1990 firebird formula 500 obo. MUST GO FAST
Car: 87 formula
Engine: 5.7 350 tpi
Axle/Gears: Borg-warner 9 bolt 3.27 posi
1990 fireird for sale in westfield ma 01085 ill take what i can get all of the parts are ther. 5.7 ltr 350, posi rear end good tread t-tops mint black interior . new ignition system, new starter. new exhaust from the cat back for parts or repair.YOU PICK IT UP
call for questions 413-455-8186 matt
Car: 1989 Firebird Formula 350 TPI
Engine: 5.7 350 TPI
Re: 1990 firebird formula 500 obo. MUST GO FAST
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
dude, i told you i would take the car. but not for nothing a 90 formy with the factory 350 is a pretty desirable car. if theres nothing major wrong with it. why not just take it to a shop and have it diagnosed? especially if u just think its the injectors. if the bodys in fair shape and it has not too high of mileage its at least a $4000 car. and nobody in youre area wants a 350 formula for $500 bucks? youre either kinda stupid or theres something else up with the car???????
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
where are you located?! whats the underside look like and is the block seized?
wow...helps if i read it...lol, i see it's in mass...whats up with the motor?
Car: 87 formula
Engine: 5.7 350 tpi
hey guys here is the deal. The engine is not ceased. It fires but won't run. There is some kind fuel issue there. There may be a little rust in underside but not much and only surface rust. And as for you 8t9. You want the car come pick it up other wise no one cared about your opinion. I did the floor when I changed the interior. I'm moving soon and I'm in a bind for another car. So 500 obo. I'm not trying to rip ne one off here I could part it out for more then 500 and it has more then 500 in new parts in it
Car: 1989 T/A
so like i said why not fix it so it drives?
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
PM sent
Car: 87 formula
Engine: 5.7 350 tpi
Car: 1989 T/A
chill out guy, im not trying to offend you. but youre lack of info isnt really going to help with youre sale.
Car: 87 formula
Engine: 5.7 350 tpi
This car also has power door locks windows and mirrors as well as the hatch release on the dash.
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Sounds like a pretty sweet deal. So, the problem is the car won't start?
No rot?
No rot?
Engine: LT1; None
Even if the car is sold, do you have anything else worth buying? Jacks, jack stands, tools, shop equipment, etc.? I can't believe a deal like this came up so close to where I live, but now is not the best time for me to be buying cars. (I.E.- no money) Any feedback or info would be greatly appreciated.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
Dialed_In
Aug 20, 2015 01:45 PM
