Hello all, starting a build thread.
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: Hello all, starting a build thread.
When I bled the clutch for my old camaro, it took what seemed like forever before it was even close to right. Also make sure it isnt leaking, and listen for any abnormal noises coming from the trans with the engine running.
also i should say if i put it in first, press the clutch and try to start it, it doesnt move. if i leave the clutch engaged and try and start it it will roll. could it still be air in the lines?
ive driven it a little, just up and down the driveway. the tranny makes noise with the car running. it shifts into all gears now. revese grinds, gotta be careful. i wanna make sure the alternator is working, making sure the one wire alternator is hooked up correctly.
interior shot
funny sticker.
interior shot
funny sticker.
will this alternator work?
http://shop.advanceautoparts.com/web...R%7CGRPALTSAMS_____#
That alternator looks like it will work just fine.
Alternator is in. Needs a battery. It made it around the block the other day. It has like 3.08 gears in it and still hauls ***. Way faster than my lt1 m6 Camaro. I have the timing right. It's not getting enough gas I think. I gotta mess with it more tomorrow. I'm gunna relocate the battery to the trunk, and hook up the exhaust. Coming along!!
Here's the first driving video. Notice the stalling and bad shocks.
http://www.youtube.com/watch?v=TAE1d...e_gdata_player
My dent
The rest of the pile
My dent
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
So you pretty much turned that into a bat out of hell street machine in a matter of months? Pretty sweet!
How much for the seats?
Car: 1986 iroc-z
Engine: 5.0 tpi
Axle/Gears: stock.
well got my exhaust today. my friend gave be a custom tranny crossmember so the exhaust would fit. but it doesnt fit for some reason so ill have to modify it. but i bolted the exhaust to the headers so its a little quieter for when i start it. trying not to anger the neighbors!!
here it is not fitting
Well the car has exhaust on it. Hangs really low, but it's temporary. I got good fuel pressure but I can't keep the car running, anyone know why? It seems to run on all cylinders when I start it it just shuts off. It won't idle, also doesn't run well under load, so I have to deal with that. Hopefully it's almost done!
Car: 88 IROC Maiden
Engine: 1968 Corvette 350/350hp w/Holley
Transmission: Tex Racing 4 speed
Axle/Gears: 10 bolt 3.90 w/9" axles and ends
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
have you tried spinning the trans x-member around, it may fit
Well it's not using a screen. I cut all the lines at the tank, And I switched the pickup with the return. so it picks up fuel from the return, then as soon as its out of the tank switches to the pick up line. Then it uses the stock line and filter all the way up to the engine bay, where I have a rubber hose off the stock metal line running to the mechanical pump. I know it's ghetto, but it's temporary until I can sump my tank and run a 6an line.
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Yea I know. In the future it's gunna get the g force upgrade and a nine inch, but I want it running first. All of the sudden I can't keep it running. It starts and unless I give it gas it sputters and dies. Also backfires out of the carb. It seems like it struggling to get gas. The fuel pressure is good. I'm using a regulator, but do I need it?
It was running well today. I'm going to eliminate the filter under the car since I have one by the carb. In the future I'm gunna just run a 6an line from the fuel pump back to the tank which I will sump.
Anyway for today's project I got 95% of the body work done. I have to fix one dent, and get a new front gfx. Then when it's warm I'll do one of the budget paint jobs. Here's some pictures.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
if you are not intending on putting a larger hp engine in the car, i recommend staying with what you have, as there are other things you can spend your money on that will yeild better results.
Ok, I just figured it would have been a nicer set up. Oh well.
Today's project was cleaning my ugly tail lights up.
Before , covered in VHT,not glossy enough.
After
After
Car: 92 RS 5 speed
Engine: 5.0L TBI
Axle/Gears: 9 bolt rear
Wow man ! Car is coming along great. You are better off buying the taillight covers anyway.
It's strange to think how far it's come, working in a driveway, on a super limited budget, in just about 4 months.
Day I bought it
Can't wait till it has some wheels. My original plans where for a strip Car, but now it's just gunna be a decent all around street car. I'm thinking some z06 replicas? Idk, I'll play it by ear. My next project is lexan headlight covers, and battery truck relocation.
Day I bought it
Anyone have any RS side skirt badges? One of mine is gone, another is painted over. I can probably fix it, but if some one has one or two for cheap, let me know.
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
Thanks! Well I made the fuel line, got the timing right, but it's got bad gas, I'll siphon it all out tomorrow and get good gas in it. It ran out of a bottle. Ran like a beast!
SOme random pictures, I'm iffy on the Chevy emblem. Is it tacky?
I have a short video as well but don't know how to post it.
Today's project! Started on my headlight covers. In these pics they're just sitting on there, they will look better when they're actually mounted.
Again they aren't flush yet, cause they're just sitting there. But when I decide on mounting them, they'll look good. Anyone have any ideas on mounting them?
I live in new York, we could swap addresses, you could send them in an envelope, and I could send you $10 in a birthday card or something. Bonus, cause I'll get a funny card for your reading enjoyment.*
