Almost done, what do you think...? (pics)
Old Dec 11, 2006 | 02:04 PM
  #101
Demon355's Avatar
White Camaro's need the headlight pockets black...
Old Dec 13, 2006 | 04:44 PM
  #102
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
Satin black for the win! My . That car is dead sexy.
Attached Thumbnails Almost done, what do you think...? (pics)-resized_img_0393.jpg
Old Jul 2, 2007 | 04:43 PM
  #103
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Re: Almost done, what do you think...? (pics)
hey guys check out my burnout on you tube. it is also on the last page of my CD site
Old Jul 2, 2007 | 08:20 PM
  #104
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Very nice, whats with all the coughing tho. Burning rubber is better than air.
Old Jul 2, 2007 | 09:36 PM
  #105
Camaroguy18's Avatar
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
your car is the ****
Old Jul 3, 2007 | 04:51 AM
  #106
70gmc's Avatar
Car: 1970 GMC LWB Street strip
Engine: 383 stroker
Transmission: 350TH
Axle/Gears: 12 Bolt 4:11
Hey man great build. One question what are the "spacers" under the front strut mounts there for?
Old Jul 12, 2007 | 03:30 PM
  #107
Engine: LS3
Thats the way the caster/camber plates come from hotpart.com. They have since release a revised vertion that looks better, that I think I am going to get sometime down the road, Or maybe go with the spohn ones, but for now these ones work and don't deflect at all when on the street. If I ever get into racing I would def get the revised vertions right away.
By the way, thanks for checking out the vid.
Later,
-Dennis
Old Jul 17, 2007 | 09:08 AM
  #108
Engine: LS3
Happy to say the car has gone more than its first 1000 miles and nothing has gone wrong yet. haha. minor victory, haha.
Only real issue is the damn over axle pipe hangar keeps breaking, but I think I fixed it for good last weekend.
In case anyone wanted to know what I am doing to the car next.
-All new ignition system, with retard box and finally firing up that N20 on the dyno.
-C5 and LS1 brakes.
-New sticky sticky tires.
-Machining down the rear spacers, they don't need to be so wide.
-Headlight buckets painted black, and a wetsand.
-New proform carb for better tunning, and getting rid of the choke. (never used it)
-And of course a K&N air filter, haha.
Old Jul 17, 2007 | 09:52 AM
  #109
85_ZED28's Avatar
Car: '85 Z28
Nice work man
Old Jul 17, 2007 | 10:56 AM
  #110
ranone21's Avatar
Car: 1989 Trans Am t-top WS6
Engine: 305 tpi
Awesome car Man! Nice work!
Old Jul 17, 2007 | 12:07 PM
  #111
Engine: LS3
Thanks a lot guys! I am at work now, and she is a blast to drive on lunch breaks, haha. people at Wendies never looked so confused. haha. Anyways, thanks for all the compliments.
Later.
-Dennis
Old Jul 17, 2007 | 12:48 PM
  #112
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
Nice ride man! I too get that same look by pedestrians and such. These cars can definitely catch some eyes when thumping around.
Old Jul 17, 2007 | 12:55 PM
  #113
Engine: LS3
Hey I saw in your sig that you have Z06 brakes. Are they the C5 Z06 calipers? Whatever they are please fill me in as to how you like them, where you got them, any options you got and if you are happy with it.
New brakes is the first thing on the list for this summer for me. I am looking at a fully loaded package including powder coated splindles and all from bigbrakeupgrade.com. They quoted me $1166 for everything needed, coated, drilled/slotted and stuff. You think that sounds OK? Anything you think I should just skip on?
thanks for any advice.
Old Jul 17, 2007 | 09:06 PM
  #114
Car: 1991 Z28
Well I went about it slightly a different way. I had my car torn down so time wasnt an issue. I bought the stuff i needed to piece it together. Like the caliper carriers and calipers from gmpartsdirect, then the adapting brackets from a member on the board. I ended up using some wagner rotors and thermo quiet pads from Oreilly's. Thats pretty much it. cutting, drilling and tapping the spindles are easy. I ended up painting it with POR 15, still shiny a year later. For the brake lines Oreilys again. I just used 1LE brake lines and grinded alittle bit of the banjo fitting to get it to fit.
Its hard for me to get an exact figure because of the bits and pieces bought over time, but I know it was under $700. It brakes awesome. Drilled and slotted is a nice extra, I wasnt concerned about it at the time for my car as I had many other things to shell money out for. You could probably piece it together and get some premium rotors like Baer Eradispeed's for what it would cost you for the kit.
Old Jul 17, 2007 | 10:08 PM
  #115
Jap408Cracker's Avatar
Car: 87 IrocZ/87 Iroc Z28
Engine: L98 350 TPI/ LT1 350
Transmission: BW T5 5spd/ 700r4 A4
Axle/Gears: 10 bolt posi 4.10/10 bolt posi 3.73
the doors look silly, but whatever. looks good though
Old Jul 18, 2007 | 06:41 AM
  #116
Engine: LS3
The doors? What are you talking about? Why are they silly?
If you are not aware, and just looked at the pics on my site without reading the captions, there are no more lambo doors on her.
The doors are back to stock.
Chris Etemadi: thanks for the help. I POR-15'ed my entire car. It is really great stuff. You said you spent around $700, not bad at all. maybe I will look into that method. I am just kinda considering the kit, so I can get it all slap it on there and have plenty of summer left to play with it.
Thanks for the insight.
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
TexasFormula
Sep 30, 2015 06:36 PM
aaron7
Sep 30, 2015 09:15 AM
92projectcamaro
Sep 29, 2015 07:07 PM
