Loooking for long islander to fix car. TOP PAY!!
Old Jan 11, 2008 | 01:44 PM
killacamaro's Avatar
Car: 88 IROC-z
Engine: LO3 V8 305
Transmission: T5 W/ Stage 2 Clutch
hey guys i got an 88 iroc-z here is the problem:
a friend of myne had a camaro that has been sitting for 3 years. before it ran perfect, until 1 day the fuel pump relay went, and melted the wires, and also the
coolant fan relay did the same. im not sure why it did this or what happend. i replaced both relays and wires. did the western union splicing and then solderd them
together. i had syphoned the gas out the tank, put in techtron and 2 gallons of new gas, new fuel filter
the car starts when i put in sum starter fluid, once it burns off it dies, if i dont put in starter fluid it takes like 10 secs to turn over and then dies.
i really dont know what to do. i changed oil, and filter. what can be the problem? i have a V8 305 TBI
Old Jan 11, 2008 | 04:13 PM
TurbomanKnight's Avatar
Car: 1983 Recaro T/A
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
Re: Loooking for long islander to fix car. TOP PAY!!
Pull one of the injector plugs and put a test light with a wire into the plug and see if theres any power.
Old Jan 11, 2008 | 04:34 PM
Car: 88 IROC-z
Engine: LO3 V8 305
can i use a DVM? and what colors are wat? like where do i stick the test light into?
Old Jan 11, 2008 | 04:41 PM
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
Yes, you can also use a DVM. But a test light is better assuming you're checking this by yourself. (You can see the light from inside the car. I dont remember colors off hand, but if you pull one of the plugs off and connect a test light to each side you can see if theres power going to it. Injectors pulse, so the light would flicker real fast if there is power going to it.
Old Jan 11, 2008 | 05:05 PM
Car: 88 IROC-z
Engine: LO3 V8 305
when car is on it gets 25 volts and when trying to start it goes down to 13
Old Jan 11, 2008 | 05:27 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
take the cap of the fuel rail and see if there is pressure in there or fuel at all inthere...can you hear the pump prime when you turn the key on?
Old Jan 11, 2008 | 05:28 PM
Car: 88 IROC-z
Engine: LO3 V8 305
i can hear the pump turn on and prime yes, goit a new relay and wired it correctly this time. where is the fuel rail located? this is a TBI V8 305
Old Jan 11, 2008 | 08:42 PM
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
Is there any fuel being sprayed out of the injectors? Check your Ignition Module under the distributor cap. Theres a pickup coil there that sends a signal to the ECM to control injector pulse.
HOw does the plug get 25 volts? Can anyone clarify that?
There is no fuel rail on a TBI.
Last edited by TurbomanKnight; Jan 11, 2008 at 08:43 PM. Reason: Automerged Doublepost
Old Jan 11, 2008 | 09:07 PM
Car: 88 IROC-z
Engine: LO3 V8 305
mb i read the DVM WRONG, lol but i know its getting voltage. and the injectors are not spraying its more like a dribble. i have to check the Ignition module tomm. what am i lookn for when i do look?
DOES ANY1 WANT TO HELP ME IN PERSON?
Old Jan 27, 2008 | 10:33 PM
dannydoo's Avatar
WHere in lond island are you?
I know whats wrong.I had the same exact problem.
The fix was pretty time consuming,but I could do it.
Let me know.
Old Jan 28, 2008 | 09:14 AM
Car: 88 IROC-z
Engine: LO3 V8 305
car is fixed really, fuel pump was bad. but now my fuel gauge and temp gauge dont work..
Old Jan 28, 2008 | 06:10 PM
Charged350's Avatar
Car: 87 IROC Z28
who fixed it, they messed up sumthing with the sending unit....and temp gague...that beats the **** outta me
Old Jan 28, 2008 | 06:19 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
yep take it back and have them fix it for nothing, they screwed up a wire somewhere.
Old Jan 28, 2008 | 06:39 PM
Car: 88 IROC-z
Engine: LO3 V8 305
the gas gauge worked b4 i syphoned all the gas out of it. and now its pinned above the F.
i replaced the fuel pump. sending unit looked fine. i didnt touch anything or any wires.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
Amillionoh7
Aug 7, 2015 01:24 PM
