Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
AC compressor is shaking rapidly!
Old Jan 30, 2007 | 09:42 PM
bobert's Avatar
Car: 1988 pontiac trans am
Transmission: auto
Axle/Gears: ??
when i start my car it starts shaking and makes loud banging sounds!im young and dont know much soo any help would be awesome! i dont want to take it to a shop cause im ona tight budgit!trhanx for any help!
Old Jan 30, 2007 | 10:08 PM
RocVert's Avatar
Car: 67 RS/SS 91 Z/28 vert
what kinda of car do you have ?
Have you tried to remove the belt for the ac ? if it is ran by a dedicated belt remove it, it will stop the ac compressor pully from spinning.
or is it all ran by 1 serpentine belt ?
Old Jan 30, 2007 | 10:14 PM
bobert's Avatar
Transmission: auto
Axle/Gears: ??
i have an 89 trans(305tpi) and it is all by one belt!i check alll bolts and they are tight! i would emagine its the belt but whenyou look at it (when its running) it looks like the whole ac compressor and bracket is loose!
Old Jan 30, 2007 | 10:42 PM
RocVert's Avatar
well couple things
you say it looks like the ac compressor and bracket is loose ?
but you checked all bolts anf tight ?
Does the belt feel tight ?
does the pulley for the ac feel loose when you grab it ? (engine off of course LOL)
I am not sure of a temporary way to bypass the ac without a ac delete pully
and new belt,
IF the ac compressor is bad the shaft will sometimes get real loose and noisy
anyone correct me if I am wrong but to fix, you may need to
a. replace the compressor
b. delete the ac compressor (remove it and probably have to use a "ac delete pulley"
Old Jan 30, 2007 | 10:49 PM
bobert's Avatar
Transmission: auto
Axle/Gears: ??
do you know how much a new ac compressor would cost!
Old Jan 30, 2007 | 11:07 PM
RocVert's Avatar
well napa list several but the cheapest was $174.00
but if it is indeed the commpresor or the clutch on the comp
you could still bypass it,(AC Delte pully) cheaper I think than a new compressor, no AC of course.
Larry
Old Jan 30, 2007 | 11:10 PM
bobert's Avatar
Transmission: auto
Axle/Gears: ??
well when i bought the car the ac wasnt workin in teh first place!i never thought to actually take it all out cause i dont know how!being young and not having much knowledge isnt very fun!
Old Feb 1, 2007 | 07:26 PM
bobert's Avatar
Transmission: auto
Axle/Gears: ??
ok on the ac compressor bracket there is another metal piece connected to it with a coil or spring like thing incased in it! can anyone tell me what this is!
jrdturbo
Mar 31, 2016 02:58 PM
Gunner242
Dec 25, 2015 04:49 PM
meeklay812
Oct 1, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
