'83 Z28 Build Thread
Old Apr 7, 2015 | 12:31 AM
paulieet's Avatar
Car: 83 Z28
Engine: LG4 305--Pulled
Transmission: T5 Non-WC
Bought an '83 Z28 last fall. Been my dream car since high school to own a stick shift V8 Camaro, I've owned 2 other V8/Auto Camaros, but this one will be a keeper. Plans are to the suspension up, a built rearend, new interior, new paint, T56 or TK0 swap, and either a supercharged 350 or a 5.3 swap
Old Apr 7, 2015 | 12:36 AM
paulieet's Avatar
Car: 83 Z28
Re: '83 Z28 Build Thread
New cam installed and double roller timing set
1st time porting anything
more
Old Apr 7, 2015 | 12:39 AM
paulieet's Avatar
Car: 83 Z28
Moog 5665's for the rear
Coming back together
Nitto 275/60/15's (more tire than the 305 knows what to do with)
Old Apr 7, 2015 | 12:48 AM
paulieet's Avatar
Car: 83 Z28
Put a few go fast goodies into the LG4 over the winter just to help me be a little more content with it until the motor swap, and I only put a few hundred dollars into it. I mirrored a build that carcraft did a long time ago, and the engine should be sitting around 230hp-250hp I'd guess.
Old Apr 7, 2015 | 02:02 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
I love the look of 275's in the back (have them on my own '83Z). Also gives the car a nice rake with a 28" tire on the rear.
Old Apr 17, 2015 | 07:01 PM
paulieet's Avatar
Car: 83 Z28
Well I threw the warmed over LG4 on Craigslist and had a bite on it. Guy came and put money down on it, so I pulled the motor today so I'm onto bigger and better things. Didn't even get 400 miles on the motor after the go fast goodies were put into it. I'm just happy to offload the boat anchor.
Old Apr 18, 2015 | 12:42 AM
paulieet's Avatar
Car: 83 Z28
305 out!!
Need to ditch the exhaust manifolds and the true dual exhaust that's on the car, also delete a lot of the wiring.
Old Apr 18, 2015 | 12:46 AM
paulieet's Avatar
Car: 83 Z28
Took the dash out to install new Infinity speakers, also going to put a new heater core in, just for good measure.
A bit cracked.
Old May 1, 2015 | 06:10 PM
paulieet's Avatar
Car: 83 Z28
Got some more goodies in the mail yesterday for the rear suspension
Old May 2, 2015 | 09:13 PM
paulieet's Avatar
Car: 83 Z28
Cut the manifolds and true dual exhaust off of the car and starting to sort thru the wiring.
Old May 2, 2015 | 11:30 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Attachment 291455
Old May 6, 2015 | 11:42 PM
paulieet's Avatar
Car: 83 Z28
Made some pretty good progress earlier this week. Replaced the heater core just for good measure, it was surprisingly easy. I ended up breaking the heater motor blower resistor, it was pretty brittle. I looked everywhere for one, Ekler's firebird sales was the only place I found that has one for a Non-AC car. I had to lie on the checkout about my model and year of "firebird"
Stripped all the interior out. It will be black
Ditching the rear seats and the harness
Prepping the firewall for paint
Old May 12, 2015 | 10:54 PM
paulieet's Avatar
Car: 83 Z28
Got the wonder bar in the mail today. Hope to get some painting done tomorrow of the firewall and heater box/motor.
Old Jul 6, 2015 | 07:06 AM
paulieet's Avatar
Car: 83 Z28
Getting it ripped apart, everything came apart fairly smooth. Still need to get the A-arm out to get new bushings pressed in.
Cut about a half coil out, had them in an ice bucket so they didn't heat up....a little over board maybe.
Both front springs were broken on the first coil
Old Jul 28, 2015 | 09:45 AM
paulieet's Avatar
Car: 83 Z28
Got this in the mail today, my dog approves
Old K member came out surprisingly easy, the bolts turned fairly easy. I just took it out with hand tools and didn't even need a crazy long pipe on the breaker bar to get them loose. I was lucky
Old Jul 28, 2015 | 05:50 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Looking good paulieet!
Where in WI. are you at?
Old Aug 5, 2015 | 05:15 PM
paulieet's Avatar
Car: 83 Z28
Got the driver's side back together and that's when the issues started on the passenger side with the K-Member.....
Old Aug 5, 2015 | 05:22 PM
paulieet's Avatar
Car: 83 Z28
This is a UMI K-Member
Here's the driver's side, no issues.
The passenger side either has to much metal left hanging from the "tab" or the bolt hole was drilled in the wrong spot. Haven't had the wheel on to figure out which on it is.
I ground material on both the K-member and a little on the A-arm
I emailed UMI today and am waiting reply. Every company can have issues with their product from time to time, but it pisses me off when you pay good money and issues come up. I'm sure they will make it right, but the only way to do that is for me to take it out and them send a different one... Frustrating when you want your car ready for an engine to go into it.
Old Jan 19, 2016 | 09:55 AM
paulieet's Avatar
Car: 83 Z28
Been a while since I updated this.
Engine bay turned out pretty good
First time on the ground with the new K-member and suspension
This ugly thing will be finding a new home between the camaro's fenderwells
The 350 and T5 going in
Old Jan 19, 2016 | 10:09 AM
Car: 1983 Z28
nice!
Old Jan 19, 2016 | 01:59 PM
crazynights's Avatar
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
Love this thread! Great job! Enjoy and thanks for the pics!
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
GVMV
Aug 16, 2015 08:01 PM
