Northern California Discussion board for Northern and Central California.
19lb injectors
Old 09-06-2004, 04:54 PM
Zac's92's Avatar
19lb injectors
Anyone have any stock 305 injectors? do you think the l98 22lbers or some 24lbers would bee too big? I know it won't need em but Im tring to work with what I have, though I'm afraid it would try and put them below their minimum pulsewidth and run rich at idle.
thanks
Zac
Old 09-07-2004, 02:00 AM
vexter's Avatar
Car: '88 Iroc
Axle/Gears: 3.45
Zac,
I believe you can use the larger injectors but you need to tune for it. Otherwise, you're correct about running rich. I don't have any 19 lb'ers but you see guys trading up all the time. If I were you, I'd post a wtb in the classified section.
--Aaron
Old 09-21-2004, 03:02 AM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
Find a set? I think I have some 19lbs..., but they will need to be cleaned.
Jason
Old 09-21-2004, 05:30 PM
Zac's92's Avatar
got em
thanks
92-Formula
12-12-2015 10:34 PM
rubyred88
09-17-2015 02:19 PM
thejimsterz28
09-15-2015 04:37 PM
BAMiller
09-14-2015 06:38 PM
webeeZ28
09-14-2015 12:00 PM
Quick Reply: 19lb injectors
