Thirdgen fuel sending unit to work with 4th gen gauges.
Old Jan 16, 2025 | 12:53 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
I am running a 4th gen cluster/gauges from 99-02 and 0411, still using the thirdgen fuel tank and sending unit. Question is can I modify the ohm values in Hp tuners so that my fuel level gauge will work. Was going to buy a fourth gen tank but if this can be done I'd rather do it this way.
Old Jan 17, 2025 | 10:07 AM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Re: Thirdgen fuel sending unit to work with 4th gen gauges.
I've never tried myself but I don't think that's how it works. The resistance is in the level sender itself. Buy a 4th gen tank and finish it properly
Old Jan 18, 2025 | 02:19 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
In the 2000 Camaro instrument cluster wiring diagram, the fuel gage goes to a "solid state logic" and it's not clear to me what happens from there. I assume it talks to an ECM somewhere? I did not find the fuel tank level sensor within the very limited amount of wiring diagrams I have.
Old Jan 18, 2025 | 04:02 PM
exiled350's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 427ci Gen 1 Small Block
Axle/Gears: Strange60 4.10 Eaton Truetrac
That cluster is late enough that it may be getting a lot of the info from the ECM via GMLAN vs direct resistance readings. I would expect the sending unit to provide a reading of 0-90 ohm, but again to the ECM not the cluster.
Old Jan 18, 2025 | 04:24 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Yeah the cluster gets all it's info from the ecm via the "serial data" pin blue 58.
"The gauge cluster interprets class 2 serial data for the following gauges and indicators:
- ABS Inop indicator
- Airbag indicator
- ASR Off indicator (TCS Off in Firebirds)
- Brake warning (only to indicate loss of serial data signal)
- Change Oil indicator
- Check Gauges indicator
- Coolant Temperature gauge
- Fuel gauge
- Low Oil indicator
- Low Traction indicator
- Skip Shift indicator (M6 only)
- Service Vehicle Soon indicator
- Tachometer
I did some reading on the subject but couldn't find a definitive answer, I'm going to buy a fuel gauge for now and keep an eye out for a fourth gen tank for now.
Old Jan 18, 2025 | 04:43 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
4th gen level sender is 40 - 250 Ohm
kill4thril
Mar 4, 2015 07:29 AM
mk2389
Mar 4, 2014 04:19 PM
BlueZee28
Jun 19, 2012 01:46 PM
whitedevilTA
Apr 13, 2010 01:16 AM
