My First 92RS - The Revival
Old Sep 1, 2022 | 04:29 PM
  #51
Whitebird75's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 L V6
Re: My First 92RS - The Revival
Have you noticed a change in the smoke between post 16 and now? Was it the reason why you pulled the valve covers off recently?
Old Sep 1, 2022 | 05:11 PM
  #52
92RS-HeritageEd's Avatar
Car: 92 RS / 90 IROC-Z
Engine: 305 / 350
Axle/Gears: Non-Posi / Posi - Both GU2 - 2.73
No, I can't say that I did. I was re-reading my thread and noticed I was offered a suggestion and I never even gave it a shot + it gave me the chance to put on some new covers I had laying around a few years. What really brought me back to post #16 was the fact my Oil psi is normally midway on the gauge out of nowhere now it starts at the max & sometimes I'll see it come down a bit but in a blink it's right back at 60 or whatever the max is.
Old Sep 1, 2022 | 05:30 PM
  #53
Engine: 2.8 L V6
Sometimes the oil gauges, are a little funky, but the smoke sounds like either stuck rings due to carbon, worn out rings due to use, or bad valve seals. I'm assuming that the smoke has a bluish tent to it?
Old Sep 1, 2022 | 06:43 PM
  #54
Engine: 305 / 350
Idk, it just looks like faint smoke, but the exhaust smell will make your eyes water. Was told it "smelled lean". ll try and get a video of it tomorrow after the engine flush and oil/filter change.
Old Sep 2, 2022 | 02:40 PM
  #55
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
You've been busy while I was gone!
FYI...the posts in the "Members Camaros" sub-forum are more often used for documenting your build. There is certainly nothing wrong with asking technical questions within your build thread, but a lot of folks who frequent the forum don't come in here.
If you run into a technical problem, and need a more timely answer, you might do better posting that specific question in a part of the forum meant to support those kind of questions...Tech/General Engine for this one maybe, or Electrical for electrical questions, etc.
Old Sep 2, 2022 | 07:02 PM
  #56
Engine: 305 / 350
That explains everything! Much respect & Thank you for the enlightenment.
Old Sep 2, 2022 | 07:24 PM
  #57
Engine: 305 / 350
Wheeled out the New US General Tech Cart today, since I bought it to work on my Camaros It was time they meet. First I taped up the IAC Valve wires and connected it, then the battery. I ran this Motor Flush stuff through it for 5 min, drained it. Jacked up the passenger side for more drainage. Filled & installed the new filter, lowered her down and filled her with STP High Mileage 5W-30. Having the cart outside keeping everything close by made this easy. Cleaned up, no visible leaks so I fired her up. No smoke visible for the first few minutes, but I knew it was to good to be true. I blipped the throttle and boom... smoke. So I guess I'm off to the tech section for some troubleshooting advice.
White90Birdo
Sep 10, 2018 12:22 AM
Tonglebeak
Jun 8, 2012 12:43 PM
Chevy8588
Feb 1, 2010 09:08 PM
86White_T/A305
Apr 16, 2008 08:00 AM
chio987
Oct 14, 2004 06:24 PM
