89 Iroc Restore/Build
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 2.77
My first project, no "real" experience to speak of but I am diving in head or fuel system first. Picked up an 89 in Dec 11, car had not run since 05. not been driven daily since 2000. Would not crank. I am guessing fuel pump and sending unit. I have pulled the rear wheels, rear axle and fuel tank out. I am getting an electrical signal from the relay, no signal through the sending unit. I think a new fuel pump and sending unit. I am also replacing all of the bushings, rear struts and brakes/calipers/lines and such. Will post pics of the ten year rust on the rotors. I hope this don't take 5 years.
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 2.77
Re: 89 Iroc Restore/Build
Ordered New Fuel Sender, Fuel Pump, Rear Struts, Calipers, Rotors, Pads, Brake Lines and Bushing set.
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Energy Suspension makes a complete poly kit for these cars, but for the rear you could look at the founders performance LCA/ panhard bar kit. Its dirt cheap, stronger than stock, has poly bushings and comes powdercoated red or black.
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 2.77
Thanks for the reply! I just got the Energy kit in the mail. Still waiting on a few parts to come in. The undercarriage is immaculate! Nice job.
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
Hey, Jimmy, Mine took 5 years. But it was totally worth it! If you need inspiration check out my car on the body forum. When you get her done there is a feeling of accomplishment that is not easy to describe. People with cars worth 10 times as much will pause to look at your car, and every fart can import will immediatly start acting like an *** and beat their cars when in her presence! Good Luck!
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 2.77
Thanks Eagle, It is going pretty good so far. I will wait to do the body and paint when I get home next year. The suspension is taking a while because I am finding stuff that needs to be replaced as I tear down. Cost a little more than I initially expected but I feel it is worth the time and money. Not going for show quality underneath just solid and dependable.
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
Amen to that, I did the same thing under mine, solid and changed out all the parts as I went, good luck
Stock track bar (powder coated) the rest is Founders and the springs are Hotchkis
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 2.77
Front - New ball joints, Energy poly bushings, new tie rods, new struts. Waiting on rotors, Calipers, Pads. Rear - Rotors, energy poly bushings, struts. Waiting on calipers, pads. Overall - Waiting on fuel sending unit, Pump, brake lines, flowmaster cat back exhaust and tires. Will post pics soon.
Engine: All 5.7's
Yep, Same route I took with mine, solid and reliable. I wanted a good driver car. My suspension is all poly and I just put on J&M poly ball rear arms. Poly really makes it ride with a solid feel. Good luck Brother, I hate waiting for parts too!
I bought a set of Russell Braided brake lines for the car, just ordered a new master cylinder also
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 2.77
Christmas time in April!! I have been in Yuma AZ since Tuesday, just got home and so many parts have arrived! Still short a few parts but at least I can start work again. I have had no luck getting the OEM fuel sending unit. I guess I will have to get the Spectra. I should have some pics tomorrow.
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 2.77
I am cancelling the rest of the items I ordered from Auto Parts Warehouse. I ordered every item on 18 April. I have received on three of the 10 things I ordered. No E-Mail stating out of stock or what not. I have great success with Summit! I will use them in the future. Also US Auto parts was not very helpfull. I ordered a fuel sending unit with overnight delivery on thursday. Was told it would arrive on monday due to fedex not shipping on weekends, finally got an e-mail sating out of stock on wednesday. Frustrating. I am using oreilly and autozone for the small stuff.
I hear ya on that, I use a local spped shop here for most of my stuff, I just picked up a Mr Gasket dip stick and a set of ARP flex plate bolts. I use Summit when they either don't have or their price is just to high for the same product.
Car: 88 Camaro Coupe - 99 Corvette
Engine: 305TPI - LS1
Transmission: A4 - A4
Axle/Gears: 3:73 - 3:15
rockauto.com is by far the best internet parts place
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 2.77
She runs!!! I will have pics eventually. still need a new master cylinder and I am waiting on exhaust. small victories!
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 2.77
Now she wont start. attempted to start and on the third key turn I got nothing. No hit to the starter. Replaced the starter. Nothing. Narrowed it down to the purple wire on the solenoid. I jumped from the solenoid to the battery and I get the spark, now it still wont start. The fuel is getting to the fuel rail, but it wont fire over. Any suggestions?
So she is cranking but wont fire? I would check the in-line fuse on the apron just back from the battery its in a small black fuse holder. It will be bolted to the rail below the fender with a ground right next to it, open the case check the fuse, they blow when you check starter wireing some times.
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 2.77
She was cranking, now when I turn the key to crank I get nothing. I Did hot wire from the solenoid to the battery and it will turn over, just wont start.
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 2.77
What is the procedure to bypass? I think it is the case also but I want to test to make sure. I also found a bypass kit on rick's camaros, anyone know if it is worth it?
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I just went to radio shack and bought a potentiometer and using two of the leads with my tester adjusted the little screw until it read .68 (my keys resistance) . Just put it between the to VATs wires and your done.
I just asked the guy for one that would match that resistance.It cost me all of $4.00 ,I don't know exactly the one but it looks like this.
= http://www.radioshack.com/product/in...ductId=2062308
I did it and it has worked perfectly.
I just put my motor in on Friday, I actually hope to drive mine (at least test drive it) in the next two weeks
mustangman65_79
Aug 11, 2015 03:17 PM
