LS swap into a Berlinetta
Old Mar 13, 2023 | 03:02 PM
MrMercury's Avatar
Car: 1991 Camaro RS, Mazda MX-6
Engine: 305 TBI, swapping to a 355 TBI
Transmission: Stock
Axle/Gears: Stock
I looked around on here and couldn't find any pertinent information, my question is simple.
I have a Berlinetta camaro, digi cluster, control pods, rotating radio, the cool stuff.
but the stock carb 305 that's in their wheezes to 60 like my grandpa getting out of bed in the morning.
I figure the mechanical parts of an LS swap are just like how you would do it for every other 3rd gen, I'm going to go with a 5.3.
my actual question is for the Berlinetta specifically, will the swap wiring harnesses that are available work with the digital cluster? I figure it might not, and I'm not an electrician so having something plug and play is gonna be better for me.
Old Mar 13, 2023 | 06:11 PM
dixiebandit69's Avatar
Car: '89 Firebird Formula
Engine: TBI 305
Axle/Gears: 10-bolt, 3.42s, Torsen diff.
Re: LS swap into a Berlinetta
You will find that most of the guys on this board are not fans of the readily available "swap harnesses" on the market, instead opting to modify our own. There are some REALLY good threads about this in the stickies section.
As far as your gauges go, everything will work just fine, so long as you continue to use your existing sending units - which you have to integrate into the LS wiring harness.
Speedometer might be a different question, though.
But trust me, the answers are out there.
Old Mar 13, 2023 | 06:12 PM
vorteciroc's Avatar
Top Answer: 1
Those Berlinetta Camaros are very rare...
And the Value of Third Gens have been going up quite a lot.
I would consider not Modifying it, Selling it, and modifying another Third Gen.
Contact @John in RI , he is a Berlinetta Specialist... and get his opinion.
Old Mar 13, 2023 | 06:13 PM
vorteciroc's Avatar
Top Answer: 1
I will have some amazing Swap Harnesses available very soon!!!
Brisk
Sep 10, 2008 12:15 PM
bradley23150
Oct 11, 2007 02:14 PM
john1221
Fabrication
Jul 8, 2005 12:16 PM
chevySS
May 8, 2003 09:49 PM
firebird13
Apr 9, 2003 04:13 PM
