Its Time- My 87 IROC LT1/T56 swap and more
Old Oct 12, 2016 | 04:59 PM
  #51
KCG's Avatar
KCG
Car: 89 IROC
Re: Its Time- My 87 IROC LT1/T56 swap and more
That is really sharp. I'm trying to get my son to paint his 2nd gen that color.
Question on your painting, I'm trying to learn how, do you not have to take a car down to bare metal to change the color? My 89 is black and want to go to red.
Old Oct 12, 2016 | 06:11 PM
  #52
tglennon11's Avatar
Car: 87 IROC
Axle/Gears: LS1 10bolt w/ 3.73
thanks- what does your son have?
So this is the first car i have actually sprayed but i have done the prep work on a few others- in all instances i have not gone to bare metal unless other work required it. the OEM primers are pretty good and work to help adhesion. Just sand it with 400 grit and shoot your primer over it. If you go to bare metal in more than a few spots you will want to use an etching primer to promote adhesion between the metal and whatever primer you are using.
I talked to a few shops before i bought my paint and materials. also check out Southern Polyurethanes, they have a pretty good customer service department and can answer lots of your questions. SPI is good for the pre base coat materials and the clear, but they dont do the color coat, just not in their biz model.
Good luck!
Old Oct 13, 2016 | 06:03 PM
  #53
KCG's Avatar
KCG
Car: 89 IROC
An 81. Looks good in the picture, but its about ready for a paint job lol
And thanks for the additional info
Old Oct 13, 2016 | 08:52 PM
  #54
tglennon11's Avatar
Car: 87 IROC
That picture makes it look great, thats a great looking ride.
Let me know if you have any other questions.
Old Oct 14, 2016 | 05:33 AM
  #55
KCG's Avatar
KCG
Car: 89 IROC
I don't want to hijack your thread...If you have any other advice, would you mind posting in mine? Thanks!
https://www.thirdgen.org/forums/body...ing-paint.html
Old Jun 6, 2017 | 01:28 PM
  #56
tglennon11's Avatar
Car: 87 IROC
Well I just spent the weekend looking through some pictures on my phone of the camaro and realized i have not updated this thread with what i did over the winter-
I got tired of the multi-colored parts in the engine bay and decided wrinkled black was the way to go, so i took off the valve covers, stripped them and painted them, I painted the vanes silver and then masked them off rather than polishing them for durability.
while I was in there i replaced the valve springs, thought about RR but had some interference with the iron head and the pushrods.
Old Jun 6, 2017 | 01:30 PM
  #57
tglennon11's Avatar
Car: 87 IROC
after that was done i went ahead and "upgraded" to the C5 brakes up front. I had some nasty squealing from the brakes originally and found some misalignment with the spindle bracket to the spindle, so it was a good time to get everything straightened out-
Old Jun 6, 2017 | 01:32 PM
  #58
tglennon11's Avatar
Car: 87 IROC
and finally, just recently, i was still not happy looking under the hood. The fuel rails were pretty tarnished and couldnt get them clean. I also noticed my paint was flaking off of the intake. So i went a fabbed up an intake/fuel rail cover. the benefits of working at sheet metal fab place-
that is a piece of brushed stainless under the slots on top of the intake. I think it covered up all of the wiring etc pretty well. Engine bay is night and day better.
Old Jul 7, 2017 | 09:40 AM
  #59
tglennon11's Avatar
Car: 87 IROC
fixed broken picture links, silly photobucket
Old Jul 7, 2017 | 02:38 PM
  #60
Faine's Avatar
Car: 1986 Trans Am WS6 w/ Recaros
Engine: LB9
Wow, definitely adds a nice touch! good job
Old Jul 17, 2017 | 11:18 AM
  #61
tglennon11's Avatar
Car: 87 IROC
Sig Test and a new picture
Old Jul 17, 2017 | 07:43 PM
  #62
tglennon11's Avatar
Car: 87 IROC
In going through all of my pictures I realized I don't have any of the car with the tops off, consider that fixed. Especially since that was most of why I bought this car...
Old Jul 17, 2017 | 08:32 PM
  #63
tglennon11's Avatar
Car: 87 IROC
Walking out after work this always puts a smile on my face
Old Jul 18, 2017 | 11:26 AM
  #64
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Where did you buy your shift ****? 12 or 16mm threads?
Old Jul 18, 2017 | 11:36 AM
  #65
tglennon11's Avatar
Car: 87 IROC
this may ruin the dream, but its actually a F**D Rustang Cobra t56 ****, i drilled it out and tapped it for the stock 16mm threads.
Old Jul 18, 2017 | 12:25 PM
  #66
Car: '91 LS6/T56/9"
Engine: LS6
Nah I knew it was a Cobra ****, just wondering where you got it.
I'm looking at which options are cheaper for me. Either:
1 - Cobra **** ($68 Pony Tuning) + 12mm handle for my MGW shifter ($23 MGW) = $91
2 - Hurst/SLP **** ($78 Summit) + new shift pattern indicator ($13 Hawks) = $91
Since they're equal I went the Cobra shifter.
Old Jul 18, 2017 | 12:29 PM
  #67
tglennon11's Avatar
Car: 87 IROC
I like mine, but with the drill and tap i fit it to my Pro 5.0 shifter handle.
Old Jul 22, 2017 | 10:59 AM
  #68
Cglennon10's Avatar
Transmission: TH400
awesome color, really nice job
87 camaro iroc
Aug 20, 2015 07:47 AM
jharrison5
Aug 19, 2015 05:53 PM
BewleyBizzIROC
Aug 14, 2015 02:52 AM
mustangman65_79
Aug 11, 2015 03:17 PM
