Finally...back on the 91!
Old Dec 1, 2012 | 04:03 PM
David 91RS/Z28's Avatar
I see many builds in this section so it seems appropriate to post here... After a 5 year plus hiatus, I'm finally back to working on my Camaro! She has been hibernating in the garage due to losing interest in working on it after running into some issues as well as other things in life. The car had been having clutch problems and pretty much knew the trans was gonna have to come out. Well after a couple years of sitting and having run the engine only a couple times, the fuel pressure took a crap. My suspicion is the fuel hose that connects the hard line to the pump has split. Happened before once and it's the same symptoms. Anyhow, as I have been perusing thru the message board again and seeing lots of awesome builds going on, I have really taken an interest again after getting started. I have lots to do(as a result of "while i'm there") and then I'm not even sure once I finish what I might do with the car. Probably sell it but I will at least drive and race it a few more times!
Things to do:
Fix fuel pressure
Clean up the differential
Change out some rear suspension components
Pull Trans, swap clutch, bleed hydraulics
Clean up the underbody and components
Bleed brake system
Pull radiator and have cleaned
A lil bit of engine maintanence
Trying to do this in the least expensive way as I don't feel like dumping much more into the car at this point after owning it almost 18 years.
Parts I already have or acquired over the years to be installed:
Spec II clutch (dealer cost looooong time ago)
BMR poly adjustable LCA's (used,$100 bucks)
Front and rear swaybar bushings and endlinks ($60)
Random Technology adjustable Torque Arm (Free...long story)
SPOHN driveshaft safety loop... prolly require modifying for fitment with exhaust ($80 bucks)
Russel SS braided center rear brake hose ($40bucks)
KYB AGX rear shocks ($160)
At this point, the exhaust is out, the rearend is just about out cept for 3 bolts, swaybar out, shoes all removed and E cables disconnected, driveshaft out, and tank is waiting... Long way to go! Heres a few pics I snapped, but I will be taking more photos and posting progress as I go along.
Attached Thumbnails Finally...back on the 91!-rearendbefore2.jpeg   Finally...back on the 91!-rearendbefore3.jpeg   Finally...back on the 91!-centerexhst.jpeg
Old Dec 3, 2012 | 12:40 AM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Re: Finally...back on the 91!
Sweet, cant wait to see some more updates!
Old Dec 3, 2012 | 10:41 AM
A bit more progress... Rear is out as well as tank! I think I may have the bad tank which insued the recall. Looks like some leaky leaks here! I sure don't recall it being this bad looking last time I dropped it. Gonna have to check my VIN and see if it falls under it. Only thing is I wonder if I could even get the recall done if I'm doing the work?? The old stock LCA's with poly bushing sure have worked ok but it's time for an upgrade! I wish I could say the same for the diff, but I'll have to stick with the stocker! Swaybar will get sent to powder coater then all new bushings and endlinks will be installed.
Attached Thumbnails Finally...back on the 91!-fueltank.jpeg   Finally...back on the 91!-rearendbefore.jpeg   Finally...back on the 91!-swaybar_lca.jpeg
Old Dec 3, 2012 | 07:29 PM
BLACK92B4C's Avatar
Car: 92 B4C 1LE/2010 GT/2003 P71/2002 Z2
Engine: 5.7/4.6/4.6/5/7
Transmission: A4/A5/A4/A4
Axle/Gears: 3:23/3:73/3:23/3:73
Good job buddy, I just finally jumped back on after about 4 years off with my 1992. Never to late
Old Dec 6, 2012 | 04:22 PM
Woohoo! Got my sways back from the powder coaters! Came out really good even though the pic doesn't do justice! Red poly bushings and endlinks to go around once i'm ready to reinstall them!
Attached Thumbnails Finally...back on the 91!-swaybars.jpeg   Finally...back on the 91!-swaybarsblackpc.jpeg
Old Dec 7, 2012 | 09:02 PM
MMroc86's Avatar
Car: 1986 IROC-Z28 & 1987 GTA
Engine: 305 TPI & 350 TPI
Looking good! Nice Pics to.
And whats this I hear about a gas tank recall?!
My tanks leaks when it has 9 or more gallons, I just thought my tank was screwed and I need a new one!
Old Dec 7, 2012 | 09:03 PM
MMroc86's Avatar
lol, just did a search & noticed that its 91 only. Guess my first assumption as correct! hahaha
Old Dec 10, 2012 | 09:44 AM
Ugh! Fuel tank is corroded as well as the pinholes on filler neck, assembly completly corroded/rusted, and pump is locked up. I tested the pump to see if it spun by connecting to battery. It clicks but no spin. I've got the recall info and will contact GM about the tank. Not what I wanted to see when I pulled the assembly for sure. Was hoping for just a split hose to cause the loss of fuel pressure, but the rubber in the hose is completely disintegrated! It's my fault for letting the car sit so long. Anybody have any recommendations on which fuel assembly to buy?? AC Delco unit is $290 thru RockAuto and then I see the cheaper brands at half the cost. If I can't get the tank recall performed then thats another $170 plus the $100 on another Walbro pump.
Attached Thumbnails Finally...back on the 91!-fuelassembly1.jpeg   Finally...back on the 91!-fuelassembly2.jpeg   Finally...back on the 91!-fuelassembly3.jpeg
Old Dec 10, 2012 | 09:45 AM
A couple more pics...
Attached Thumbnails Finally...back on the 91!-fuelassembly4.jpeg   Finally...back on the 91!-fuelassembly5.jpeg   Finally...back on the 91!-fueltankinlet.jpeg
Old Dec 10, 2012 | 10:37 AM
ohiosteve's Avatar
Pinhole in the filler neck is a safety recall. Take it to a dealership.
Old Dec 11, 2012 | 12:18 PM
Caleb Taylor's Avatar
Car: Pontiac GTA
Engine: 5.7L TPI
looks like a good build! anxious to see it done
Old Dec 20, 2012 | 04:50 PM
Not too much of an update cept ordering/waiting on parts and cleaning up some existing stuff. A lil wax on powdercoated parts sure works great to shine them back up! The wonder bar pic below, I did half and it looked almost new! Got the diff all cleaned up as well. The center section was completely caked with years of oil and grime! I'm just gonna put a coat of black on it and roll with it. Should look much better though! Still waiting to hear back from local Dealer on the tank recall, otherwise I'll just have order one. Lots to come....
Attached Thumbnails Finally...back on the 91!-wonderbar.jpeg   Finally...back on the 91!-diffclean.jpeg
Old Dec 20, 2012 | 05:07 PM
ohiosteve's Avatar
The dealership will install an aftermarket tank if your tank fails the pressure test. Search on tank recall.
Old Dec 20, 2012 | 07:57 PM
Nobody but me is installing anything! Lol! That's kind of the issue though...since I'm doing the work I'm hoping the Service manager will help me out to do the warranty without the car. It's not really suppose to go down that way but I have read that some have done so. And yes I know it'll be aftermarket. I read thru the whole recall thread weeks ago so I'm up to date on it. I won't be pissed if they don't but it's worth a shot!
Old Feb 13, 2013 | 03:14 PM
It's been a while and I have made only a little progress. Just haven't been able to work on it like I have hoped. I've painted the rear end and rear brake lines. I've also been using my dremel with wire brush attachment to clean up bolt heads for a nice detail. They look new again as you can see. Long long ago the torque arm bracket was bent from UPS and I got that fixed and installed. I have new fuel tank, pump, and assembly together and ready to go back into the car as well. Slowly but surely though, right!
Attached Thumbnails Finally...back on the 91!-bolt.jpg   Finally...back on the 91!-bolts.jpeg   Finally...back on the 91!-diffpainted.jpeg
Old Feb 13, 2013 | 03:17 PM
Here is a shot of the rear before painting. It took lots of scraping and brake cleaner to clean up the grime, grit, n grease built up!
Old Feb 15, 2013 | 12:12 PM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Damn straight, and good attitude to have.
That 10 bolt looks awesome too! Did you blast it?
Old Feb 18, 2013 | 10:49 AM
Thx! No, just several coats. I think it came out pretty good too. 100x better than before! Now I just need a TA cover to finish it off!
Old Feb 18, 2013 | 10:51 AM
Car: '91 LS6/T56/9"
Engine: LS6
Several coats of what? Degreaser/pressure washer?
Old Feb 18, 2013 | 02:22 PM
Paint.
Old Mar 1, 2013 | 11:20 AM
Some progress... Back rear underbody is painted along with a couple heat shields. Got the new tank in as well. I also ordered one of the Perfect Launch diff covers as it will be going in next with rear suspension. Think I might test fuel pump 1st just make sure it's buzzin before the diff! Would suck to have to remove everything if it wasn't. lol
Attached Thumbnails Finally...back on the 91!-rrunderbodypainted.jpeg   Finally...back on the 91!-rrunderbodypainted2.jpeg
