Cold air kit for sale
Car: 90 Camaro
Engine: 418 LS3 whipple charged
Transmission: Magnum T56 w/ Street Twin
Axle/Gears: 3.27 9 bolt
I am selling this cold air setup from my camaro since it will no longer fit with my new induction setup. It uses 3 k&n filters and comes with one spare. I am asking $200 obo.
Car: 90 Camaro
For more surface area and it let you pull air from inside of the fender, behind the headlight and from under the car.
Car: 90 Camaro
Installed picture
Car: 90 Camaro
You could use it on a maf car by cutting the straight piece of tubing shorter and mounting the maf right next to the filter box. By the way it is all 3.5 aluminum tubing.
Car: 90 Camaro
I am going to stick to $200 I have over $300 in material and a ton of hours involved in it. If you want to you can give me a call and stop by to see it first hand.
Car: 96 s-10, and 89 camaro RS
Engine: 305 TBI with alot of mods
Transmission: 700R4 B&M shift kit
i fugured that it said OBO but i can make one with a cone filter and run it outside the fender for $150 and keep the battery where it is. Thanks though.
Car: 90 Camaro
I put my battery in the trunk (actually I removed the spare tire and put the battery where the spare was) so there would be more weight over the right rear tire.
sorry, but no thanks. He would also have to buy a $40 battery relocation kit and install a kill switch when the battery is moved to the rear.
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
I know that most of us are hurtin' for cash but come on people at least read the post from the top AND look at the pictures. Most of the people around here(QC) don't have the skills to pull off a fabrication like that for under 200 bucks. If you think you need it buy it. I you have a TBI or less don't WASTE the mans time. You know who you are.
Car: 90 Camaro
If you can build one for $125 you are doing better than me. The 2 elbows are $60 each and the tubing was $30 the 4 filters are $30 each. That is $270 and you still do not have the .125 plate or the .75 plate. I have 12 hours of machine time and my welder has another 4 hours of his time involved in it. This is the reason I was asking $200.
like i said. One that isnt overkill. That is overkill for a 350. I will have him buy a 3 1/2" stainless mandrel bent exhaust tube in JCWhitney for $60 and ill cut off one end to make the other elbow to weld on. And then he will buy the $45 cone K&N filter and we will put it on the end of the intake. All of this will take around 4-5 hours. Not the 20 hour job but not overkill. And ill polish the SOB to make it shine.
Terrell351
Jun 13, 2021 01:13 PM
toronto formula
Nov 10, 2015 06:17 AM
kyle5647
Aug 15, 2015 11:56 PM
db057
Aug 11, 2015 10:11 PM
