Ohio?
Old Dec 10, 2007 | 06:13 PM
ROADBLOCK's Avatar
Car: 1985 Camaro Z28
Engine: 350ci SBC
Transmission: THM-700R4
Axle/Gears: Stock
Ohio?
i think im in the right section...
anyways, im Mike and I drive a 1985 Camaro Z28. here's the list:
350ci SBC bored to 355ci
Engine Machining Done By Precision Engine & O'Flaherty Racing Engines
Mid 500's COMP Cam
JE 12:1 Pistons
Eagle Rods
SCAT 350ci Steel Crank
Dart 2.02 Heads
Holley Dual Plane Intake Manifold
Edelbrock 850cfm Carburetor
Moser 12 Bolt Rear, 3.73's & POSI
Built THM-700R4 by Hockenson's Transmission Shop
Cold Plugs & 200 Wet Shot of Nitrous
Getting caged this winter as well. all this work was done since September 2007 when I put it away for the winter.
last year i went 14.39's on stock motor & Built Trans. & 3.23 Gears
We'll see what 2008 brings
Old Dec 10, 2007 | 06:58 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: Ohio?
Welcome! and I've been here awhile and have yet to figure out where Ohio fits.
Old Dec 10, 2007 | 07:24 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Re: Ohio?
welcome .
check out this post. its OHIO also
https://www.thirdgen.org/forums/nort...0209-ohio.html
BTW where in Ohio are you? Im in 44438 zip
Old Dec 10, 2007 | 09:02 PM
ROADBLOCK's Avatar
Engine: 350ci SBC
Axle/Gears: Stock
Re: Ohio?
45840 here
Old Jan 25, 2008 | 06:05 PM
hellraiser6's Avatar
Car: 82 Camaro
Engine: 3 350's
Transmission: 3 t350
Re: Ohio?
I am also in Ohio, 43119/43228 area
Old Jan 27, 2008 | 03:44 PM
CashMunson's Avatar
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
Re: Ohio?
roadblock, you're turning that car into a track only ride? how come?
Old Jan 27, 2008 | 03:49 PM
ROADBLOCK's Avatar
Engine: 350ci SBC
Axle/Gears: Stock
Re: Ohio?
where'd you hear that? im building it into a street/strip car. i sold the built z28 my cousin and i had, this is going to be my daily until April, when i get my LS1 car and tear this thing apart again so i can either do a big block swap or an LS1 carb swap.
Old Jan 27, 2008 | 06:17 PM
CashMunson's Avatar
Engine: 408 LS
Re: Ohio?
a car running 12:1 compression isn't going to be a very good street car, you'd have to run race gas only...
PestilenceIV
Sep 11, 2016 12:53 AM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
fasteddi
Exterior Parts for Sale
Sep 29, 2015 04:30 PM
buffaloman
Firebirds Wanted
Sep 7, 2015 09:47 AM
buffaloman
Camaros Wanted
Sep 7, 2015 09:46 AM
