Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
Hey MIlwuakee guys
Old Dec 31, 2002 | 03:00 PM
rsscoty's Avatar
Car: 1991 RS
Engine: 305 TBI
Transmission: auto
Hey MIlwuakee guys
Hey Milwuakee guys,
My brakes rattle really bad. I would like to know if you guys have had this problem and fixed it.
I have put silicone on the back of the pads and they are still rattling. It is driving me insane if anyone can help please contact me. Thanks Scot
Old Dec 31, 2002 | 11:08 PM
Pepsicola's Avatar
Engine: 305 TBI
Transmission: 5 spd
Axle/Gears: 10 bolt w/eaton posi 3.73
The only problems I've had with my brakes is that the previous owner(s) of my car never took the time to replace the brake pads (front and rear). Mine were all eaten apart, I was lucky i could stop at all.. But rattaling I dont know about
Old Jan 3, 2003 | 04:36 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
There's little tabs on your disc brake pads. Sometimes you need to bend them in a little so they'll fit snug on the caliper. When they are loose - It'll rattle.
Old Jan 3, 2003 | 07:09 PM
rsscoty's Avatar
Car: 1991 RS
Engine: 305 TBI
Transmission: auto
thanks
Thanks confused, I have bent the tabs down...come to think of it I've done everything but weld them solid. I'm beginning to think that it is'nt my brakes, however if brakes lightly ridden they don't rattle. still
Old Jan 5, 2003 | 08:34 PM
Confuzed1's Avatar
Car: 83Z28 HO
Is the rattle from the front or rear?? You didn't mention whether you have discs all around or not.
If you apply the brakes lightly and the rattling stops, it would seem to point to the pads or something. Maybe one of the thin sheet metal backing plates are loose??
Good luck!
Old Jan 11, 2003 | 09:30 PM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
When I got my first F-body it had a horrible rattle that i was told were the ball joints. When I went to install the ball joints I noticed the calipers were extremely loose. It seems the previous owner had done brakes but hadn't put the caliper bolt bushings in. Well I fixed that and I was back on the road in twenty minutes instead of a few hours. Hope this helps.
Old Jan 12, 2003 | 09:37 AM
rsscoty's Avatar
Car: 1991 RS
Engine: 305 TBI
Transmission: auto
Turns out it was my caliper bolt bushing. took the tire off and could move the caliper with my hand. Changed it no more rattle woo hoo
Red iroc-z 305
Sep 30, 2015 05:22 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
matthew911
Aug 12, 2015 09:38 AM
mx127
Aug 10, 2015 08:13 AM
