dead on arrival IROC
Old Dec 21, 2019 | 07:21 PM
N8IROCZ's Avatar
Want a title? Post!
Hello all , got this car as a trade for an old work van i had . Car needs work to be road worthy i was told
so i yanked her in the garage after 6 months of sitting outside to see what it was gonna take.
Old Dec 21, 2019 | 07:26 PM
N8IROCZ's Avatar
Want a title? Post!
Re: dead on arrival IROC
cleaned the leaves and lizards out gonna need a belt, battery, plugs so far.
Old Dec 21, 2019 | 07:31 PM
N8IROCZ's Avatar
Want a title? Post!
and so it begins,got a new battery in her but just clicks rapidly , ground mabey?
Old Dec 22, 2019 | 07:43 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Check the positive battery cable and make sure all you connections are tight.
Old Dec 22, 2019 | 10:16 AM
Billgluckman's Avatar
Nice project. Have you made sure the engine isn’t locked up? Bad starter possible too.
Old Dec 22, 2019 | 12:00 PM
N8IROCZ's Avatar
Want a title? Post!
come to find out it needed another ground added from block to chassis. And after some work i got it fired up and it moved out under its own power! all fluids , plugs vac lines were changed and some fresh fuel.
File Type: mov
File Type: mov
Old Dec 22, 2019 | 12:13 PM
N8IROCZ's Avatar
Want a title? Post!
big relief getting it to run
Old Dec 22, 2019 | 12:17 PM
N8IROCZ's Avatar
Want a title? Post!
motor is a new gm goodwrench long block 4bolt main 350 needs some beautification though gonna pretty it up once if get it on the road
Old Dec 22, 2019 | 12:36 PM
Carlos89's Avatar
Car: 1986 Trans Am
Engine: 5.0 LG4 4BBL
Transmission: T5 5-Speed
Glad you got it running.Looking forward to updates.
Old Dec 22, 2019 | 08:24 PM
Gibby10's Avatar
Car: 86 Iroc
Engine: 355
Axle/Gears: 3:42
nice! great looking car!
Old Dec 23, 2019 | 09:05 AM
dagwood's Avatar
Top Answer: 1
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
Following!
Cool IROC!
Old Dec 23, 2019 | 09:32 PM
N8IROCZ's Avatar
Want a title? Post!
This dang mess Smh
Old Dec 23, 2019 | 09:36 PM
N8IROCZ's Avatar
Want a title? Post!
Anyone know the purpose of this cable on the left? It was disconnected and I can’t find it in the service manual
Old Dec 24, 2019 | 07:06 AM
Fullmonte77's Avatar
Car: 85 Berlinetta
Axle/Gears: 10 bolt 3.42 with Torsen posi
The one on the left is an aftermarket shifter cable. It probably had another shifter in it at some point and was switched back to stock setup and they didn't remove the cable.
Old Dec 26, 2019 | 06:07 PM
N8IROCZ's Avatar
Want a title? Post!
So...neither of the power windows work and I determined it was the motors , that being said I took the door panel off and of course it was all water damaged and rotted in the front bottom corner . I made a patch outta son Xmas boxes and got some new push pins and she’s good to go
Old Dec 26, 2019 | 06:08 PM
N8IROCZ's Avatar
Want a title? Post!
I did however have some help from petunia
Old Dec 26, 2019 | 08:25 PM
2slow5.0's Avatar
Car: 91 Formula
Engine: 5.0 tpi slow
Transmission: WC t-5
goofy lookin dog
Old Dec 27, 2019 | 03:36 PM
N8IROCZ's Avatar
Want a title? Post!
Hit the junkyard and was able to put together a decent center console and some new switches from eBay
Old Dec 28, 2019 | 03:34 PM
BrianI's Avatar
Looks great!! I like the 88-90 Iroc wheels the best.
Your help has made a real pig of themselves though
Old Dec 28, 2019 | 04:16 PM
N8IROCZ's Avatar
Want a title? Post!
ya she’s a real tool hog too
Old Dec 28, 2019 | 08:28 PM
BrianI's Avatar
lol!!
Old Dec 28, 2019 | 09:00 PM
GeneralDisorder's Avatar
The extra cable on the shifter goes to the ignition switch on the column and is the locking mechanism that keeps you from taking out the key without putting it in park.
GD
Old Dec 29, 2019 | 06:30 AM
N8IROCZ's Avatar
Want a title? Post!
GD
thank you sir
Old Jan 6, 2020 | 09:58 AM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
I have one of these sum bitches to lol
92RS-HeritageEd
Aug 1, 2022 06:36 AM
W.E.G.
Jun 13, 2020 07:06 AM
6speedIROC
Oct 13, 2019 10:53 AM
Bobby Suth
Jan 30, 2011 02:09 PM
