painting help
Old Apr 17, 2011 | 06:36 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
painting help
hello all, saterday i am replacing my engine with an engine out of a 93 s10 and im going to paint the block before i put it in, im doing what some call a "mexican" engine job. im pulling the engine, fixing a few things, then painting and dropping it in. so im not tearing the engine down at all so i need advice on how to paint the engine. im painting it chevy red-orange engine paint from autozone, rated at 600 degress so any tips?
Old Apr 17, 2011 | 09:15 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: painting help
Get a wire brush or two, maybe even one to go on a drill to get the heavy sediment/old paint off. Mask off everything that shouldnt be painted (IE: Spark plug threads, etc..). Also grab a bottle of Acetone and some rags to wipe the block down with prior to painting it.
Old Apr 18, 2011 | 06:25 PM
Engine: L31 350
Re: painting help
hows purple power? im looking at getting a can of auto zone heavy duty cleaner, will i need 1 or 2 cans?
Old Apr 18, 2011 | 07:21 PM
Re: painting help
Purple power is an excellent degreaser, it is what I use on everything. Just be careful not to get it into places you wouldnt want it, like in your alternator, sensors, etc..
Old Apr 18, 2011 | 07:56 PM
Engine: L31 350
Re: painting help
blocks gonna be pretty much just a block. all the sensors, accs, and oil pan are gonna be off so yeah
Old Apr 18, 2011 | 08:01 PM
Re: painting help
Yup, just covering all bases.
Old Apr 18, 2011 | 08:38 PM
Engine: L31 350
Re: painting help
yeah i apreciate it, im glad someone took time to help me , im gonna get some purple power and i have some wire brushs out in the garage so it should go easy. hopefuly only a day!!
Old Apr 18, 2011 | 09:41 PM
Re: painting help
Just make sure you get all the purple power off before you paint, and try not to rush it. When you get into a rush thats when the paintjob starts to look pretty bad. If you're going to use acetone, use it as the last step, it works wonders on getting the surface clean and dry.
Should only take a day with drying time and such.
Old Apr 19, 2011 | 09:18 AM
Engine: L31 350
Re: painting help
how long? im using my friends garage so i dont wanna tie up his garage
Old Apr 19, 2011 | 09:49 AM
Engine: L31 350
Re: painting help
i was thinking maybe an hour to let the paint dry then let the re assembely flow
Old Apr 19, 2011 | 01:56 PM
Re: painting help
That would be fine.
Old Apr 19, 2011 | 08:27 PM
Engine: L31 350
Re: painting help
okay, my step dads doing the painting as he has done it before, hes gonna do light coats till done so im okay on that part. hes painting the pan too and wants do to the valve covers but i like the grey covers i have now.
Hotrodboba400
Dec 10, 2019 07:07 PM
Drone358
Sep 21, 2015 08:54 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
