but My LS1 has traction control. That's a no go, am I right?
However, I thought I'd read that a stand alone cruise module (no T/C) would integrate with my stock controls/cables. Would this part be what I need (see attached). Would this work? or not at all? Thanks.
Old Aug 26, 2021 | 05:33 PM
2knight's Avatar
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
Re: LS1 cruise on 3rd gen swap
You need one from a 98 fbody to be stand alone. The newer ones need to communicate with the bcm. I believe 99 and up silerados work too but the cable is short. I used a 98 fbody and the cable is long enough to be mounted underneath in front of drivers tire so its out of sight.
Old Aug 26, 2021 | 05:58 PM
rearview's Avatar
Thanks. Is it stand alone? Will I need to do any ECM programming for it or anything? (My ECM is from a 2000 Camaro with ASR).
Old Aug 26, 2021 | 08:22 PM
2knight's Avatar
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
98 fbody is the only year thats stand alone. If you do a search on here the diagram has been posted. Its super easy to do completely independent of the ecm. Just needs a vss input to function. I just took the ls ecm vss output and connected to both my speedometer and cruise and it worked fine.
Old Aug 26, 2021 | 09:29 PM
rearview's Avatar
Great info! Thanks a lot. I'll try to remember to report back in a few months when I've got everything put together.
Old Mar 14, 2023 | 11:38 AM
rearview's Avatar
n/m
the rookie24
Apr 12, 2011 01:55 AM
88_Import_Slaye
Jul 19, 2005 10:28 AM
realdealkvndeal
Jun 9, 2005 07:38 AM
KAOTIK415
Jul 8, 2004 01:43 AM
german-motorsport
Aug 12, 2003 09:54 PM
