Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
Question For Wisconsin
Old Jan 27, 2009 | 05:25 PM
adriancamaro's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
Ok, so i have a 92 camaro RS, would it be legal for me to take my front license plate off?
Thanks,
adriancamaro
Old Jan 27, 2009 | 05:35 PM
rhit_rs's Avatar
Re: Question For Wisconsin
Seeing as how you have one now, I'll assume Wisconsin requires one. That being said, it would not be legal for you to remove it. On the other hand, some people choose to remove theirs and haven't had any problem with the local authorities, but some police officers will pull you over for it or say something about it if you are pulled over for some other reason. So, legal? - no, can you get away with it? Possibly.
My car is licensed in IL so I am supposed to run a front plate, but since I'm in Indiana 80% of the year, I've never actually put it on because IN does not have front plates. I realize that doesn't make it legal, but it does make it easier to get away with.
Hopefully this helps
Old Jan 28, 2009 | 12:15 PM
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
That makes sense, but i was told if the model of car doesn't come with a front license plate mount then its legal to only have one. I have a Z28 grill in my car and it has a front license plate mount, but if the 92 RS didn't come with a mount from the factory then i should be fine without one right?
Old Jan 28, 2009 | 12:26 PM
rhit_rs's Avatar
I can testify that is not the case in Illinois. My mother drives a M-B SLK that originally did not come with a place to mount the front license plate bracket. A cop pulled her over and threatened to give a ticket if she did not put one on it. She had to buy an aftermarket bracket that mounts it out in front of the front bumper. The dealer would also have installed it, however they were going to cut through the front bumper to mount it. The same scenario happened to my father as well. He drives an Austin-Healey kit car on which the front bumper does not have a specific place to mount a license plate. He was pulled over one time driving his C4 (also with no front license plate) and was told to put a license plate on the vette and his other car!
I also have a Z28 grill in my car. I've seen grill inserts that were for mounting a license plate that I believe were factory. I think it depends on which state the car was sold in.
Old Jan 28, 2009 | 01:41 PM
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
I see cars all over the place here with no front license plate mount. My dad's truck doesn't have one and there is no plpace for it. He bought it in wisconsin too. Also from what I've heard, it depends on the cop, too. Wait, I just looked at your profile, your from Illinois and Indiana, and I'm from Wisconsin....hmmmm, just a thought.
Can someone from Wisconsin verify this, Thanks
Old Jan 28, 2009 | 07:31 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Bottom line - Front plates are required. You may be ticketed for not having one. Will you get away with not running one? - roll the dice.
Old Jan 28, 2009 | 08:56 PM
jrz28's Avatar
Car: 1984 Berlinetta
Engine: 305 Carb
It says on the pack that your plates come in, if the state Of Wisconsin gives you two plates, then your car should have two plates.
Old Jan 28, 2009 | 09:44 PM
iggy89's Avatar
Car: 86 Camaro
Engine: 79 350 carbed
Transmission: TH-350
Axle/Gears: 3.73 posi
I have passed cops before with no problem but who knows. I think they will usually use it as an excuse to pull you over for something else.
Old Jan 29, 2009 | 09:32 AM
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
Ok, well, I'm gonna pull it and see what happens.
Thanks guys
Old Jan 30, 2009 | 10:45 AM
84firebird383's Avatar
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
My father got a ticket a few years ago for no front plate. I don't know the exact amount of the fine,but it was over $100.
Old Jan 30, 2009 | 01:00 PM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
I got pulled over a few years back and was given a warning. I'm not sure if it is a primary offense or not but generally they give you a warning and if its not taken care of by such a date they mail you a ticket
Old Feb 3, 2009 | 11:28 AM
ndamron's Avatar
Car: 82 Trans-Am / 83 Trans-Am
Engine: Major Mod SBC / Minor Mod SBC
Transmission: Major Overhaul 700R4 / Stock 700R4
Axle/Gears: None!!! / 3.73 posi disc...soon
You must display a fron plate in wisconsin even if the car doesnt originally come with a front bracket. I have been pulled over for this, typically you will only get pulled over by a WI state Trooper. But consider that it gives a law enforcement agent a reason to pull you over where if you have the front plate they will have to find something else to pull you over for......this is useful info if you drive around near bar closing time.
Nick
Old Feb 3, 2009 | 12:34 PM
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
seeing as im only 18 i don't have a problem with bar closing times. and when i drive im careful and obey all laws, so even if they pulled me over for no plate they have nothing else to ticket me for. I don't think it will be a problem, my dad has been driving his truck for 7 years without a front plate and has had no problems. So i should be fine
Old Feb 3, 2009 | 02:01 PM
iggy89's Avatar
Car: 86 Camaro
I usually don't drive my car at all at night. Way to many deer around to even bother with that. If they would pull me over for anything they would use the exhaust as an excuse way before the front plate.
Old Feb 5, 2009 | 09:04 PM
RPOZ28's Avatar
Car: 1985 Z28
Wisconsin for sure does require two plates.I put new front sheet metal on my Z,and really didn't want to drill up my virginal bumper cover for front plates.Well,two years go by with seasonal driving.One afternoon I passed a squad car in the oncoming lane.He spun around in the middle of the street and stopped me...for guess what??Moral to the story,on the right day with the right officer......you'll get 'er..........BILL
Old Feb 7, 2009 | 05:31 PM
notmuch's Avatar
Car: 69 Chevelle SS Lookin' for 92 Z ver
Engine: 468
Transmission: th350
For the most part I never had a front plate on that car Adrian, and I can say for certain, driving up to Door County, they will not let you go by without it. They will probably recognize the car without the front plate. I just carried the plate under the front seat, and when pulled over ask if I can put it on,I would toss it on for the day and that night take it back off, no tickets ever.
So how is the car doing? Running strong yet? Any problems? I hope not.
Jeff
Old Feb 10, 2009 | 04:25 PM
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
Hey Jeff, i had a problem with the fuel pump relay, it fried itself, so i pulled one off a suburban and popped her in. runnin strong now, just need new tires, oh and the muffler rusted off, so i have to do somethin with that too, but nothin serious. I love the car, thanks man.
Old Feb 10, 2009 | 11:19 PM
notmuch's Avatar
Engine: 468
Transmission: th350
I might still have another exhaust for that car in my storage unit. I can check and see. if I do, its yours if you want it.
Jeff
Old Feb 12, 2009 | 03:14 PM
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
sweet, sounds good. oh and i had a low beam light go out, so i replaced them with sylvana silver stars, love em. but ya, that would be awesome if you have the exhaust, you wouldn't happen to have a grey headliner for it too would you?
Oh and funny story with the front plate. I was at work (bp gas station), and a cop pulls up next to the camaro, i was watching him while he walked all around it looking at it. He came inside and asked "who's camaro," i said it was mine, and he goes, "nice lookin ride." he never said anything about the front plate, and he had to have noticed it, so for now im good.
Old Feb 12, 2009 | 09:26 PM
bm87ta's Avatar
Car: 87 TA
Engine: 305 tpi
Transmission: auto
been driving my car for 8 summers with no front plate and haven't gotten pulled over yet. But you are suppose to have one. How about some pics of your car?
Old Feb 13, 2009 | 06:24 PM
notmuch's Avatar
Engine: 468
Transmission: th350
I might be able to go check out my storage unit tomorrow, i will check on the exhaust for you. I know I don't have a headliner for you though, I would have put that in myself if i had it.
I am glad to hear you are enjoying the car, I still miss it. That was by far my favorite third gen of many many I have owned.
Last fall there was another RS just like yours for sale not to far from me, except it was ratty. My daughter (remember it was her car) started crying when she saw it, she so badly wanted me to go buy it for her.
Jeff
Old Feb 16, 2009 | 08:30 AM
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
ya i might get a parts car pretty soon, $250. Its amazing the car has some rust on the hood, and all it needs is a tranny to get it running, and he only wants $250 for it, but hey im not complaining.
Ya if you have the exhaust, how much do you want for it? And did you find your 92 Z vert yet?
Old Feb 17, 2009 | 11:54 PM
turbojohn's Avatar
Car: 86 Trans AM
Axle/Gears: ???
Thanks,
adriancamaro
In Wisconsin?? NO!
Old Feb 18, 2009 | 12:53 AM
jkris53406's Avatar
Apparently you didn't see our useless governor's speech tonight. To cut costs, we will just have to make due with the DMV issuing only one plate. I woder when that will take effect.
Old Feb 18, 2009 | 12:56 PM
heavychevy's Avatar
where in de pere are you?
Old Feb 19, 2009 | 05:17 PM
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
off of the Scheuring road exit, in West De Pere.
Old Feb 19, 2009 | 05:43 PM
HankL69's Avatar
Car: 85 IROC / 69 Firebird convertible
Engine: 5.0 / 350
Transmission: t-5 / WC t-5
Axle/Gears: 3.27 / 3.08
Hey DePere, I'm in Bellevue. Haven't had a front plate on either one of my collector cars for15 years but I did get stopped 20 some years ago with my first Camaro ('70 RS Z/28 ) by a state trooper who said the main reason he stopped me was because I had no front plate. I told him that when the body work was done the mounting holes were filled and I no longer had the bracket to mount the plate. He gave me a warning. A couple months later a county cop stopped me and I gave him the same story. No luck, $65 ticket!!!
Old Feb 19, 2009 | 06:16 PM
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
Ya so far no problems, like i said i had the cop look all over the car, also i have no exhaust, and haven't got pulled over yet, so i should be good for a while, at least until i run into the one cop having a bad day...... oh well, when the time comes, ill try makin up a story and see what happens.
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
