FS: JL Audio e2150 amp $35 shipped
Old May 30, 2007 | 02:41 PM
Spiers's Avatar
I have this used JL Audio e2150 amplifier. It needs repair. When hooked up and turned on, only the red security light lights up but no sound. I do not know what is wrong with it, could be something simple or not... I don't know how to work on amps. Retails at around $150 new. Here are spec's...
Class: AB
Channels: 2
Min Frequency Response: 10 Hz
Max Frequency Response: 25 KHz
Bridgeable: YES
Protection Circuitry: Short Circuit, DC Offset
Protection LED: With Protection LED
Power LED: With Power LED
Power supply topology: MOSFET, Regulated
Input Voltage: 12 volts
Variable Gain Control: With Variable Gain Control
Signal to Noise Ratio: 104 db
Features
Bass Boost: With Bass Boost
Fuse Rating: 1x20 AMPS
Wire gauge: 8
Output Power
Preamp Outputs: 1 Pair
Bridged Power: 150 x 1
Power at 2 Ohms: 110 x 2
RMS Power Output: 45 x 2
Minimum Impedance Bridged: 4 Ohms
Minimum Impedance Unbridged: 2 Ohms
Crossover
Built-in Crossover: With Built-in Crossover
High-Pass Crossover Min Frequency: 50 Hz
High-Pass Crossover Max Frequency: 200 Hz
Low-Pass Crossover Min Frequency: 50 Hz
Low-Pass Crossover Max Frequency: 200 Hz
High-Pass Slope (dB/octave): 12 db
Low-Pass Slope (dB/octave): 12 db
Dimensions
Height: 2.36 in
Depth: 9.8 in
Width: 9.25 in
So if you or someone you know works on amps, maybe you can fix it. It's just sitting around collecting dust for me.
How's $35 Shipped
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
