My engine bay (Start to finish) thread
Old 08-23-2010, 09:58 PM
  #251
On Probation
TPI TERR's Avatar
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
Re: My engine bay (Start to finish) thread
Originally Posted by FueledSoul
whats the purpose of this if any of you guys know
Old 10-28-2010, 11:56 AM
  #252
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
That's the inlet air peace. I had to take the diaphragm off it so i could fit fab up wiring board by it with out it interfering. I used a spring inplace of the diaphragm, im using this as a pressure relief when i shut the doors or hatch air now has a place to escape with out blowing out gaskets.
Old 10-28-2010, 01:13 PM
  #253
FueledSoul's Avatar
oh and i already had a explanation for this above thos pics you quoted.
but yea basically using this for a pressure relief now
Old 10-29-2010, 07:30 PM
  #254
92 CaMaRo Rs's Avatar
Man, Ive read both threads. Your car is amazing...its beautiful. Ill be reading this keep it up!
Old 11-16-2010, 01:58 PM
  #255
aqualordx93's Avatar
Car: 1986 Camaro Iroc Z
Engine: V8 305 TPI
Re: My Camaro (Start to finsh) thread
where did you get those camber plates from?
Old 11-16-2010, 11:15 PM
  #256
FueledSoul's Avatar
They were newer stock plates i sanded, primmered and painted. Your not the first to ask lol
Old 11-17-2010, 09:11 AM
  #257
Engine: V8 305 TPI
they look sweet, along with your engine. sick jobb
Old 04-14-2011, 12:23 AM
  #258
BBCpoweredZ28's Avatar
Wow. Amazing car. Now where's the new update lol
Old 04-15-2011, 11:34 PM
  #259
FueledSoul's Avatar
Thanks, Its pretty much done, just gotta fab up a hidden washer jug and over flow and do some final touch ups. I will post new pics sometime...
Old 07-15-2011, 06:08 PM
  #260
Marc Brown's Avatar
Sick, just sick!!! Man, that is awesome. I'm a biGG fan of the smoothin the engine bay out...here's mine...so yey, I feel your pain for that engine bay... Awesome work man.!!!! AWESOME!!!!!
AGain, AWESOME job, What's going on with the car now? I see you haven't posted in awhile. Just wondering , would love to see some more build shots and such.... Great job!!!
Marc
Old 07-19-2011, 01:11 AM
  #261
FueledSoul's Avatar
Thanks! Yours looks amazing as well! iv seen your thread, I was going to go just as crazy as you but i decided to keep it somewhat more factory looking. As far as what is going on with the car a lot has been going on i should really update some of the threads i have but anyways i fab up a coolant and washer jug and hid it in the front of the noise, i also built an exhaust system here are some threads on thos builds
https://www.thirdgen.org/forums/fabr...ow-washer.html
https://www.thirdgen.org/forums/exhaust/617402-my-exhaust-fab-long.html
Old 07-19-2011, 01:14 AM
  #262
FueledSoul's Avatar
Here are some super long awaited pics of the engine and bay! ENJOY!
Old 07-19-2011, 05:35 PM
  #263
one92rs's Avatar
Car: SOLD!!!!!
now that is beautiful man. is all the wiring in now? and did you relocate the battery? what else is left to install in the engine bay.
Old 07-19-2011, 06:53 PM
  #264
Mitch91Z28's Avatar
Car: 1991 Vert Z28
Engine: 305... LS1 waiting to drop in
Transmission: 700-R4... soon 4L60E
Axle/Gears: 3.08 posi nine bolt
Wow! very nice!!!!!
Old 07-20-2011, 12:17 AM
  #265
FueledSoul's Avatar
Thanks, all the wire is in but im not done yet there are a few odds and ends left, but the engine and tranny are all wired in and done but i need to see whats going on with the charging end of things since the car dies when you pull the battery cable it should stay running. The battery is in the back but haven't decided on its spot. Another engine will eventually go into the bay and i gotta fab up a newer stainless rad hose other then that at this point i feel its done.
  #266
FueledSoul's Avatar
Originally Posted by Mitch91Z28
Wow! very nice!!!!!
Old 07-20-2011, 08:17 AM
  #267
Marc Brown's Avatar
(not trying to sound like a S-@ss...but , if you pull the cable from the battery , it is most likely your alternator. I promise, I'm not trying to sound anyway, but if the cable is pulled and the car stops, then alternator is not working. I'm also going to put battery in trunk, probably a couple , I'm doing a Knight Rider car and need the extra juice for the dash and scanner on front, but for now, I'm going to just get the car running and engine in(which is where I want to be in the next month or so) . Anyway. Been going through the wire harness , looking at this thread and other ones for Pump relays and etc...What did you tie your fuel pump's Relay's 12v to on the ignition side? Just wondering as I'm going to try and wire this before I put it in. I'm putting the headlight and it's module up under the fender.....had to extend wires, but looks pretty cool, not having wires running up front. Anyway, If you could answer that, I'd be most appreciative. (if that's a word) Jjokin....humor is high today, so looook OUT! Jjokin , have a good one, and man, you need to take that engine bay to Nationals!
Marc
Old 07-20-2011, 09:09 AM
  #268
NxtLevl's Avatar
Car: 1992 Z/28
Engine: 5.7 TPI
That is sweet...! ....
Old 07-20-2011, 02:22 PM
  #269
FueledSoul's Avatar
Like i said i need to test the charging system, It doesn't necessarily mean its a bad alternator remember there is no stock wiring harness on this car everything has been personally rewired i might have missed something.
I was seeking help at one point in time with the alternator wiring. but i thought i got it figured out guess not or it is a bad alt... https://www.thirdgen.org/forums/elec...-confused.html
I used a new 12v 30 amp relay and have it wired to come on when the key is in the forward position "ignition hot" its very easy to do. If you have a lot of things that need to come on when the cars in the key forward position like me I.E Water pump, Fuel pump, Choke, MSD etc ... you can get a board that you connect one ignition hot wire and powers a whole strip.
Marc
Thanks for the complements
Old 07-20-2011, 02:23 PM
  #270
FueledSoul's Avatar
thanks
Old 03-21-2020, 08:42 PM
  #271
Tidan's Avatar
Curious how this build is holding up these days?
And what spark plugs did you use to clear the headers?
Old 05-30-2021, 10:45 PM
  #272
myers's Avatar
Car: 86 Trans am
Man I just read through this whole thread and I am so impressed. All the work you did was so neat and thought out there were no shortcuts. I had a quick question about running vacuum lines because I am currently doing the tpi to carb swap and was getting alittle confused on what line needed to go where. Also I see your breathers on the valve covers but did you do away with the pcv valve completely? Thanks in advance your a real legend.
zero13
Third Gen Expo
45
12-10-2017 11:41 PM
gt4373
09-03-2017 11:04 PM
Sonar_un
South Central Region
04-30-2006 12:13 PM
Sinister Z
05-31-2005 06:04 AM
Sinister Z
05-23-2005 10:44 PM
Quick Reply: My engine bay (Start to finish) thread
