the low down
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
the low down
I just thought I would let every one know what has to been done to my car cause I always post saying I need to fix it so here are some details. first off the car runs pretty good I lose a bit of traction on the 1-2 shift and its not the adverage chirp but I do get a chirp in the 2-3 shift some times.
The List:
clean K&N's
adjust t/v cable(needs to be changed)
change fuel injectors
change plug wires
oil change
trans flush/filter
fix exhaust leak
grease u-joints
change gear oil
as you can see most of the things that need to be done is routine maintenance and all can be done in a weekend (excluding eaxhaust work and changing the t/v cable). I just been lazy or may be a case if "out of seat out of mind" because at one point I didn't drive the car for about three months
The List:
clean K&N's
change plug wires
oil change
trans flush/filter
fix exhaust leak
grease u-joints
change gear oil
Car: 87 Z28
So what, least you are getting it done... I need a rear end or I am gonna be off the road for a while... S'ok, I been pimpin my honda. I just threw a set of these babies on, mad tyte.
Sept my aren't chrome heh.
need to fix camaro.... ugh
Engine: 383/LGX
how much are you looking to spend on a rear end and what kind are you looking for
Engine: 383/LGX
tell travis to give you his I don't think 10 bolts are worth that much anyway
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: the low down
What? I don't remember having a ten bolt? was this from my wrecked RS?
What did you end up doing Timmah?
