Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
Post Your Mods
Old Jan 22, 2003 | 12:57 AM
maverick351ci's Avatar
Car: 1985 Firebird
Post Your Mods
just wondering what people are running out there here are mine
Old Jan 22, 2003 | 02:51 AM
Kandied91z's Avatar
not enough room in this thread to list all of mine without putting someone to sleep..........nice looking list you got there!
Old Jan 22, 2003 | 04:44 AM
Car: 1985 Firebird
thank you like you said there is so much to list so i just hit the main ones that most people would notice
Old Jan 22, 2003 | 07:20 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
just ths basics 4 last season
Old Jan 22, 2003 | 05:54 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
in sig
Old Jan 22, 2003 | 06:59 PM
pskel350's Avatar
Lets just say its a stock 85 Camaro 2.8MPFI SC
Old Jan 22, 2003 | 09:33 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Most information is on my website (see sig).
Old Jan 23, 2003 | 11:51 PM
BLUETA's Avatar
Car: 86 TRANSAM
Engine: 406
Hers--90 IROC 350 TPI all stock except for K&N filters.
His--86 TransAm, 406, Speed Pro pistons, 9.3 compression, 5.7 rods, World S/R Torquers (76cc, 2.02/1.60), Comp cam (mystery grind), Comp roller tipped rockers, TPI w/SVO 24# injectors, reworked air intake w/K&N filter, SLP 1 3/4 thru hi-flowcat into Dynomax Super Turbo, 700R4 w/shift kit, 3.27 gears and 255/50r16's on rear. BOY IS IT FUN ! !
See several from Iowa. Anyone going to the Drake Relays on April 25-26 ??
Old Jan 23, 2003 | 11:56 PM
Kandied91z's Avatar
his and hers....how cute.:lala:
Old Jan 24, 2003 | 01:19 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i'm pretty much factory.
Old Jan 24, 2003 | 04:19 AM
Car: 1985 Firebird
how much you want for your hooker shortys and does it have the y pipe?
Old Jan 24, 2003 | 01:37 PM
MILT's Avatar
Here's the scoop on my '91 Formula I'm currently building:
-305 w/ Holley Stealth Ram
-Comp Cams 210/220 .500/.510 cam
-March 2-pc pulleys
-SLP 1-5/8" headers
-Gale Banks 3" exhaust
-Off-raod pipe
-52mm TB w/ air foil
-K&N CAI
-Speed density conversion
-MSD 6AL box
-'93 T56 setup
-Aluminum driveshaft
-Hotchkiss rear susp package
-Eibach sportline springs
-3.27 9-bolt posi rear
-Wonderbar
-Herb Adams' F/R sway bars
-LCA relocation brackets
-1LE oil cooler
-Walbro 255L/h pump
Coming this summer:
-S&M 8-pt roll bar
-Corbeau seats
-4pt harnesses
-'98 3.73 disc rear
-Spohn SFCs
-4thgen wheels
-4thgen console
Hmm, I think that's most of it.
MILT
Old Jan 26, 2003 | 12:29 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
I'm basiclly stock but I have--
Removed A.I.R. pump
Ported & polished my plenum (siamesed runer ports)
Polished TB
Air foil
Cut out air boxes
oh and I always have 93 octane running through!!!!!
thats about it
Polished TB--
Old Jan 26, 2003 | 12:32 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
plenum...sorry for the bad quailty pictures. Need a new digital camera
Old Jan 28, 2003 | 05:37 PM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
eh...you know...
Old Jan 29, 2003 | 02:09 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Just barely getting started here... Nothing modded HP-wise on the car yet, but about a grand worth of breathing mods in the mail so far!!!
Old Jan 30, 2003 | 12:17 PM
Zenger's Avatar
400 sbc 4 bolt
9.8:1 Ariax pistons
-8 Brodix Heads 2.055 int. 1.62 ex
.535 int .565 exh.
226 int 230 exh
4L80E tranny shift kit
Ford 9inch 4.11 gear 33spline axles eaton posi
accel dfi
msd 6al
30# injectors
89 Corvette TPI ported polished with accel large tube runners
(For Sale)
Holley Stealth Ram to soon take place of it
disc brakes all around
line lock
stock stall
1 3/4 coated hooker headers
3inch exhaust going thru 2 cats 2 mufflers 2 muffler baffles
26x11.5x16 M/T et Streets
hoping for mid 8's in the 1/8 come March before Intake swap!
312rwhp @5k
380rwtq @4100
Old Feb 2, 2003 | 12:46 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
In the sig..
Old Feb 7, 2003 | 05:18 PM
6sp thirdgen's Avatar
88 RS Carborated 383, Dart heads,100%Roller Motor, 232/238 at .50 with 1:6 rockers,6sp Tranny, 9in. ford with 3:73,and revapted suspension.
Old Feb 7, 2003 | 11:16 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Welcome to the board, 6sp. Sounds like you have a real runnin' setup.
Old Feb 7, 2003 | 11:47 PM
89firechicken's Avatar
so far this is what ive collected edelbrock tes headers, hooker exhaust, electromotive tec-2, edelbrock mpi, oh and a bowtie block with 4.125 bore and 350 mains. eventually it will be a d-stroked 377 with either afr or areo 32 valve heads with a vortech in front. but thats after the elky is done
Old Feb 10, 2003 | 11:10 PM
fakezcar's Avatar
mostly in the sig but details as follows.
TRW cast pistons
"GM" Cam. 239/242 @ .050 .539/.542 lift
1.5 Full roller rockers
stock crank
stock rods
Performer RPM
"stock" Edelbrock 600.
Stock HEI
soon to be a complete MSD setup
All in a 90 RS. No a/c, no emissions currently
Old Feb 18, 2003 | 03:35 PM
IROCZEKE's Avatar
Car: 1990 Iroc
Engine: L98 5.7 350
Hey xpndbl3.....How much was it to remove that ac/heater core? my ac compressor is broken and i wanna remove it by summer. That thing weigh like 40 pounds? Is it easy enough to do it yourself?
Old Feb 18, 2003 | 10:48 PM
12secRS's Avatar
388 1 pc rear main seal, 10.75 comp. SCAT crank Forged TRW pistons, COMP hydraulic roller cam, Pro Topline 220cc heads, Victor JR. Holley 750 DP. Th-350 2800 stall, trans go shift kit, 4.10 gears. 200 shot of nitrous. 3 1/2" exhaust dynomax bullet mufflers, Moroso front springs, Competition engineering shocks 8 point cage.
Future mods 6 al box 3 step rev limiter, 3500 stall, pro fogger system.
Old Feb 19, 2003 | 12:01 AM
xpndbl3's Avatar
Car: 1984 Z28
Yea,
it was easy enough to remove all that stuff. You just have to make a steel firewall piece where the heater/AC stuff used to go. It definately removed some weight, although I just bought a heater only setup which weights 47 pounds including all the ducting and blower motor, so I'm putting that back in because not having a working defroster sucks around here especially since IL has cold nights and windows like to fog. It was cool not having any of that stuff to mess with but now I want it back.
Although I should mention that the non-a/c box like I have takes up a LOT less space than the A/C & heater setup does and I needed that space for stuff.
Old Feb 19, 2003 | 03:24 PM
IROCZEKE's Avatar
Car: 1990 Iroc
Engine: L98 5.7 350
Thanks for letting me know, i'm from chicago myself, maybe it would be smart to leave it in..........
Old Feb 19, 2003 | 03:33 PM
xpndbl3's Avatar
Car: 1984 Z28
Well it definately would be worth swapping from the A/C and heater style box to a non-a/c heater only box. It will allow you to free up a lot of room and weight while still keeping your heat....that would be the best choice..
Steve
PS check out the chicago board on thirdgen for our gathering memorial weekend under big spring party
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Chuck84TA
Jul 15, 2016 09:05 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
haps
Interior Parts Wanted
Sep 8, 2015 10:15 AM
1LE91
Aug 31, 2015 08:13 PM
