1985 trans am
Old Apr 27, 2014 | 08:52 PM
blackd-out z28's Avatar
Car: 1985 pontiac firebird t-tops
Engine: 350 with 305 heads
Transmission: t-5
Axle/Gears: 4th gen rearend with 3.23 gears
1985 trans am
picked this up in october but finally got some good pics to post with out snow.
350 with 305 heads and a 450 cam heddman headers with flowmaster exhaust. It has 4th gen suspension seats and center console. And has craiger soft 8 17x9 rims.
Attached Thumbnails 1985 trans am-img_5398.jpg   1985 trans am-img_4020.jpg   1985 trans am-img_6071.jpg
Old Apr 27, 2014 | 08:55 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: 1985 trans am
Congratulations on your new purchase!
Old Apr 27, 2014 | 08:59 PM
Transmission: t-5
Re: 1985 trans am
thank you!!!! i have more pictures in my profile of interior and engine.
Old Apr 27, 2014 | 09:06 PM
JT's Avatar
JT
Community Administrator
Re: 1985 trans am
Check the VIN. If the prefix begins with a 1G2FS then it's a Firebird or Formula (note Formulas didn't appear on ThirdGens until 1987) or if the VIN prefix begins with a 1G2FW then it's a Trans AM or GTA (note GTAs didn't appear until 1987 as well).
From the pictures you posted, it's either a Firebird or if it's a Trans AM it's missing a lot of Trans Am body parts.
Old Apr 27, 2014 | 09:11 PM
Transmission: t-5
Re: 1985 trans am
1G2FW87H6FL615540
Old Apr 27, 2014 | 09:12 PM
Transmission: t-5
Re: 1985 trans am
the car is also missing heat and wipers and a plaque on the dash as well
Old Apr 27, 2014 | 09:13 PM
Transmission: t-5
Re: 1985 trans am
it came with a 305
Old Apr 27, 2014 | 09:16 PM
Transmission: t-5
Re: 1985 trans am
the car is also missing heat and wipers and a plaque on the dash as well it has a small one that says performance suspension and i looks like there was a bigger one above that
Old Apr 27, 2014 | 09:20 PM
Transmission: t-5
Re: 1985 trans am
you can see here in the picture what i am talking about
Old Apr 29, 2014 | 10:06 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: 1985 trans am
You have a FireBird front end and rear FB bumper cover.Theirs nothing TA about your car
Old Apr 29, 2014 | 11:08 PM
lasher_350's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 9 bolt 327
Re: 1985 trans am
Lack of a.) fender vents, b.) ground effects of any kind (note: no holes for lower door effects even) and c.) non-Trans Am hood (4 vents) also leads one to have doubt as to the validity of the Trans Am claim...
But, also, many things could have happened to the car since 1985. "There's many a slip twixt a cup and a lip"
Old Apr 30, 2014 | 01:50 AM
Transmission: t-5
Re: 1985 trans am
so as far as the title matching the vin sticker and door sticker but as said before "the car is also missing heat and wipers and a plaque on the dash as well it has a small one that says performance suspension and i looks like there was a bigger one above that" but yes stuff was changed before because engine bay was painted black. the hood was changed and is original black because there is a rust spot in the middle of it and the fenders and bumper is loosely applied and the car was sprayed primer black and inside the hatch area and the rest of the car is white as it states on the title
Old Apr 30, 2014 | 01:57 AM
Transmission: t-5
Re: 1985 trans am
and the vin was also posted before as for verification
1 g 2 f w 87 h 6 F L 615540
us pontiac gm f-body trans am 2 door coupe 305 lg4 1985 van nuys production number 615540
Old May 4, 2014 | 08:20 PM
Transmission: t-5
Re: 1985 trans am
after alot of digging around i found this vin on the car 1G2FS87H4FN205061 so i apologize for any inconvenience and misunderstandings so its was a lg4 car but not any more. after looking around the only cars that have my bumpers are the formulas and it has 82-84 taillights in it.
Old Jun 11, 2014 | 03:17 PM
Transmission: t-5
Re: 1985 trans am
so rpo code
Old Jun 13, 2014 | 04:49 AM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Re: 1985 trans am
That's a cowl tag. The RPO codes are on a largish-decal, typically inside the console.
Old Jun 13, 2014 | 03:12 PM
Transmission: t-5
Re: 1985 trans am
well the console has been changed so no rpo codes only for a fourth gen
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 31, 2015 04:52 PM
Thornburg
Aug 27, 2015 11:34 PM
Dquickshift
Aug 12, 2015 06:21 PM
drathaar907
Aug 10, 2015 07:44 AM
