1991 Ultra Bright Blue Camaro Pics
Car: BMW 330i ///M Sport
Engine: M54 DOHC I6
Transmission: 5 speed
Axle/Gears: Stock
Paint code 23 WA 9537...
I can't seem to find many pics of these color Camaro's
beautiful color, too bad there are were so little made!
Two nicer ones, and a Cash for Clunker
beautiful color, too bad there are were so little made!Two nicer ones, and a Cash for Clunker
Car: 89 RS Camaro
Engine: 350 ci
Axle/Gears: 3:42
Re: 1991 Ultra Bright Blue Camaro Pics
I have a problem right now matching the paint
My car RPO is 23U (PRIMARY COLOUR MEDIUM MAUI BLUE MET (91) )
like the 3rd picture of the car of the front end
any one can help me with the colour code from PPG?
thanks
thanks
The third car is mine, thanks for the props
I'm not by my car so I can't verify the paint code on the RPO, but I do believe it is 1990 Code 23 Maui Blue Metallic, just like Manovox's car.
You have to be careful though--Maui Blue, at least in 1990, AFAIK, was the name given to this blue when worn on Firebirds, but on Camaros, the same paint code was given a different name--either Bright Blue or Light Blue IIRC. Where you have to be careful is that in earlier years Camaros came in a color called Bright Blue, but it was much darker and not the same color. I always refer to mine as Maui Blue though, FTR.
Also, the picture on the beach is not the same color, it's much darker than what we have.
Love love love my Maui Blue, wouldn't trade it for anything, and indeed a very uncommon color. Could never get it on an IROC.
EDIT: Just found this, probably makes it more confusing since it lists 23U as one version of Medium Maui Blue Metallic, and 9537 as another. Probably identical, but yeah. http://www.uniquecarsandparts.com.au...rs_usa_M-Z.htm
Car: 89 RS Camaro
Engine: 350 ci
Axle/Gears: 3:42
Here is what also solved my problem!!!
PPG formula
4129 : PRIME : GLOBAL BC MET : 4129;16650 : 1988-1991 : Trim : MED MAUI BLUE : WA9537 : GM (N AMERICA) : MMF
Brand Reference: 4129
Finish Effect: Metallic
Use undercoat G3 for maximum hiding
Main Layer:4129
Price Code:A
MSDS Number:BC1
Revision Date:1/18/2006
Code
Description
Gms/Qt
D772
CRS. ALUM.
D770
FINE ALUM.
D754
BLUE
D759
MATT BASE
D981
INTENSE VIOLET
D753
WHITE
D740
BLACK
HAPS Content (lb/gal): 0.53
Density (g/L)
Density(lbs / gal)
Volatiles wt. %
Water wt. %
Exempt wt. %
Water vol. %
Exempt vol. %
949
7.92
76.2
0.0
0.0
0.0
0.0
PPG formula
Main Layer:4129
Price Code:A
MSDS Number:BC1
Code
Description
Gms/Qt
D772
CRS. ALUM.
410.90
410.90
FINE ALUM.
248.30
659.20
BLUE
194.20
853.40
MATT BASE
18.10
871.50
INTENSE VIOLET
12.20
883.70
WHITE
7.20
890.90
BLACK
7.20
898.10
Density (g/L)
Density(lbs / gal)
Volatiles wt. %
Water wt. %
Exempt wt. %
Water vol. %
Exempt vol. %
949
7.92
76.2
0.0
0.0
0.0
0.0
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Linson
Aug 21, 2015 02:12 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
