Identify these rims
Old Jan 6, 2009 | 06:38 AM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Identify these rims
Guy wants 75 for whole set. They are corvette rims but do they have the same lug nut pattern as my third gen?
Old Jan 6, 2009 | 07:15 AM
trans_x1985's Avatar
Car: 1985 pontiac transam WS6
Transmission: t-5 5 speed manual
Re: Identify these rims
if they are corvette wheels, they will fit because i have seen a lot of camaros and trans ams running corvette wheels
Old Jan 6, 2009 | 07:30 AM
Doc_G's Avatar
Car: 87 Trans Am
Axle/Gears: Not enough
if you can get them for 75.00 w/decent tires its a fantastic deal, if they have no tires its still a good deal. Yes the bolt pattern is the same as on your third gen, however the backspacing is different. You will need spacers to run them just like 4th gen rims IIRC.
If I'm mistaken someone else please chime in.
Old Jan 6, 2009 | 10:11 AM
JTNKTZ's Avatar
Engine: 355/350
Alright sweet. He said that he will throw his spacers in for free. The spacers are off a 1996 Camaro though. Would those work? If not what kind of spacers should I get? It's an 89 Vert 350 T-5 Drum brakes and I don't know what gearing though (RPO tag is gone). Also would this mess up my speedometer? If it would how would I fix that as well?
Old Jan 6, 2009 | 10:38 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
As long as the wheel/tire combo height is the same as your OE, the speedo will read correctly. If not, there is always the option of swapping out the driven gear on the tranny.
JamesC
Old Jan 6, 2009 | 10:47 AM
JTNKTZ's Avatar
Engine: 355/350
JamesC
How can I determine what drive gear I am going to need?
Old Jan 6, 2009 | 10:56 AM
JamesC's Avatar
Check the following:
http://www.hanlonmotorsports.com/t5speedo.asp
JamesC
Old Jan 6, 2009 | 11:31 AM
jrhaus76's Avatar
Car: 1989 IROC-Z28
Engine: L98 - 350 TPI
Transmission: MD8 - 700R4
Axle/Gears: GH3/G80 - 2.77 POSI
OK...
#1 The wheels are off a 1997-1999 C5 Corvette (wagon wheels). Is the complete set the mix match like on the Corvette? 17 up front 18 in the rear?
#2 The spacer for the 1996 Camaro should NOT work because to run 4th gen (or Corvette) wheels on a 3rd gen you need a spacer. If this spacer is to be used on a 4th gen, then its wrong. Follow my logic?
#3 if the rear wheel is the 18", then you will have to have a mightly low profile tire to maintain the correct OE diameter.
It is a good price but I am not sure how they will look. Let us know...
Old Jan 6, 2009 | 02:47 PM
JTNKTZ's Avatar
Engine: 355/350
Originally Posted by jrhaus76
OK...
1. Yes 17 Front 18 Rear
2. The thing that the guy called a spacer are just like big washers. I can take a picture if needed. What would you suggest that I needed?
3. Why do I need to keep OEM diameter? Can I just change the speedo drive gear and be good?
Also the guy couldn't find the second spacer so I got him to bring the price down to $50. I just got back. They are in pretty good condition. One wheel has minor curb rash and minor paint chips as well.
Old Jan 6, 2009 | 03:03 PM
egott_91Z28's Avatar
Car: 1998 Camaro SS
Axle/Gears: 3.23's
Are the actual OEM Corvette wheels, or Replicas?!
And to make them fit you will need a 2 1/4" spacer. I had replica ZR1's on my '91 Z28 until I took them off to sell to my brother.
If they're OEM Corvette wheels that is a FANTASTIC deal!
Old Jan 6, 2009 | 03:06 PM
JTNKTZ's Avatar
Engine: 355/350
There are GM Symbols on it so I would think so.
http://cgi.ebay.com/ebaymotors/Wheel...1%7C240%3A1318
So thats what I need? And only for the rear I am guessing?
Old Jan 6, 2009 | 03:09 PM
Car: 1998 Camaro SS
Axle/Gears: 3.23's
Yeah, those are 2.25" spacers...but be careful buying from eBay...yes they're A LOT cheaper, but sometimes they don't fit. I bought a set from eBay last spring, and we had to hone out the centers to get them to fit, and we still had to draw them up w/ the lugs to fit on. Let's just say, that was a BEACH to get off! I had to chisel the stupid things off...it was a PITA!
Old Jan 6, 2009 | 03:13 PM
JTNKTZ's Avatar
Engine: 355/350
Hmm which would you suggest and what specific lug pattern do I need for the adapter on both sides.
Old Jan 6, 2009 | 03:16 PM
Car: 1998 Camaro SS
Axle/Gears: 3.23's
Skulte is a VERY good brand, but you'll be paying 5 times what you bought the wheels for! Haha! Hawks Third Gen has them for $260...but you could always try eBay...it's up to you man! I had spacers, and i said i would never buy them offa eBay again because of that experience.
Old Jan 6, 2009 | 03:19 PM
JTNKTZ's Avatar
Engine: 355/350
Well what I would do is if the adapter doesn't fit perfect I'll just return them and say they don't work.
What lug pattern to what lug pattern do I need? Do I need a set of 4 or 2?
Old Jan 6, 2009 | 03:55 PM
Doc_G's Avatar
Car: 87 Trans Am
yeah, good luck with that, GET THE RETURN POLICY IN WRITING.. have it stated in something you can use in the event of the spacers not being correct. Barring that, make sure you use a CC to make the purchase (via paypal if you don't want a third party to have the information) that way if there's any type of monkey business on the return issue you have better recourse in not being stuck out for your money.
260.00 isn't really a lot of money when you consider the fact that the parts are whats going between the wheels of the car and the car itself. Just for piece of mind, I'd bite the bullet and buy the good ones. Hell even at what your spending for the spacers if you add the price of wheels and tires, you STILL are getting one helluva deal.
Old Jan 6, 2009 | 03:57 PM
JTNKTZ's Avatar
Engine: 355/350
I only use my Credit Card cause Paypal is stupid.
Well right now I cannot afford that. I am dead broke lol.
Old Jan 12, 2009 | 07:54 AM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
Anybody have pictures of their car with these rims on?
Old Jan 12, 2009 | 10:08 AM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
The pattern you need is 5lug @ 4 3/4in spacing. You need all 4
Old Jan 12, 2009 | 03:01 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
im running ebay spacers no complains yet, no reason why they should fail if properly mounted and torqued right. i drive the car pretty hard with 305's tires in the rear and suspension upgrades so i know the spacers will hold up, 5k on them so far and i've noticed nothing, but then again who knows
Old Jan 12, 2009 | 04:09 PM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Yup.... Search my previous posts and you'll see the car in avitar. I'd link them here but I dont know how.
They are 275/40Z18 rear, 245/45Z17 front in the pictures.
Max,
Old Jan 12, 2009 | 04:10 PM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
Axle/Gears: 10 bolt auburn pro posi, 4.10 gears
I second that! I did a 1.69 60ft at the track with them, no problem
Old Jan 27, 2009 | 01:14 PM
ffemtm70's Avatar
Car: primered 1987 IROC-Z/28
Engine: 305 TPI HO
Axle/Gears: Lotsa slip 3.23
i am getting a set of those same rims for $350 but mine are chromed and are wrapped in goodyear f-1 runflats.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
kitt23
Exterior Parts for Sale
Nov 28, 2015 06:26 PM
dbrochard
Oct 10, 2015 01:03 PM
Linson
Sep 21, 2015 01:08 PM
