gen 1 smc with ls1 firing order is it posible?
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: gen 1 smc with ls1 firing order is it posible?
Yep, its possible. Its called a 4/7 swap cam. I don't really see the point though.
Transmission: 4L80E/4L80E
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Proponents of the 4/7 swap claim a small gain in power (5-6HP from a 750HP NASCAR SBC) by correcting the imbalance in manifold harmonics and the inherent cooling problems caused by two adjacent cylinders firing in sequence. Others say that they notice no appreciable difference. While it may feel good to know you've solved an age old engineering flaw, you will never know the difference in a street driven vehicle.
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Car: 87 IROC Z28
Engine: 355 cid TPI
Yes. But it's still advantagious not to have two cylinders at the rear extremity firing in sequence. Ever notice on stock SBCs how #5 & #7 exhaust valves are always the first to go? At least that's how proponents of the swap see it. Another supposed advantage is improved crankshaft harmonics which is claimed to free up power. I don't see where it's worth the trouble, unless you're racing and want to find every last ounce of power.
ambainb
Apr 25, 2016 09:21 PM
