Holley Terminator
Old Nov 28, 2022 | 10:32 PM
Project_redrkt's Avatar
Holley Terminator
So I'm in the process of installing a Holley terminator x into my 92 Z28 and have a few questions before I go and splice into any wiring. I have read multiple of the LS swap how-to's and think I have the basics down, just want to make sure I'm doing things right.
First, the Holley calls for a switched power source, which if I understand correctly, would be the pink wire out of the c100 connector (f4). However, the transmission harness calls for another 12v switched source and my question is, can I tap into the C207 for that switched power source? If so, where should I tap in? Also, any tips from anyone that has installed a Holley EFI would be greatly appreciated.
Old Nov 29, 2022 | 02:41 PM
vorteciroc's Avatar
Top Answer: 1
Re: Holley Terminator
You can use any switched power source.
When I build my Harnesses/ Bussed Electrical Centers (Fuse and Relay Panels)...
I take that 12 AWG Pink Wire and use it to trigger a bank of Relays that need to be triggered with Ignition ON.
Old Nov 29, 2022 | 06:21 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
This is what I did and it worked out really well.
thatsupnow
Sep 27, 2021 02:11 PM
cjpenny89
Aug 18, 2021 12:22 PM
305forever
Dec 30, 2009 03:03 PM
92rsv8
Jan 24, 2003 01:04 AM
