Pulling apart my 87 IROC
Old Nov 21, 2010 | 08:57 PM
  #401
propaintball96's Avatar
Re: Pulling apart my 87 IROC
love what you did with the vacuum pipe going to the BOV.
Didnt notice it before haha
Old Nov 21, 2010 | 09:25 PM
  #402
mightymaro94's Avatar
love seeing all those new HI-PO parts goin on... looks great man
Old Dec 4, 2010 | 01:32 PM
  #403
Twin_Turbo's Avatar
Decided to do both lines to the BOV in stainless
Mounted the water pump for the intercooler here, not much room elsewhere
I have a large front mount oil cooler left over from another car, I'm probably going to use that for cooling the water. It fits tight in the front above the air dam.
Decided to coat the STB aluminum so it blends better w/ the engine bay. Was supposed to be all aluminum color but the coater messed up and coated the mounts black...oh well
Old Dec 27, 2010 | 03:54 PM
  #404
Twin_Turbo's Avatar
finally got weld elbows in 3" 3mm wall aluminum so I can start on completing the ducting. Made a start today, it's darned tight. Had to remove the rad mount and will have to notch it to clear the pipe.
Old Dec 27, 2010 | 11:19 PM
  #405
3rdgenred's Avatar
Car: 6.7 Powerstroke
OP,
Discussing radiators, would you make that shroud you made for yours to sell to members on this board or no? Only saying this because that shroud is mighty nice.
Old Dec 28, 2010 | 01:48 PM
  #406
Twin_Turbo's Avatar
I have a cad file for it but my computer systems have been destroyed by water damage, this included my main station and my quadro system for solidworks. IF I can recover the file I'd be happy to share it. I live in the Netherlands so making them here is not cost effective because of the conversion rate & shipping.
I did finish that last pipe today I'll blast it for an even texture and maybe have it powdercoated, not sure yet
Old Dec 28, 2010 | 01:56 PM
  #407
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
i wanna see that thing run
Old Dec 28, 2010 | 02:02 PM
  #408
Twin_Turbo's Avatar
I have vids of it running without the SC hooked up.
I'm waiting on my 62 lbs injectors, stil have to wire up the maf and install an ostrich 2.0 and fiddle w/ the tune
Old Dec 28, 2010 | 02:47 PM
  #409
khulsebus's Avatar
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
i wanna see it run on a dyno with the sc hooked up.
Old Jan 17, 2011 | 06:30 PM
  #410
Twin_Turbo's Avatar
Originally Posted by 3rdgenred
OP,
Here's the radiator mount dxf file
Attachment 212596
Old Feb 19, 2011 | 06:08 PM
  #411
Twin_Turbo's Avatar
Finally got something done again, I swapped the injectors for Deka/Siemens 62s and I blasted the SC to intercooler pipe to mimic the cast look of the other components. It's a little lighter in color because the rest is a little dirty. Some WD40 is going to clean that right up.
I managed to F up one of the threads in the manifold whilst swapping the injectors. The thread was already questionable, someone must have tried the wrong fastener or didn't use anti seize. So, it turns out it's a thread I don't have in my timesert kit ugh have to order that now.
Also wired up the MAF using a 5 pin weatherpack connector, have to wire last 2 wires to IAT (internal in the film type maf), fans are also final wires so all wiring is complete. Tomorrow I'm going to install a big oil cooler that I'm going to use as a water cooler for the IC. IT fits snug in the front lower opening
Old Feb 19, 2011 | 07:21 PM
  #412
91ORANGEZ28's Avatar
Car: 1985 Z28/ IROC-Z
Engine: 5.0 TPI
Transmission: T-56 Magnum F
Your car is envied
Old Feb 19, 2011 | 08:11 PM
  #413
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
im hard
Old Feb 20, 2011 | 01:08 PM
  #414
Twin_Turbo's Avatar
Got the water cooler done today, I'm pretty sure this will be enough without having to hang coolers and crap in front of the rad. This thing is more than a fist thick
Old Feb 21, 2011 | 03:25 AM
  #415
Demon355's Avatar
Epic build dude. Props. Been reading this thread on and off all day.
Old Feb 21, 2011 | 11:11 AM
  #416
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Build looks like it's going GREAT! I was recently talking to a freind of mine that I hadn't seen in some time and he was telling me about how a buddy of his sold a red IROC to someone accross seas.....Said apparently the guy was doing some crazy build on it and he was almost positive it was in the Netherlands. Did you happen to buy this car out of CT??
Old Feb 21, 2011 | 11:34 AM
  #417
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
that would be quite coincidental if he did. although your friend would know its safe and in good hands now too
Old Feb 21, 2011 | 01:53 PM
  #418
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Correct me if I'm wrong, but isn't the car you bought from ct, a red 91 1LE with a procharged 383?
The buildup on this car started way before he bought the 1LE.
Old Feb 21, 2011 | 04:13 PM
  #419
Twin_Turbo's Avatar
nope, this one came from the UK, it's an original export car.
As for the 91 1LE, if it's ACs car, my buddy bought it, not me.
Old Feb 21, 2011 | 04:17 PM
  #420
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
hey twin i think you should post pics of all your cars, and the ones in your garage currently. just because i cant believe what your other work would look like. amazing job
Old Feb 21, 2011 | 05:44 PM
  #421
Car: 1986 Trans am
Engine: 5.3 LM7
Yep, it was AC's car. Thats funny. I guess it's a small world!
Old Feb 22, 2011 | 02:30 AM
  #422
Twin_Turbo's Avatar
Do you know him personally? I asked him a few questions in a PM but never got a reply. I figured all of it out by myself, except where the blinking led is for behind the passenger side kick panel. It flickers with the car running and there's a **** above it.
Old Feb 22, 2011 | 10:45 AM
  #423
Car: 1986 Trans am
Engine: 5.3 LM7
I don't know him personally but have spoken to him many times through the forum. My other freind I'm almost positive does know him personally though. I can always mention it to him. It wouldn't be some sort of boost retard **** maybe would it?
Old Feb 22, 2011 | 04:46 PM
  #424
Twin_Turbo's Avatar
no, I think it's a vats or other security kind of deal or it's a status light for the LC1
Old Feb 23, 2011 | 10:42 PM
  #425
mike_c's Avatar
Car: 1989 Trans Am GTA
Axle/Gears: 9 Bolt 3.70
Been following this since the beginning. Awesome build! Can't wait to see it all finished.
Old Mar 6, 2011 | 05:35 PM
  #426
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Damn nice build! Good Job!
Old Mar 13, 2011 | 11:43 AM
  #427
Twin_Turbo's Avatar
Finally got a Hobs switch. I'll have to do something about the plumbing, I hate it like this w/ the brass elbows. I'll have to find a 45 deg aluminum adapter and point the thing down to the throttle body so the eyesore is not as obvious.
almost done...
started on wiper fluid reservoir, I goofed and didn't account for the hood height when I designed it (oops) so my filler cap won't fit, I'll have to find a flush mount one so I left the top of the tank unfinished. Still, I'm pretty pleased w/ the result and how it tucks away.
Old Mar 13, 2011 | 01:33 PM
  #428
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
you could make a spout coming off from the back of the reservoir towards the firewall of the car, and add a filler cap there mounted flush with the height of the tank
Old Mar 13, 2011 | 04:49 PM
  #429
Twin_Turbo's Avatar
Yes but that's going to look like crap. I have 2 of these reservoirs, one for the 82 trans am also (well, the cut parts that is, still need to weld that one up) and I found a solution, I bought 2 of these
Old Mar 13, 2011 | 05:35 PM
  #430
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
yeah that is a much better idea than mine. i really like that cap, good find to the solution
Old Mar 26, 2011 | 02:08 PM
  #431
Twin_Turbo's Avatar
Man I lucked out!!!! The hood actually closes LOL. It's sooo close, it's not even funny. Especially where the BOV line is.
but the most important is... it's closed
I also installed the lines for the water intercooler. I ordered too short a length to complete it I need to order some more -12 line for the last stretch from the rear of the IC (highest point) to the pump. The rest is done, line visible on the right
Old Apr 11, 2011 | 05:42 AM
  #432
Twin_Turbo's Avatar
Woohoo, its all complete and running again , the intercooler is plumbed & filled w/ water. Pump is working (only have to hook up a relay to switch it on using the hobbs switch) All is running with the custom film type maf in an lt-1 elbow using a triple range extended custom prom w/ help from Greg @ Blowerworks.
I did reposition the hobbs switch to get rid of the brass elbow eyesore
plumbing the water side of the intercooler cost me more hose and adapters that I figured. Ended up needing a 90 deg npt adapter as well.
Now to fine tune this thing, fix the door hinge on the pass side and then it's off to the painters....well...if I don't find a set of S10 door handles that is, I never liked the originals
Pretty proud of how it turned out
Old Apr 11, 2011 | 01:58 PM
  #433
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
did you fix the overflow tanks and put those spouts in yet.it doesnt look like it?
Old Apr 11, 2011 | 03:02 PM
  #434
Twin_Turbo's Avatar
No, I got the caps and they are aluminum but the weld ring is stainless can't use them. 100$ worth of useless parts LOL
I'm going to buy some different ones w/ pop up caps, they do have an aluminum weld ring but as usual....it takes a lot of time for that stuff to get here.
Old Apr 11, 2011 | 04:16 PM
  #435
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
is it the same basic design as the previous ones, just different material?
Old Apr 11, 2011 | 04:20 PM
  #436
Twin_Turbo's Avatar
No, this style
The cap pops up
Old Apr 11, 2011 | 05:07 PM
  #437
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
i like the other better, but both serve the same purpose well, whats the approximate time of arrival on those?
Old Apr 11, 2011 | 05:59 PM
  #438
Twin_Turbo's Avatar
I liked the initial idea better too but they are not available with aluminum weld bungs so it's a no go.
It's probably going to take weeks and weeks. The brokerage dept of the mail service here is super slow (but super expensive too)
Old May 8, 2011 | 09:24 PM
  #439
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
how about a BUMP for any new info?
I so want to copy your Air to water cooler idea for my novi2000 setup.
Old May 9, 2011 | 03:31 AM
  #440
Twin_Turbo's Avatar
No real news, I'm messing with the tune to get it to run correctly. Right now it runs and revs fine in park but not in D. Lots more number crunching to do.
Old May 9, 2011 | 05:50 AM
  #441
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
what are you using for ecm? etc.. i prob. missed it if you already said.
Old May 9, 2011 | 09:24 AM
  #442
Twin_Turbo's Avatar
Stock ECM with triple range maf extended tables. All with help from Grag Carroll @ blowerworks. He's an awesome guy, helpful & friendly. I got the film type maf from him too as well as a bunch of other parts. If you need stuff, I'd recommend going through him. His parts are all top quality. Great attention to detail, especially in the wiring harnesses and the instructions are superb.
Old May 9, 2011 | 07:52 PM
  #443
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
I seen the MAF and setup you did for that. Along with the tune help from bw. With all the work your doing any reason you didnt swap to speed density and say $59 code or something like holley 950 commander , etc..
Old May 9, 2011 | 07:56 PM
  #444
Twin_Turbo's Avatar
My buddies 91 1LE has code 59 and it's not running perfect either, in fact it's running rich and I doubt it would meet emissions standards here, it certainly won't as it is.
The 91 GTA is running it's stock speed density ECM and is a bitch to tune partly because of the cam. I can honestly say that my maf setup should be a lot easier to get right, it certainly runs a lot cleaner with a rough tune compared to the SD setup.
For instance, before I swapped to 60lbs injectors I was running 32s with the intention to run a superfueler (I have 2 lying around), with the SC not hooked up it actually ran just fine w/ those 32s, stock tune & stock maf.
Old May 9, 2011 | 08:08 PM
  #445
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Interesting... I'll deff. be keeping an eye on how you do with the setup.
Ya I you bought one of those superfuelers with 55lb injectors from me.
Old May 9, 2011 | 08:10 PM
  #446
Twin_Turbo's Avatar
Oh yes, the TB plate. The rest of the system consists of a control box and an injector driver box. I should some day sell off some of that old stuff I'm not using LOL.
Old May 9, 2011 | 08:15 PM
  #447
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
that would be it. I know I asked before but prob. deleted the PM. but what a-w ic core is that?
Old May 9, 2011 | 08:21 PM
  #448
Twin_Turbo's Avatar
From wheel 2 wheel powertrain, no longer available. They were bought out, everything discontinued unfortunately.
Old May 13, 2011 | 01:47 PM
  #449
TrueIroc's Avatar
Car: 1989 IROC-Z 100% Original
Engine: 5.0 TPI
Axle/Gears: 3.08
I'm thinking about getting a 9 bolt posi disc with 3.45 gears.
Why is the posi setup design junk??
Was surprised to find that these 9 bolts are glyptal coated from the factory....something nice for a change because the posi setup is a junk design. Pulling the pinion tomorrow and then it's going to be blasted and powdercoated like everything else.
Old May 14, 2011 | 03:26 PM
  #450
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
its a cone type posi that wears the case/carrier. once the case/carrier is worn out, you really cant rebuild it. and parts are really hard to find.
