Best headers...
Old Nov 16, 2010 | 08:48 PM
chrkevjac09's Avatar
Car: 1989 Rs
Engine: 5.0 TBI
Axle/Gears: Stock
Best headers...
I have the exhaust manifolds and the complete smog system taken off of my 88 iroc and i need help finding out witch pair of long tube headers will fit in with out me having to lift the motor. I already have the small starter and I know that I will have to install them from underneath the car but i dont want to order them and have the wrong pair can anyone please help?
Old Nov 24, 2010 | 07:41 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Re: Best headers...
I don't know of any headers, long or short, that you can install without moving the motor around. Not enough clearance.
Old Nov 24, 2010 | 09:03 PM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Re: Best headers...
You dont need to move the motor around for any headers that I know off. So who ever told you that is mistaken.
I have a pair of Hedman 68460s that were pretty easy to install, all they need is a small notch on either the K-member or the header itself on the driver side and they fit perfectly. I had to remove my starter on the pass side and Oil pressure sensor on the driver and Spark plugs on both sides. Both came in from the bottom.
I am sure you know that longtubes will need alot of work and thinking to get the best clearance for them. Even more if you run true duals. Making them into a single exhaust would require fabbing up a custom Y pipe as well. If you are still set on it, look into the Hedmans. Love em even gonna install them on my buddies 89 T/A.
Also you might get more responses in the exhaust section, check out the stickies there as well. I spent a full day looking at the duals sticky thinking of ways to route my exhaust.
Old Nov 24, 2010 | 09:28 PM
Car: 1989 Rs
Engine: 5.0 TBI
Axle/Gears: Stock
Re: Best headers...
thanks man I always have a hard time finding out how to post things on here but ill try posting things in different sections you've been lots of help thanks
Old Nov 24, 2010 | 09:31 PM
Car: 1989 Rs
Engine: 5.0 TBI
Axle/Gears: Stock
Re: Best headers...
And what do you mean by a small notch?
Old Nov 24, 2010 | 09:51 PM
Carlos773's Avatar
Re: Best headers...
Mine needed and according to others it confirms it, but they needed a small notch on the k-member on the driver side. My 68460's were used so they had the small dent on them already and fit like a glove. The notch is on the first cyl tube if I recall.
If I were to get new ones. I would just notch the k-member instead. Either way I am going Tubular K-member soon.
http://www.jegs.com/i/Hedman/500/68460/10002/-1
Those are the 68460's. Good price on them too, you can even find used ones for around $100 or less on here. Mine had a coating of rust of course like every header gets. I coated them with VHT High temp paint but it got chipped really bad from the install but then again now I can install and uninstall them in seconds after they are unbolted. Just make sure you lift the front end enough to get enough clearance.
Also if you buy them used, get the ball & socket version which is the newer style. Mine are flanged due to being the older style. Its just nice feature to not need gaskets.
Old Nov 25, 2010 | 12:46 AM
Car: 1989 Rs
Engine: 5.0 TBI
Axle/Gears: Stock
Re: Best headers...
kool man thanks for the help
Old Nov 25, 2010 | 12:56 AM
Carlos773's Avatar
Re: Best headers...
No problem also very beautiful 3rd gen you have there.
Old Nov 25, 2010 | 08:58 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Best headers...
Have a look at Dyno Don headers sold on the TDS website.
pyrofire127
Mar 20, 2008 09:42 PM
Brisk
Jul 19, 2004 12:26 AM
TwinTurboROC
Jun 25, 2003 08:14 AM
KlayBuRn
Dec 30, 2002 01:15 AM
aziroc
Aug 16, 2001 11:36 PM
