Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
newbie from ohio
Old Jul 14, 2010 | 08:03 PM
tkcaraudio's Avatar
Car: 65 Nova Wagon
Engine: 358
Transmission: 350 turbo
Axle/Gears: 410
newbie from ohio
My name is Tim I am 24 from Chillicothe Ohio I am a 3rd gen fanatic LOL
I have always found a thing for 3rd gen camaros I currently own 3
85 berlinetta(roller might have to sale city hates it lol)
87 Iroc Clone 355 5speed
91 RS Convertable 302 5 speed(yes i said 302
Here are my current toys
87 Camaro Plain Jain
started Life as a V6 Automatic Car
Car Currently Lives as a Iroc/Z28 Clone
350(Early 90s motor)
bored 30 over
flat top pistons with 4 valve reliefs
H Beam Rods
10/10 Crank
510 lift cam(but dont have radical idle)
194 valves
double valve springs
double roller timing chain
600 Holley
New Belts
New Hoses
New Water pump
New OEM Aluminum Radiator(Not one in pics jegs sent me a junk one)
Billet Crank/Alt/Water Pump Pulleys
Jegs Hi Torque mini starter
Braided Fuel Hose from Fuel Press Regulator to carb
Fuel Pressure Regulator mounted on fender
HEI Distributor
Accell 8.8 MM spark Plug Wires
Accell Spark Plugs
Hedman Shorty headers
Hedman Y pipe
Heat Wrapped to keep tempature under hood down
3" stainless steel pipe custom bent to rear of car
Flowmaster Dual outlet 40 Series Flowmaster
Chrome Tips on Rear Of Car
5 Speed Transmission
Zoom Clutch
Hurst Shifter
Hurst T handle with line lock button on it
Jegs Line Lock(Roll Controll)
Custom Made Drive Shaft
7.5" 10 bolt out of 2001 Camaro Super Sport
373 Gears
Posi Unit
Converted to 4 wheel disc brakes
2001 Camaro 16" Aluminum Wheels(As of now I am thinking of putting 16" Anniversery wheels back on due to I dont like the 01 wheels on it)
Jegster Adjustable Pan Hard Bar on Rear End
Chrome Rear End Cover
Aftermarket(unsure of name) Torque Arm(Runs from Trans to rear end to help plant power to ground with wieght transfer
Ebach Lowering Springs
Adjustable Edlebrock Shocks on Rear
New Monroe Struts on front
New Dash Pad
New Door Panels
New head liner
Bucket Seats out of 2001 Cavilier(Look good and match interior)
New Console
New Arm Rest Lid
145 MPH Iroc Z28 Speed O
Rear seat is factory and mint
ALl Plastics are mint
Windows/Sun Roof dont leak
Stock Hood Cut out with APC Cowl Scoop Molded Onto it
rear hatch soon as you turn key it pops up by its self and stays
All Factory Gauges work and are pretty close to acurate
This car Hooks hard on street and runs strong in 1/4
i had it to the track 3 times
Run 1 13.00 at 112 mph
Run 2 12.46 at 116 mph
Run 3 11.99 at 122 mph (on 125 shot) but spun bad
I couldnt decied what color I wanted to paint it
and I ordered a gallon of dark gray primer from napa and painted the front clip and when I went to order the rest they gave me light gray so I made a stripe and made it look different I get tons of complements on it people love it...
Old Jul 14, 2010 | 08:32 PM
tkcaraudio's Avatar
Car: 65 Nova Wagon
Engine: 358
Axle/Gears: 410
Re: newbie from ohio
91 Camaro Convertable RS
started life as 305 5 speed
The car was a under cover police car for columbus ohio police department(Used as detective car and is not a salvage title because detective that drove it bought it when they was going to sale off then I bought from him)
this car is a major project
283 from 1963 Corvette bored 30 over and stroked to a 302(Same internals as a 69 DZ302)
Hedman Shorty headers(Might get long tubes before its in)
Dynomax 4" bullet mufflers
Weiand Single 4 Tunnel Ram intake
MR Gasket street scoop
750 Holley Double Pumper Carb
NOS Sniper Nos Kit
Holley Chrome Mechanical Fuel Pump
Holley Elect pump for nitrous system
Barry Grant Billet Fuel Pressure Regulator
Mallory Unilite Pro billet distributor
MSD Blaster 2 Coil
MSD 2 Step Modual
MSD 6AL Box
Moroso 8.8mm plug wires
AC Delco R45TS spark plugs
Jegs 510/533 lift cam and lifters
Comp Cams Roller Tip Rockers
Cash Heads
Screw In Studs
Double Springs
Push Rod Guide Plates
Comp Push Rods
Aluminum Fly Wheel
Performance Products Fuid Dampner
Jegs Race Gasket Set
Billet Pulleys
Billet Plug Looms
Billet Dist hold down
Billet timing chain cover
Billet Thermo housing
billet power stering brackets
Centerforce Stage 3 clutch kit
tremec 5 speed trans(not borgwarner t5)
7.5" 10 bolt rear end
456 gears
Richmond posi unit
Jegs alum radiator
Be Cool Adjustable fan relay
Braided hoses(Radiator/Vacume/Heater/Fuel/Throttle cable)
Non AC heater box
New GM Top
New GM Dash Pad
Autometer A pilliar gauge pod
Autometer Phantom gauges
Autometer 5" Tach with shift light
B&M shirt throw billet shifter
Billet Alum gauge bezel for cluster
H4 Conversion head light kit
Clear marker lights
Optima Red Top battery
Jegs On/Off switch
Battery relocated to rear tire holder
Billet Over Flow can
Lots moer to come I have well over 10k in this build LOL
few pix
before we pulled old motor out
Old Jul 14, 2010 | 08:37 PM
tkcaraudio's Avatar
Car: 65 Nova Wagon
Engine: 358
Axle/Gears: 410
85 Berlinetta Hard top
No Motor or Transmission
10 bolt rear end
posi(un sure of gears)
Stock Flat hood now
NO heater box
Dash Pad busted
Seats torn
head liner junk
all glass good
all interior is there
Floors/frame looks to be good
Little rust in rear 1/4 on driver side
I paid $600 for the car as a project
I want to tube chassis a 3rd gen
has clear title
the car also has
85 MPH Speedo on driver side of gauge and a metric speedo on passenger side of gauge
Old Sep 7, 2010 | 10:57 PM
fatmansbro's Avatar
hey man im from westerville. you ever go to any car meets
Old Sep 9, 2010 | 09:32 AM
tkcaraudio's Avatar
Car: 65 Nova Wagon
Engine: 358
Axle/Gears: 410
i try to. I only have the 87 left
I traded the 91 vert Rolling for a Tube Chassis S10
I crushed the 84 because no on would give 400 for it
The 87 I got a couple offers on it
so Im not sure lol
Get at me 614 364 9995
Old Sep 12, 2010 | 11:02 AM
SMKNTRS's Avatar
Why does it seem Ohio people are posting in "Mid West Region"?
Old Oct 3, 2010 | 08:06 PM
williemcfly's Avatar
Car: 1992 Camaro RS
Engine: 3.1L
because ohio is in the mid-west...
Old Dec 14, 2010 | 11:09 PM
fatmansbro's Avatar
that sucks you crushed the 85 i always see your stuff on craigslist but im always broke due 87 firebird with a 350 and a 5spd that i paid 400 for. i do love your vert ive love to have one
Old Dec 14, 2010 | 11:14 PM
fatmansbro's Avatar
here is a before and after pic of my car
Old Dec 14, 2010 | 11:15 PM
fatmansbro's Avatar
PestilenceIV
Sep 11, 2016 12:53 AM
rubblerubble
Mar 13, 2016 06:57 PM
fasteddi
Exterior Parts for Sale
Sep 29, 2015 04:30 PM
buffaloman
Firebirds Wanted
Sep 7, 2015 09:47 AM
buffaloman
Camaros Wanted
Sep 7, 2015 09:46 AM
