Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
Blue Print Engine
Old Jul 11, 2023 | 05:18 PM
2irocs's Avatar
Car: 1989 Iroc Camaro
Engine: 383 Stroker-Carb Blue Print Engine
Transmission: automatic
Blue Print Engine
Has anyone installed a Blue Print Engine. Any comments on their engines. This is what I am dealing with purchased engine has maybe two hundred miles on it. Rear main seal leaking heads are leaking oil and anti freeze, has ticking noise they are sending me new rocker arms for the ticking sound, rear main seal ,head gasket and oil pan gasket. the leaks from the heads are bottom of head small leaks near header flange.
Old Jul 11, 2023 | 05:22 PM
2irocs's Avatar
Re: Blue Print Engine
This is a roller cam engine does not require a break in period. Start your engine bring to 2000 rpm get it running smoothly. While engine is running check oil pressure, coolant temp and fluid leaks. Thanks for any input or comments...2irocs
Old Jul 14, 2023 | 04:58 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
I have never tried one, nor do I know anyone who has. My impression was that they were of above average quality (Vs a reman.) because they used new parts/castings (not from U.S.), but that's just based on what I've read.
You might want to try posting this in the https://www.thirdgen.org/forums/tech-general-engine/ section of the forum. More folks will see it.
2irocs
Mid-Atlantic Region
44
Aug 13, 2023 11:52 AM
hihighost
Jan 3, 2013 07:34 PM
89Camaro89MI
Apr 5, 2009 09:08 PM
Squeeks83
Jan 21, 2003 10:01 PM
DTL504
Sep 8, 2002 04:48 PM
