Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
My $50 Firebird
Old Jun 16, 2010 | 05:20 AM
masonmills's Avatar
Car: 1985 Trans Am
Engine: 305 Carb
Axle/Gears: Borg Warner 3.27
My $50 Firebird
T-top blew out while driving, brother didn't latch it in.... last time ANYONE ever drives my car.
Bondo on the ground effects .... idk
Passenger side T-top
Back-window is perfect, but the defrost and brake light don't work? bulb is good?
Yes i know, its not the 91 front end, neither is either fender
Driver side door sags... door hinge is bad.
It doesn't stay up, you have to hold it up for a min and then if the car moves even a little... it falls down.
Light works some times.
Carpet sucks, but all the plastic is new.
Old Jun 16, 2010 | 05:23 AM
masonmills's Avatar
Car: 1985 Trans Am
Engine: 305 Carb
Re: My $50 Firebird
dumb *** decal
leaks
ONLY CRACK IN THE DASH CAP
after i tiwsted these.... my dash lights came on? more infor later on this.
Old Jun 16, 2010 | 05:25 AM
masonmills's Avatar
Car: 1985 Trans Am
Engine: 305 Carb
Re: My $50 Firebird
no headliner
theres the computer
Old Jun 16, 2010 | 05:27 AM
masonmills's Avatar
Car: 1985 Trans Am
Engine: 305 Carb
Re: My $50 Firebird
even though im going to black seats and stuff.... thats the only tear in any seat.
close up of t-top
bad trunk motor & latch
Old Jun 16, 2010 | 05:28 AM
masonmills's Avatar
Car: 1985 Trans Am
Engine: 305 Carb
Re: My $50 Firebird
There she is guys, the one i keep posting problems about..... ill reserve a post for all the problems and ****. and ill update that when i get off work.
Old Jun 16, 2010 | 05:29 AM
masonmills's Avatar
Car: 1985 Trans Am
Engine: 305 Carb
Re: My $50 Firebird
Blinker Wiring Harness & Front Parking Lights - WIRING IS JACKED UP
Interior Screws & Clips
Seats
Story of the dash lights.....
didnt work when i bought the car.... i founf a greyish wire.. tiwsted it with a brownish wire... DASH LIGHTS CAME ON. well my left blinker doesnt blink when i have dash lights on... (Left blinker stays on when dash lights r on) well.... i connected dash to fuse box... then they never went off..... so i connected it to another one, and whenever it would blink the dashlights would blink?? idk basically
HAVE TO FIX BLINKER AND DASH PROBLEM.... my solution, new wiring harness and blinkers.
Broken T-Tops..
UPDATE!!!!!!!!!!!!!! Just toally went to the junkyard at 2:00am -.- and got t-tops..... dont ask... muwahahah **** him he wanted liek $80.
MASSIVE OIL LEAK.
very slow now that i worked on it, but it leaks for sure.
car dies in a idle cause the oil pressure.... ?
Needs ogiginal hood
Needs original front bumper
Needs a vent
my power windows are screwed... need switches and motors.
Carpet
Headliner
Shifter plate - my needle thing that tells me what gear im in is broke.
My e-brake cable is broke.
BRAKES
when i bought the car i drove it homw with no brakes... car has all new brake lines but it had no brakes? well i put new bleeders on the front... bleed them, now they work good, still have to buy bleeders for back and bleed them.
finish repairing the wheel well. (rusted)
i think thats it for now.
OH fyi, it isnt just the dash and blinkers EVERYTHING THAT IS ELECTRICAL ABOUT THIS CAR IS A WIRING NIGHTMARE.
Old Jun 16, 2010 | 08:28 AM
DIRTY JERZY's Avatar
Car: 89 formula 350 & 2001 ws6 ta
Engine: 350 tpi & ls1
Transmission: 700r4, t56
Axle/Gears: 9 bolt ? & 10 bolt 3:42
Re: My $50 Firebird
You got that car for 50 bucks? If so nice score you can part it out and make back your money 20 times over.
Old Jun 16, 2010 | 08:35 AM
campin1983's Avatar
Car: 1984 Camaro 'Vert
Re: My $50 Firebird
Heck of a car for 50 bucks! Is the mileage really that low?
Also, I've got a complete, functional pull down motor if your wanting to fix that issues. PM me if interested.
Old Jun 16, 2010 | 07:05 PM
masonmills's Avatar
Car: 1985 Trans Am
Engine: 305 Carb
Re: My $50 Firebird
i would love to have the motor... but im liek broke as a joke, and when i get payed in a week all it goes to rent. and it doesnt just leak around that seal.... if i had pics under the car.... it leaks EVERYWERE, idk if its called the oil pump... but everytime i idle at a stop light i die... so i have to nutruel rev it at lights.
ill type out a full run down of the car.
Old Jun 16, 2010 | 07:08 PM
campin1983's Avatar
Re: My $50 Firebird
I totally understand. My only money for my vert comes from selling all my old firebird parts. If you get the money and are still interested, let me know. I might still have it.
Old Jun 17, 2010 | 02:19 AM
masonmills's Avatar
Car: 1985 Trans Am
Engine: 305 Carb
Re: My $50 Firebird
Seats
Broken T-Tops..
MASSIVE OIL LEAK.
Needs ogiginal hood
Needs a vent
Carpet
Headliner
BRAKES
Old Jun 18, 2010 | 10:33 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Re: My $50 Firebird
If you've got bad oil pressure you may not need an oil pump. The oil pans on these cars are ridiculously low and are prone to dent exactly where the oil pick up is. Basically look under your car and see if you see a big dent in the rear of the oil pan. To fix it you'll still have to take out the oil pan, so you might as well replace the pump (they where only $30 when i replaced mine).
I'd also fix that rust on your firewall asap and figure out where the water leak is coming from. If that section is rusted out that usually means water is getting down to your floor pans which is NOT kool.
Good luck man, hell of a car for $50.
Old Jun 19, 2010 | 06:30 AM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Re: My $50 Firebird
Lucky bastard! In IL too?
This is similar condition my Camaro was in when it came into the family, and look at it now.
Old Jun 19, 2010 | 11:18 AM
masonmills's Avatar
Car: 1985 Trans Am
Engine: 305 Carb
Re: My $50 Firebird
i need a oil pump, and weatherstripping BAD lol
Old Jul 1, 2010 | 09:44 PM
IROC#1's Avatar
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
Re: My $50 Firebird
Originally Posted by masonmills
Broken T-Tops..
So you went to the junkyard at 2am and STOLE the T-Tops! Thats bullshit! If you cant afford to own a car then dont! Your pathetic.
Old Jul 1, 2010 | 09:49 PM
Carlos773's Avatar
Re: My $50 Firebird
T-tops are expensive even in yards, they want $29.99 for each but still, no need to steal them. Granted I do pocket small things like sensors or emblems from bigger yards but jesus no need to be that cheap . What do they leave the yard open when they close? Most here will require you to do a good climb over a fence to get in. Still does not mean alot of people don't do it, I always see people throwing things over fences and when leaving picking it up and driving off. Sometimes its over the smallest things that arent even worth $20
Old Jul 1, 2010 | 11:00 PM
Stephen's Avatar
Car: 87 GTA
Re: My $50 Firebird
Buck up & pay for what you need & cut expenses on wants. Don't steal to support your needs. Of course, the t-tops look like they were just a want anyways. Scratched doesn't mean that something HAS to be replaced.
Old Jul 2, 2010 | 09:26 AM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Re: My $50 Firebird
i dont know how expensive the yards near you are but hell around here the t tops are 100 a pop. hell for a BARE SPINDLE THEY TOLD ME 125. THATS WITH ME PULLING IT. DO YOU REALIZE that most of these crooks pay 50 for the cars then make 20x that in parts. then they scrap the rest for even more. my old friend worked for an insurance company selling the " totaled cars" with nothing more then a scratch on them. they sold these cars to the yards for anything between 15 and 75 dollars!!!
Old Jul 2, 2010 | 11:16 AM
masonmills's Avatar
Car: 1985 Trans Am
Engine: 305 Carb
Re: My $50 Firebird
**** them, my **** was way more then scratched payday was 6 days away and i needed them. as for the car. lmoa
blew the rear main.
but
as for the updates on the car
got the power window motor in driver door changed need to find passanger side
All black interior
got the right mounting bracket for my cd player
put a cb in the car
going to put on my cragers
etc etc car is lookin sharp.
oh and i got the back hatch motor now to.... yay it suxs it down
Old Jul 2, 2010 | 12:24 PM
Carlos773's Avatar
Re: My $50 Firebird
100 each? Very hard to belive if so, then why even consider them since most here would sell for that much shipped for the pair.
I have 8 yards I always go to and I have their number, price sheet for each. All range from 5 miles from me to 55 miles. On average T-top price is $30 with highest being $40. Spindles are $14.99 or $24.99 w/ Hub here and thats not the cheapest on my list. As for what they pay for yards, the small yards I visit alot are the ones who pay less and last time I was there, they were giving $150+. My uncle himself got $300 for his beat up 94 Sentra from PicknPull (Picknpull.com). As for profits, Thats how yards work, most of the small yards here are just self turned in junkers while bigger better known cars are all from insurance junk cars. Word of advice, get along with some of my people, fellow Mexican yards are 3x cheaper than bigger yards. Just look around.
Old Jul 10, 2010 | 11:13 PM
donmeca007's Avatar
Car: 1985 Z/28
Engine: Dual carbed 357
Transmission: 5 speed
Re: My $50 Firebird
part the car out and then use the money to buy another one with out or just a few probs!!!!!!!!!
Old Jul 12, 2010 | 09:07 PM
masonmills's Avatar
Car: 1985 Trans Am
Engine: 305 Carb
Re: My $50 Firebird
ive been thinking alot about this.
Old Jul 13, 2010 | 12:13 AM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
Re: My $50 Firebird
that's the easy (and fateful) way out. if you've got the money and time, go for a challenge and experience that this car will provide.
Old Aug 3, 2010 | 08:37 PM
02SLPTransAm's Avatar
Car: 1991 Firebird & 2002 Trans Am WS.6
Engine: 305 TBI & 5.7 350 LS1
Transmission: A4 & M6
Re: My $50 Firebird
Very good pick-up for the money. I am restoring a 1991 as well, good luck.
Old Aug 3, 2010 | 09:52 PM
Camaro-454's Avatar
Re: My $50 Firebird
You paid $50.00 bucks for that car?????.............what'd you do? make him an offer he couldn't refuse? Michael Corleoni style? lol
J/K. heck of a deal. and it was running too? you stole that one but good for you. ( I was referring to the car, not thwe T tops as that's not my business ).
But on that note, ( without judging you or anybody else ), ill gotten gain doesn't do anybody any good, point in fact. but anyways, take your time, save your money, tighten your belt, make deals, and get things done one step at a time. it's not a race and you want the end product to be right when it's done. believe me, I'm on a shoe string budget too, so I know what it's like when money is tight, but it'll come. just say a little Prayer, and Believe and see what comes your way.
besty of luck to you with it. great car for the price. it shopuld really be nice when you're finished with it.
Camaro-454
64goatman
Sep 9, 2015 01:09 PM
jtwoods4
Sep 3, 2015 05:39 PM
Formula_88AE
Sep 3, 2015 01:47 PM
jtwoods4
Sep 3, 2015 10:19 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
