My 1986 Z-28 build thread *PIC HEAVY*
#403
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Re: My 1986 Z-28 build thread *PIC HEAVY*
crankcase vacuum helps piston ring seal, piston ring seal makes horsepower!
#405
Car: 1979 Malibu
Engine: Blown LSx
Been flat out busy at work so progress has been slow.
Moved the fuel pressure reg to the valve cover. I had it mounted on the firewall before, but the realized that isn't NHRA legal.
Plumbed the nitrous purge
Finished up the front suspension...
Caster/camber plates
Cleaned up/painted the rear of the car. Also note, rear crash bumper has been removed.
Overall shot...
Overall shot...
#406
Car: 1979 Malibu
Engine: Blown LSx
more updates...
heater hoses done.
Fuel pressure regulator plumbed
Throttle cable hooked up and functioning correctly
Clutch hydraulics installed.
Steering colum and shaft installed
Done for the night.
heater hoses done.
Done for the night.
#407
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
I can say all kinds of stuff about this build but it is easier just to say WOW very nice build
#409
Car: 1986 IROC
Engine: 2000 Vortec 5.7
Just awesome man. You got some serious skills/ motivation to make an awesome car. I hope some day I will have the $, time , and place to do something like this. For now im just enjoying driving my beater, and beating it. And watching your amazing build and dreaming!
#410
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
What are you expecting the car to run in the 1/4? It's coming along very nicely!
#411
Car: 1979 Malibu
Engine: Blown LSx
Updates!
Coil and some other odd's and ends mounted
Massive holes in firewall filled
Master cylinder and linelock mounted
repainted the M/T logo
Brakes plumbed and bled!
Cleaned up the door jambs and repainted.
Fresh paint and new weatherstripping
Along with a crapload of other small things that I didnt take pictures of.
Driveshaft also arrived today so that will be going in tonight aswell.
#412
COTM Editor
Looking great man! Serious Camaro right there!.
Is that a Ring Bros Clutch master res? I like the looks of it.
#413
Car: 1979 Malibu
Engine: Blown LSx
Sure is a ring brothers! Killer piece, I love it.
Mark Williams 3.5" chromoly driveshaft
Loaded the car to go to nolans
Once back at Nolans we started mounting various things
Test fit of rear bumper, cant see any of the fuel system from behind
#414
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
Looks great Brother, it is really coming together now
#415
Car: 1979 Malibu
Engine: Blown LSx
The goal Is to bring it to a big car show/weekend long event about 5 hours south of where I live. The show runs July 12-14 So it's going to be a tight 2 weeks, but im sure I will get it done. Fingers crossed.
#416
Car: 1979 Malibu
Engine: Blown LSx
While I sanded body panels last night Nolan was working hard on my car without me, heres a few pics he sent me.
The one fitting on the fuel cell would lightly rub the tire when turning, so he cut it off and plugged it.
The power hatch motor didnt clear the fuel cell, so he made it a stationary latch.
Heres a quick idea of how the rear fuel cell firewall will work.
He even installed my driveshaft for me!, fit's live a glove thankfully. lol
#417
Car: 1979 Malibu
Engine: Blown LSx
Updates! Over the weekend Nolan got the exhaust, subframe connectors, and lower control arm relocation brackets done, I used the time on the hoist to plumb the fuel system. The feed is a -10, and the return is a -8. Tim at Apple auto glass is a great guy to deal with and came and installed a brand new windshield for me aswell. 90% of the factory wiring is back in place, extra wires have been trimmed and the harness has been re-loomed. I still need to wire in all the gauges/aftermarket fan, pumps etc... I figure by the end of the weekend the car should be moving under its own power. Anyhow... PICS!
#418
Cool beans, glad your getting her done, if I ever get to finish up my house plans in NJ maybe I can start on mine again
#419
Car: 1991 Camaro RS
Engine: 305 will be LSX eventually
Axle/Gears: Borg Warner
Love the build! I was confused when I saw you ran heater hose into the cabin, and then plugged up the blower motor opening. Then I saw something attached to the front roll cage that I haven't seen before, I'm assuming it's for the heat? I'm curious what it is exactly? For those who don't plan on running A/C and want to clean up the engine bay that is a great Idea.
Can't believe I've missed this build until now. Glad I did come across it though. A lot of good ideas. I will be following your build until the end. Hope you get it rolling on it's own power soon!
#420
I have a 92 rs it has a v6 in it and I have a 96 z28 with a 350 lt1 motor in it and I was wonting to switch the motor and wiring harness out of the 96 into the 92 would that work
#421
Car: 1979 Malibu
Engine: Blown LSx
#422
Car: 1979 Malibu
Engine: Blown LSx
Not the most exciting update, just wiring and more wiring...
#423
Quick question. Which spark plug wire looms are you using? It's what I need for my build.
They look like the Trans Dapt 9370.
Thanks.
Thanks.
#424
Car: 1979 Malibu
Engine: Blown LSx
It's the moroso ones for centerbolt valvecovers.
#426
Thanks for that. I've ordered a set.
By the way, for what it's worth, I'll be heading out your way and should be in Edmonton around the 3rd week of August. At present, my car is running like crap from a performance standpoint. Trying to sort out this Barry Grant carb is giving me fits although I will say that I've got the highway mileage tuned to over 22 mpg. That should help the road trip cost.
I'd like to make a pass or two at Castrol Raceway when I'm there. Not sure how I'll do because it'll be the maiden trip for the whole new engine package but I'm packing my slicks just the same. Last season's combo went 12.60's. Certainly not in your territory but it IS a cross country cruiser.
Do you figure you'll be on the road at that time? You've got a lot more to do than I did.
#427
Car: 1990 RS
Transmission: Built-700R4
It's looking great, better every time I check on the thread, AWESOME work!!!
#428
Car: 1979 Malibu
Engine: Blown LSx
#429
Awesome build thread, sir! What kind of E.T. are you expecting, WITHOUT the Nitrous ?
#431
#433
Any idea of your race weight?
My full bodied street car with sub-frame connectors and Dyna Mat, tips the scales at 3750 with my 200 lbs in it.
I've lost track of all of the changes you've made. Remove weight, add weight...Maybe 3300-3500 ready to go?
Do you know if the scales are available at Castrol on the JB Street Legal nights?
#434
Car: 1979 Malibu
Engine: Blown LSx
I'd like to see 3300-3400 starting line weight.
#436
Car: 1979 Malibu
Engine: Blown LSx
#438
#441
Nice.
#444
Car: 1979 Malibu
Engine: Blown LSx
After installing the crank trigger, setting the fuel pressure, timing, idle etc...
http://instagram.com/p/ckkRu8NB66/
Also managed to solve the wiring gremlin I've been chasing in the light circuit.
http://instagram.com/p/ck8biFtB6l/
#445
Getting closer.....
#446
Car: 1979 Malibu
Engine: Blown LSx
UPDATES:
Primed some parts
battery cables and whatnot...
New harwood 4" outlaw cowl hood
Got all the lights working!
Installed a MSD crank trigger
Completed engine bay:
Primed some parts
#450
