82 Trans Am, work in progress
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
figured I'd start a thread about my car, I bought it two years ago for $1000 with 121,000km.
The car was mostly stock when I bought it.
Car: 1982 Trans am
Engine: 383
Re: 82 Trans Am
Some of the stuff I've added or changed
its got a 305 with a T-10 4 speed trans
ENGINE & TRANS:
- Edelbrock performer EPS intake
- Edelbrock Thunder series 650AVS carb
- Edelbrock steel braided fuel line and filter
- Edelbrock vavle covers
- Moroso air cleaner
- K&N 14x3" filter
- Flowtech headers
- 2 1/2 single exhaust with a flowmaster super 40 muffler.
- Moroso solid motor and trans mounts
- MSD streetfire HEI distributor with a Accel cap/ rotor, Crane mechanical advance kit.
- Taylor 8mm plug wires
- 17" Maradyne Texas Twister fan
CHASSIS & SUSPENSION:
- 10 bolt with 3.23 gears
- S10 Manual steering box
- Edelbrock torque arm
- Edelbrock control arm relocation brackets
- Lakewood rear control arms
- Lakewood 50/50 rear shocks
- Lakewood driveshaft loop
- lowered 1 1/2" in front 1" in rear
- Wonder bar and steering braces from a 86 IROC-Z
- Battery relocated to hatch area in a moroso battery box
OTHER MODS:
- B&M line lock
- Autometer sport comp speedometer
- Autometer tach
- Hastings oil pressure and water temp guages
- Grant steering wheel
ENGINE & TRANS:
- K&N 14x3" filter
- Flowtech headers
OTHER MODS:
- B&M line lock
- Autometer tach
Car: 1982 Trans am
Engine: 383
Re: 82 Trans Am
ya the usually stuff: make it run 11s, Frame connectors, UMI torque arm relocation crossmember, Rebuild the 10 bolt with a new posi and either 3.73 or 4.10 gears, and a set of weld prostars....etc..I've got a pretty big list of future plans.
Car: 1982 Trans am
Engine: 383
Re: 82 Trans Am
it'll be my daily driver(except winter)for as long as I have it. I'd hate to throw money at something that's just gonna sit there collecting dust.
Car: 1982 Trans am
Engine: 383
Re: 82 Trans Am, DD, work in progress
update, the carpet was really moldy and falling apart, I ripped it out ground down the surface rust sanded every thing down hit with some sealer then put down some roll on bed-liner.
Before
After
New carpet and interior back together
Before
After
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Re: 82 Trans Am, work in progress
great job on the floor. should have done that to mine when i had the carpet out. I was lucky thou and no rust.
Car: 1982 Trans am
Engine: 383
I picked these up, should be a big upgrade over the Monroe/Lakewood struts and shocks I have in there now
Car: 1982 Trans am
Engine: 383
I also got this 23mm rear sway bar,
the factory bar looks like its made out of a coat hanger
Car: 1982 Trans am
Engine: 383
Car: 1982 Trans am
Engine: 383
small update, I got the rear shocks and rear sway-bar in, I just reused the stock bushings and endlinks for now.
Its amazing how small the stock rear sway-bar is
Car: 1982 Trans am
Engine: 383
global west del-a-lum control arm bushings
Car: 1982 Trans am
Engine: 383
old monroe struts
front suspension all out
new KYB AGX struts in
Car: 1982 Trans am
Engine: 383
control arm bushings in.
Car: 1982 Trans am
Engine: 383
Car: 1983 Pontiac Trans Am "Daytona"
Engine: LG4 305 V8
Transmission: T5 5-speed
Nice! Looks like your making some good progress. And I agree...steal and a half for a grand! Also, HOLY CRAP that sway bar was absolutely tiny! Probably floss your teeth with it! LoL
Car: 1982 Trans am
Engine: 383
small update, finally had enough of my edelbrock carb, picked up a holley 600 vac secondary.
Car: 1982 Trans am
Engine: 383
this will be a busy weekend my globalwest traclink and frame connectors came in today
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
its coming along well Ryan, all the important stuff being done first
Car: 1982 Trans am
Engine: 383
its slowly coming along, I am gonna try do the sub-frame connectors this weekend, I am starting to run out of suspension pieces to upgrade, gonna have to start on the drivetrain soon.
Car: 82 Trans Am
Engine: 383
Axle/Gears: Built 4th gen 3.42 posi/disc
Car: 82 Trans Am
Engine: 383
By the way, smart move on the carb. I too had
a piece of **** edelbrock carb which NEVER
worked right. Once i bolted a Demon 750 on
it i could feel the horsepower gain.
Car: 1982 Trans am
Engine: 383
Car: 82 Trans Am
Engine: 383
all the linkage/bushings. This linkage stuff SUCKS. I've
had to replace the z-bar twice. NEVER buy a z-bar
'MADE IN CHINA'. The steel was so weak it bent the
first time i pressed the clutch pedal. The shifter and
linkage i replaced with Hurst Competition Plus shifter
and Hurst Competition Plus Pro Linkage Kit.
Do not despair as there is a simple solution imho.
Hydraulic throw out bearing!!!
I'm planning on doing a 5 or 6 speed conversion,
depending on funds. Instead of using a master/slave
cylinder setup, i will be doing a hydraulic throw out
bearing. This way there is not only NO linkage but
not even a fork... LOL
Car: 1982 Trans am
Engine: 383
YEP. I've had to re-enforce that area and i have replaced
do you have any pictures of how you reinforced the frame in that area?
Car: 82 Trans Am
Engine: 383
support bracing around the ball mount on the frame.
Car: 1982 Trans am
Engine: 383
not to much to update, I got the frame connectors in I didn't take any pictures they kinda blend right in.
I got this proform secondary diaphragm, the check ball was missing from the holley one and causing a bogg that didn't respond to spring changes.
Car: 1982 Trans am
Engine: 383
Haven't really done to much to the car lately just driving it and turning my rear tires into powder
http://youtu.be/_px-fckAqns
Car: 1982 Trans am
Engine: 383
small update: I got a good deal on some Eibach sport line springs.
Car: 1982 Trans am
Engine: 383
sportlines are in, haven't driven it yet hopefully they settle a little more its sitting kinda high
lets see a profile pic of the car, maybe a comparison of before and after.
and mine did settle after a week of driving...
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
awesome progress
Car: 1982 Trans am
Engine: 383
After with sportlines and 195/70r14 front and 235/60r14 rear tires
its sits higher with the sportlines but thats ok cause it also rides a lot nicer and I drove over a few speed bumps today with out scraping.
Car: 1982 Trans am
Engine: 383
small update: I picked up a holley 670 street avenger and energy suspension poly urethane sway bar bushings and endlinks
