Mid-Atlantic Region Regional board for all of the Mid-Atlantic states. Discuss gatherings and get togethers.
Thinking about selling my 91 RS
Old Feb 14, 2008 | 09:59 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
I've about had it!!!
Emissions!!! I hate it. The car is too new to put Historic -OR- Street Rod tags on it (registered in MD).
The engine has a dead miss (cylinder 6 or 8). I have replaced EVERYTHING ignition-wise. I need to run a compression test but Im too lazy to. I dont wanna have to pull the head or anything (again, too lazy).
OK... say I pull the engine and stuff my currently being built 383 in it (no time soon). Im afraid that it wont pass emissions! I started to buy an 88 IROC before I built this car. But, I only paid $600 for it. The IROC was $1500.
Im thinking about buying an early-to-mid 80's G-Body. I dont want a GN and MCSS's cost too fricken much.
Im also hating the following:
- I dont have much room under the hood to play with. Im trying to build a turbo car.
- I cant run a true dual-exhaust system without ground clearance issues.
Dont get me wrong. I love my RS. Maybe I should just keep it STOCK and buy a G body also. Im not sure if I really wanna sell it. I guess Im confused...
Help!!!
Old Feb 15, 2008 | 08:17 AM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
Re: Thinking about selling my 91 RS
How much would you want for it and got any pics?
Old Feb 15, 2008 | 01:57 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Hey man! I know you! I met you before at Crapitol and at Budds Creek. Im the short-bald black guy with the Black GTP...
I have pics on MySpace. I can send you pics as well.
Im not sure if I wanna sell it. I have been thinking about it all day. I have talked to a few friends and they all are saying dont sell it. I need more time...
Old Feb 15, 2008 | 02:44 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Ohhhhh ok how you doing man? Be sure to get to the track this year as my car will be back out. Let me know about the car but personally if you dont have to sell then just hang on to it. Let me know either way and see ya soon.
Old Feb 15, 2008 | 10:02 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Hmmmm...
I thought about it and I think Im gonna keep it. I think Im just frustrated about this whole emissions thing. I might just have to stop being lazy and just fix the damned problem.
3 more years and NO MORE VEIP!
Old Feb 15, 2008 | 11:45 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Well somehow I seem to get an extension every time and this has gone on for a little over a year now.
Old Feb 16, 2008 | 07:30 AM
JAYDUBB's Avatar
Car: 1991 Camaro RS
What are you failing? HC? CO? NOX (sp?)? I failed all 3! This last time, I disconnected the PCV line. I got REALLY close to passing. Close, but no cigar.
I have SOOOO much crap to fix. I gotta get my S10 running. Bought it for $350. Bad fuel pump. Drop the tank to replace it, tank has a leak. Patch the leak, install the pump, start the truck, and I see a puddle of fuel on the ground. Damned thing has a bad fuel line. I seem to have the worst luck!
I guess I will try to get an extension instead of paying $14 a month to keep the tags from being suspended...
Here are some pics...
Attached Thumbnails Thinking about selling my 91 RS-camarors1.jpg   Thinking about selling my 91 RS-camarors2.jpg   Thinking about selling my 91 RS-camarors3.jpg
Old Feb 22, 2008 | 06:00 PM
Legal Disaster's Avatar
Car: 1986 Iroc-Z
I was told by somebody that if you have spent around 300 dollars to try to pass emissions and still fail, that they will waive it as long as you can produce receipts for the parts you have replaced/fixed to try and get it to pass. Actually I've heard this from a few people, so it may be worth looking into. Hope I helped, good luck
Old Feb 23, 2008 | 09:19 AM
Stevo's Avatar
Car: Pair of 92 Z28s
Yes, that is in fact true but in VA i think its closer to $500-600 you have to spend.
Old Feb 23, 2008 | 10:52 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
And when I did the waiver a few years ago, I was subjected to an under-hood inspection, to make sure the EGR/AIR/EVAP/PVC/etc. were all intact.. I believe the receipts have to be from a certified repair shop now also, not just parts receipts like I used... ymmv
mike
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
Firechicken86
Aug 12, 2015 10:07 PM
mcgarnicle
Aug 12, 2015 04:58 PM
