New member with a new project.
Car: 92 RS Camaro
Engine: 400 SBC
Transmission: Powerglide
Axle/Gears: Fab 9 with 4.10
Hi all, I am new to the forum and thought I would tell ya a little about me and my project. After losing my left leg in an accident in 09 I am now getting stuff together and have began building a 92 RS Camaro to return to racing. I do not wanna make this thread about my accident, I do not want to make this thread about assumptions or speculations about what caused my accident either. I hope that you guys can respect that. I have stayed away from forums since my accident because of this fact.
The car is a 92 RS. Came with a V6 and a stick, which are both gone now. We are building a 421 SBC and a Glide for the car as we speak. The car has already been gutted and sent off to the chassis shop that is doing the back half job on it. We will be installing a K-member, A-arms, and Drop Spindle struts from AJE on the front along with a Rack and Pinion steering set up.
We are building the car for a new class being held at two tracks close to me here in Texas called Texas Triple Threat Racing. It is a 5.80, 6.00, or 6.20 ( 1/8th mile ) index class that you find out what you run during the drivers meeting. I thought this class would be fast and fun to compete in. If all goes well we hope to be competitive as well.
The build is being covered by RPM Magazine and will be in 10-12 issues. The first article is coming out soon and I'll post when I have the correct month.I can not post alot of pics of the car until the article is 45 days out of print, but will be putting thumbnails on my website that would take you to the complete article 45 days after the magazine hits the news stands.
We will be making alot of changes and up grades on the car. If you have any input that could assist us in our build just chime in. Any questions about the parts we are using or in need of, just ask.
Thanks, Blake
Thanks, Blake
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Re: New member with a new project.
Sounds like a fun project, keep us updated with some pics!
Car: 92 RS Camaro
Engine: 400 SBC
Hi all, the first article was in the May issue of RPM Magazine, just an introduction, but it can be read on page 72 at the link below. http://www.flipdocs.com/showbook.asp...0003372_510988
We are also in the June, July, and August issues and I'll post links when the are available on-line as well.
Later, Blake
Later, Blake
Car: 92 RS Camaro
Engine: 400 SBC
Hi all, the second article covering the first part of the back half in RPM Magazine is now available on-line at: http://www.flipdocs.com/showbook.asp...0003372_711048 page 64.
Later, Blake
Later, Blake
Car: 92 RS Camaro
Engine: 400 SBC
Part 2 of Back Half article can be seen at: http://www.flipdocs.com/showbook.aspx?ID=10003372_429016 page 60
Car: 92 RS Camaro
Engine: 400 SBC
I figured I would bring this old thread back to life with pics from our build. Sorry about neglecting the thread so long.
We left the subframe connectors from when the car was minitubbed for added support.
Car: 92 RS Camaro
Engine: 400 SBC
Up front we went with an AJE k-me
We also removed as much of the strut tower and fender well to allow me more access to the engine compartment.
mber and coil over strut assembly
Car: 92 RS Camaro
Engine: 400 SBC
The front frame was bobbed and receiver tubes were installed for our VFN front end.
Car: 92 RS Camaro
Engine: 400 SBC
Weight reduction in the rear deck lid was up next.
We removed the window and will be going back with lexan.
Car: 92 RS Camaro
Engine: 400 SBC
Rear bumper supports and impact material was removed as well.
We will be adding a 1 1/4 tube to attach the rear wing struts to under the cover in the future.
Car: 92 RS Camaro
Engine: 400 SBC
The powerglide transmission consist of all BTE internals including a straight cut 1.80 planetary
1.80 straight cut planetary set up.
We went with a pro tree brake.
This modification will allows us to put a gauge on the transmission to read real time pressures.
assembly.
assembly.
Car: 92 RS Camaro
Engine: 400 SBC
Our third member includes a nodular housing, aluminum pinion support, a 35 spline spool and 4.10 gears.
Car: 92 RS Camaro
Engine: 400 SBC
The rear end housing is a fab 9 with 35 spline Mitchell Differential axles.
We upgraded to 5/8 studs and added a Disc Brake set up from SSBC.
Car: 92 RS Camaro
Engine: 400 SBC
Reed at Work Turbo custom built the S480 turbo for us, we chose to do an upgraded race cover and twin scroll 1.32ar T-6 flange housing. We are hoping for 1,150-1,250horsepower out of the 400ci SBC.
Car: 92 RS Camaro
Engine: 400 SBC
We are in the process of doing the engine mock up and hot side fabrication.
We added block adapters for the remote water pump.
We intended on flipping the 1 7/8 block hugger headers, but had clearance issues, so the exhaust routing will be from below.
I have ordered a 90 degree hose end so I can shorten the feed line for a cleaner installation.
Car: 92 RS Camaro
Engine: 400 SBC
Here are some sneak peeks of what is going on as we speak. I'll update more when I'm able.
Please excuse the rack boots, I have new ones to replace them, but am waiting on welding in the area to be completed.
Pac J
May 17, 2020 10:44 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
LT1Formula
Oct 8, 2015 08:34 PM
