Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
speedo/tach issues
Old Sep 6, 2004 | 09:08 PM
jc33's Avatar
Car: 1992 Camaro RS
Transmission: T5- manual five speed
speedo/tach issues
hey just a couple of questions. since i put my new 5 speed and posi 373 in the speedo has been way off. besides cracking the trans open and changing the drive gear is there anything i can do. it reads 110 when im doing 75.
also since i swapped the 350 for the 3.1 my tach has been off, it reads a lot higher rpm than the engine is actually turning what can be done about that.
Old Sep 7, 2004 | 12:17 AM
irocz eric's Avatar
Car: 86 "Ram Air" IROC
Engine: 305 5.Slow
maybe swap over to a v8 cluster?
Old Sep 7, 2004 | 12:29 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Swapping to a V8 cluster will fix the tach, or if you search, you can find a way to modify your stock V6 tach to work with a V8.
The only way to 'fix' your speedo is to get the proper gears and install them.
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
