Mid-Atlantic Region Regional board for all of the Mid-Atlantic states. Discuss gatherings and get togethers.
Complete L98 Heads and some other stuff...anyone have a need for them localy?
Old Jul 11, 2006 | 10:31 PM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
I have a sec of complete L98 heads that are on a freshly rebuilt engine with 0 miles on the engine itself.
I will include rockers, springs, valves, etc. Everything to bolt them in except gaskets.
If anyone wants them localy let me know.
I also have a 10 bolt open 2.73 with drum. No problem not behind a powerful car lol.
I will also have a lot more items out of a 91 Z28 soon like sway bars, a-arms, k-member, lcas, panhard bar, 2 sets of t-tops (glass), LT1 Cam etc.
Old Jul 13, 2006 | 10:09 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
Are these the aluminum or iron L98 heads?
Is the engine a 2 or 4 bolt block?
What year is that 10 bolt? 90 and up had the 28 spline axles right?
Old Jul 13, 2006 | 10:12 PM
crrllmich's Avatar
Engine: L03, LS1
Its just the heads no engine... I am just saying they were on an engine that was just rebuilt so not sure of milage.
Yes 28 Spline 10 bolt.
Havn't seen you at the show where you been?
Old Jul 13, 2006 | 10:17 PM
So are the heads aluminum or iron.
I go over to the show almost every Friday. I don't bring the car cause I'm embarrassed about the flaking paint job. Also I've had it down putting in a new master cylinder and I will soon be doing a brake swap.
I saw Mike and Rick last friday.
How much for the rear or just the axles. Drum axles are the same as disc right?
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
KO1
Aug 31, 2015 06:31 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
