My Fordiac 521 BBF pontiac formula 350
Old Jan 28, 2013 | 07:36 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Original car was a blue stock 1987 formula 350, been modding it and ended up with a 521 BBF powered firebird with 3 speed C6 trans, ford 8.8 rear with 3.55 gears. Full tubular suspension including front and rear LCAs, panhard bar, tq arm, wonder bar and 2 sets of SFC, 8pt roll bar with swing out kits. 90% aftermarket gauges and a NX express 100-250 NOS kit accompanied by a snow performance Meth/water injection kit. .
INTERIOR
Interior is fully redone (besides pass seat) with 5pt harness, new carpet, carbon fiber wrapped interior peices and engine components. New gauges, full LED lighting, rear seat delete, fabricated aluminum NOS bottle holder, B&M mega shifter. Aluminum door panels
EXTERIOR
Pop up deletes with 55w HID 8K bixenon projectors and 35W HID 3K projector fog lights. Glasstek 4 cowl bolt on hood with aerocatch hood pins, S10 door handles and camaro Z28 spoiler. Front Rims are 17x9 anthracite ford FR500 wrapped in 275/35 rubber with custom billet adapters, rear are 17x10.5 anthracite ford FR500 wrapped in 315/35 rubber. BAER 13" black label front brakes and stock 11.5" ford rear brakes (drilled and slotted) with custom brake lines and a hurst line lock for track days/burnouts. Car has filled in front fenders and rear deckled and has been painted hot rod satin black (not flat).
MOTOR
521 BBF (stroked 460) with 10.8:1 compression
Aluminum edelbrock RPM heads (OTB)
Lunait hyd flat tappet cam (241/249 at .050, .600" lift)
Edelbrock Torquer II single plane intake
1000CFM prosystems carb (billet everything)
NX express Main line kit NOS 100-250hp plate setup
Snow performance meth/water injection kit
full custom 2" headers to 3.5" collectors, full 3" exhaust with Xpipe and turndowns
1.73 Aluminum scorpion roller rockers and moly 3/8" pushrods
Jomar stud gridle all covered by fabbricated moroso valve covers
high flow aluminum water pump
Super large Oil cooler and HV melling oil pump with a filter relocation.
Spun aluminum 2" drop base air cleaner with 4" K&N filter element
TRANS
C6, full overhaul with all maxed out clutch packs (red altos)
Billet servos, transgo shift kit, deep aluminum pan
10" 3000 stall converter with Nitrous anti-ballooning plate
Huge F450 superduty trans cooler (29"x19") with remote trans filter
REAR END
ford 8.8, 3.55 Ford gears, ARP mains studs, Moser support girdle, 28 spline axles, raytech solid pinion spacer
custom 3" Dennys driveshaft (secret material) UNBREAKABLE steel driveshaft with 1350 yokes.
IGNITION
Mallory 685 ignition box, Duraspark Mag distributer customized, MSD cap/rotor, custom 50ohm summit spark plug wires and R&M modified loom. Mallory coil with aluminum heat shroud and custom steel coil mount.
too much to list! car is fully custom and insane! 550hp estimate(way more tq) then 100-250hp for up to 800 with the NOS. Makes full power by 5500rpms so i can enjoy it on the street which is why its so mild. Thinking of head porting and a solid tappet cam for an easy 650-700hp NA.
Attached Thumbnails My Fordiac 521 BBF pontiac formula 350-carbon-fiber-wrapped-engine   My Fordiac 521 BBF pontiac formula 350-interior.jpg   My Fordiac 521 BBF pontiac formula 350-vc-closeup.jpg
Old Jan 28, 2013 | 07:39 PM
Car: 87 TA clone
Re: My Fordiac 521 BBF pontiac formula 350
I will update with more pics when it gets nicer out for the full car shots etc.
Attached Thumbnails My Fordiac 521 BBF pontiac formula 350-nos-bottle-bracket.jpg   My Fordiac 521 BBF pontiac formula 350-baer-brakes.jpg   My Fordiac 521 BBF pontiac formula 350-p1030831altered.jpg
Old Jan 28, 2013 | 07:40 PM
Car: 87 TA clone
bump
Old Jan 28, 2013 | 07:50 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Looks good, I bet that thing is mean!
Old Jan 28, 2013 | 08:03 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
No doubt one of the most unique 'Birds I've seen! The torque that must make!!
-Not to mention HP. Love those valve covers too....Where did you find those? But I'll be the one to ask....Why Ford powered?
Old Jan 28, 2013 | 11:14 PM
Car: 87 TA clone
Rubberducky... yes its pretty beast. With it idling you ***** vibrate if your within 10ft of the car. above like 4000 its scary. it went 12.2 at 115mph with only a 1.8 60' ( i could smoke the brand new MT streets 290/65r15s with anything but babying it off the line) but i was getting valve float by 4500rpms so it felt like it was hitting a rev limiter and i was popping by 4500. So i was short shifting and not going through the traps at more than 3/4 throttle id say.
Yea it turns alot of heads, most ppl think its a pontiac motor at first but its very torquey! The 3000 stall helps cushion it bc it prob makes 500ftlbs before 3000 easily since its peak is about 5500. Its a mild build (mild to BBF race guys) its easy to get in the 800-1000hp range (the stock crank is good for that with its 3" mains!) but I build it for street fun even with the 3-5mpg on premium lol.
The valve covers are fabbricated moroso tall, I then hand polished them and then only wrapped the top with 3M di-noc carbon fiber vinyl. The 521BBF cutout shows the polished aluminum underneath. I only wanted to wrap the top since I didnt like the polished look (valve covers and air cleaner) it was just too much! So to calm it down I used the carbon fiber wrap on the tops so the sides of the valve covers and the breathers are all polished aluminum so it still has a good bit of POP! I didnt want to cover the aluminum welds (its my favorite part about fabricated aluminum) so it helps add alittle pop/bling on the tops of the valve covers. Its hard to see in the pics but the breathers are billet polished aluminum as well with carbon fiber on the top as well.
Car had a brand new 383 HSR that took me 6 yrs to build, and it was stolen before i could even finish tuning it (roughly 3 months after first startup) After than I was going to go big or go home and big blocks always gave me a stiffy. so I went big!!! and got it insured for all the money invested in it since I got nothing from the theft and gut of my 383 HSR/700r4 build. I got the block core and trans for free and basically just used the block and trans case and everything else is aftermarket. Plus doing a timing change on the BBF is stupid easy lol!
thanks for the kind words guys.
Old Jan 28, 2013 | 11:19 PM
Car: 87 TA clone
Nice ride btw! liking it! Im liking the 3rd gen fest (car show) in your domain page more tho lol. where was that?! Very little 3rd gen meet ups like that in norther jerz
Old Jan 28, 2013 | 11:32 PM
Car: 87 TA clone
Some more pics.
Heres a pic of under the valve covers, all that bling!
Rear weight jacks, afco 200lb rear springs, ford 8.8 rear with custom extra long adjustable RLCA brackets for 5 mounting points vs the aftermarkets 2 hole versions. Mine have 5 mounting holes and the holes follow the arc of the RLCAs which means you never need to adjust the length of the LCA when moving holes. ( I change mine for the track and street as I change the ride height with the weight jacks to fit the 290/65r15 MT streets.
rear sumped stock tank with 1/2" NPT fittings, aeromotive pump, -10AN pressure and return line, regulator is aeromotive with -8AN to summit racing -8AN fuel log.
Attached Thumbnails My Fordiac 521 BBF pontiac formula 350-521-no-valve-covers.jpg   My Fordiac 521 BBF pontiac formula 350-sumped-gas-tank_pump_rear.jpg   My Fordiac 521 BBF pontiac formula 350-weight-jacks_rear-under-car.jpg
Old Jan 29, 2013 | 05:32 PM
Confuzed1's Avatar
Car: 83Z28 HO
Thx!
The combination of how you laid on the carbon fiber vlnyl on those valve covers and 521 cutouts really sets those off! The rest of it ain't too shabby either!
The show is in Crete, Illinios every year Memorial Day weekend....bring your gas card and drive on over! Bring a rag too so you can wipe the drool off your fenders...lol There's a thread on the board all about it:
https://www.thirdgen.org/forums/third-gen-fest-12/
Old Jan 22, 2015 | 11:26 AM
maks10's Avatar
Car: 1990 Trans Am
Engine: 5.7 350 HSR afr195 xfi268
Axle/Gears: 3.08 posi
Not sure how I missed this thread but some nice work!!! Like all the unique work and style!!! Sucks someone stole your original setup
Not sure if you mentioned it but what kind of mods were needed to fit a bbf???
Old Jan 22, 2015 | 12:31 PM
Car: 87 TA clone
It wasn't too bad. Custom motor and trans mounts and custom headers. I trimmediately the firewall back alittle on some areas. The hardest part was the cooling system since the rads are opposite on a ford. Once i figured it out its pretty easy. Headers took some time. It fit with thr stock kmember etc. Now it's got a moly kmember, coil overs with integrated STB, newly designed cooling system, 2004r, fast eZ efi 2.0 and TA gfx, getting new paint and quad bixenon projectors.
Cooling system is knotched over to the pass side 3" and down 1.5". Had to create a remote rad cap filling station bc the water neck is 1.5" higher than the rad cap
Old Apr 9, 2015 | 04:46 AM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
Hmmm I've heard stories about this car. My dad brought it up to me he trolls the 460 ford forum.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
okfoz
Convertibles
83
Oct 29, 2018 11:18 PM
okfoz
Mar 9, 2017 02:35 PM
Linson
Aug 31, 2015 04:52 PM
