My 85 IROC Z28
Engine: Solid Roller 406 SBC
Transmission: RMVB TH400
Axle/Gears: Stock Ten Bolt 3:42 Gears
My 85 IROC Z28
So i found this third gen here locally. Its an 85 IROC Z28. Came with S&W race cars subframe connectors, torque arm, lca's tranny x member, built TH400, aluminum radiator, e fan, sumped stock tank, all stainless lines, holley blue fuel pump, KYB shocks, has Contour Camaro seats, extended wheel studs, locker with 3:73's on iron rims wrapped in Mickey Thompson drag radials, Quick Silver B&M Shifter , hooker super compkids headers and full interior. I plan on doing some moroso Trick Springs and V6 springs in back with lake wood 90/10's and 50/50's. I am gonna drop in a 511cam casting 400 SBC that's built to a 406 with canfield aluminum heads that made a tad less than 600 on 112 octane at the flywheel. Hope to get the motor running in the car by middle of next month. Rear end will be swapped for a Ford 9 with 4:11's and a spool with 15x4's and 15x9' s with a 5.5 BS. Later this year.
I'll post up pics when my buddies and i drop in the motor and turn this roller in to a runner.
Re: My 85 IROC Z28
Car is up and running. Hope to have a video and pics up later tonight.
ambainb
Apr 25, 2016 09:21 PM
mustangman65_79
Aug 11, 2015 03:17 PM
