R4 serp belt ac install/parts help
Old Jun 17, 2022 | 03:10 PM
Camarothatcould's Avatar
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
Gearing up to start putting AC back in the car. I believe I'm going with the holley R4 mount and a later model R4 compressor. This leads me to believe I can re use all the factory hoses and such. I have an 87 car with full hvac.
What other items am I looking at needing to pick up that are specific to the use of a 98 PCM?
I'm. Assuming I have to wire up ac signal(from hvac unit) to the pcm? High/low psi switches, idle increase, and rpm cut out?
Does anyone have the specifics?
Thanks.
Old Jul 2, 2022 | 12:13 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: R4 serp belt ac install/parts help
The wiring has been covered several times here already. If you're running 134 then you can have the ECM run the compressor. I still run R12 and letting the ECM run the compressor seems to be a mistake.
The stock TPI AC setup fits right into the Holley bracket, you just need to rotate the compressor and tweak the hard lines a bit to clear the overflow. THe stock AC from a TPI is also "stand alone". I am going to switch my AC back to this setup
janson327
Jul 14, 2009 09:49 AM
ohiotemplar
Sep 21, 2007 11:43 PM
Peugeot205gti
Jan 12, 2007 11:54 AM
