key stuck in ignition..
Car: 71 camaro, and also a 91 camaro
Engine: 383 stroker
Transmission: t5
Axle/Gears: 3:73 strange axle
hello everyone, just recently purchased a 91 rs, the seller put the kep in and turned the steering wheel and pulled th key out with no problem.... the car has no motor and there was not power hooked up to the car when the seller showed me this. i hooked up power and put the key in the ignition, and not the key will not come out.... i am trying to put the motor in but there is no use to put in if i can not crank the motor.... so the bottom line is the key is stuck in the ignition can anyone help me please.....
Gunner242
Dec 25, 2015 04:49 PM
Linson
Oct 1, 2015 09:50 PM
