Mid-Atlantic Region Regional board for all of the Mid-Atlantic states. Discuss gatherings and get togethers.
Could someone bring tools to the picnic???
Old Sep 17, 2002 | 01:48 PM
MuttandJeff's Avatar
Engine: 5.0 TBI
Transmission: 700R4 Auto
I'm having a couple of problems with my T/A that I need worked out and was wondering if you guys could help me out at the meet this weekend.
1. I installed the open air cleaner on my tbi awhile back and all was running good, but now I have this smoking coming out the passenger side (along the quarter panel side) of the hood. Its not a major smoking, but you can notice it slightly at stops/parking, but not every time. I think I can reproduce it in park and revving for a few minutes.
2. I also have this weird rubber burning smell (I think it is but could be mistaken) all of the time, except when driving, or when you turn on the air conditioning you can smell it for a long while before it is circulated out.
3. Other than that I would like to have my timing checked, and adjusted if necessary but I don't have a timing light and don't know how to use one anyway but I will want to learn. So if anyone who is going this weekend could remember to bring theirs that would be great.
I'll bring my socket set and crescent wrenches with me as well in hopes of an easy fix to this smoking and bad smell problem.
Thanks guys!
Old Sep 17, 2002 | 02:16 PM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Guess I just won't empty out the back of my car from this past weekend.
Old Sep 17, 2002 | 04:11 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
lol
Old Sep 17, 2002 | 04:34 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Sweet, I will bring some tools and stuff too. I will bring my timing light, but it's not very bright anymore?
I'll also bring my fuel pressure gauge and stuff like that, if any one needs it....
Old Sep 17, 2002 | 04:36 PM
Car: 99 Formula
Axle/Gears: 342
hmm , fuel pressure gauge, I might be able to use that, would it show if I'm running lean or not? as in showing my carb is too small?
Old Sep 17, 2002 | 04:41 PM
ES87iroc's Avatar
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Not really (esp for a carb car), but I will also bring my DVM so we can tap your o2 to figure out the above mentioned.
Old Sep 17, 2002 | 04:47 PM
Car: 99 Formula
Axle/Gears: 342
hmm, 02 ehh, well I have something hanging out my driver side header, but it ain't hooked up, is that a prob?
Old Sep 17, 2002 | 06:32 PM
ES87iroc's Avatar
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Nope, do NOT hook that up to anything, and make SURE it is not grounded. If you ground it, it's toast.
Old Sep 17, 2002 | 07:15 PM
Car: 99 Formula
Axle/Gears: 342
I think it's just hangin out down there for now.
Old Sep 17, 2002 | 07:50 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
i know you problem with the Smoke thing
when i did the open Air Element mod to my car i had the same problem
the breather groment on your car is broke or the breather is not push into the hole as far as it should be
the smoke is the oil dripping onto the exhaust manifold and burning off
Old Sep 18, 2002 | 06:52 AM
Engine: 5.0 TBI
Thanks to everyone who has offered to supply tools!
Dennis91Rs, I'll check that since I took the breather and rotated it away from the air cleaner, maybe I pulled it out some.
Thinking about it now, it could also be my multiple oil leaks, mainly the passenger side valve cover leak i have and maybe its dripping onto the exhaust manifold. Since the oil leak is not significant (I'm not losing oil, according to the dipstick) that would explain why sometimes it smokes and sometimes it doesn't.
Old Sep 18, 2002 | 01:19 PM
MDv6man's Avatar
Car: 1983, 1986
Does that require any special software (for a v-6)? I have a smog retest in October and would like to see how far I'm off
Old Sep 18, 2002 | 05:28 PM
poorboy8's Avatar
Car: 79 Camaro RS
Engine: 355, carb, alum heads, XE262
Transmission: TH350
Laptop and scan software for SD cars.
DVM, Fuel Pressure gauge with hose I'm leaving the rest of the tools at home, unless someone wants to do an engine swap or something
Old Sep 18, 2002 | 05:39 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
One off-the-wall question... will the park guys get mad if we start working on the cars? They seem like they've been cool so far... just wondering if "vehicle work in a state park" is against state regulation or something.
Old Sep 18, 2002 | 05:44 PM
Car: 99 Formula
Axle/Gears: 342
I wouldn't think so, unless you start changing fluids like oil or something.
Old Sep 18, 2002 | 06:12 PM
ES87iroc's Avatar
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Good point, I think as long as we do not turn the park into a garage, we should be okay. Just little stuffs like laptop monitoring and stuff I would think would be okie. So long as we are not revving engines and making a commotion or something anyways.
92projectcamaro
Dec 8, 2015 12:25 AM
David Frans
Oct 31, 2015 08:12 PM
Reid Fleming
Oct 10, 2015 09:56 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mfp189
Sep 27, 2015 09:25 AM
