Steering Wheel HELP!!!!!
Car: 1991 Camaro
Axle/Gears: 3:42
I have bought a grant steering wheel for my 92 Camaro and had an old one removed and I am unsure on how to install the new one????? I have the adapter kit that i bought seprate if anyone has a clue or can help me out that would be great!!!! I live in Des Plaines or if someone can explain it to me it looks like i may be needing a screw reight where the hole lines up im not quite sure HELP!!!!!!!!!!
Car: 91 CAMARO Z28,91 GTA
Engine: 305 TPI modified, 350 tpi
Transmission: 700R4 modified
Axle/Gears: 2.73 (yuck), 3.23 posi
Re: Steering Wheel HELP!!!!!
what are you having problems with?
Car: trans am ws6
Engine: something special :)
Axle/Gears: 4.10 posi
the thing can be confusing. i put a grant wheel on my car this summer. which part do you need help with?
Car: 1991 Camaro
Axle/Gears: 3:42
i have everything off i need to put the wheel on and the hole to line it up is there a bolt that goes thur there or what cause im sooooo lost either i got the wrong adapter kit or its missing a bolt or what not im unsure???
Car: trans am ws6
um there is a whole it i believe is if you have a air bag. all i did was put the washers on and the black adapter and put the 3 bolts in the wheel to the adapter , then with the nut on it. hope that might help??
Car: 89 and 91 Camaro RS
Engine: 350ci TPI and 305ci TBI
Axle/Gears: 2.73 One-wheel wonder
can you post pics of what you have including the column and maybe give us some part numbers?
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
