Selling Vortec Heads/ ZZ4 Cam, Performer RPM Air Gap
Selling Vortec Heads/ZZ4 Cam/RPM Air Gap/Nitrous Kit/Crane Gold RR/TES Headers
I havent had too much luck in the classified section of this site so im trying it in the West Coast Forums. Mostly because Id much rather have a local buyer than ship it anywhere.
From Scoggin Diggy, a set of Vortec Heads with upgraded z28 springs good to .570 lift. ZZ4 Cam (.474intake/.510exaust lift) 208/221 duration. Last But not least a Performer RPM Air Gap intake manifold for vortec heads. Selling total package for 700obo.
Also have a set of 1.6 crane gold roller rockers, narrow body self aligning type. Sell for 200obo
Dont delete me thread NATE
Located in the Bay Area, CA.
oh almost forgot
I have for sale, for a carbed car, a NOS Power Shot Nitrous Kit (Wet Type). Rated at 125 horses to the wheel(s).
Comes With
-15lb NOS Bottle (Full, 10lb Capacity) w/ Bottle Bracket
-Nitrous Plate, Will Fit Square or Spread Bore Type Intake Manifolds/Carburetors
-NOS Power Shot Fuel Solenoid
-Pressure Tested Braided Nitrous Line
-NOS Shifter **** W/ Button
Also have the Nitrous Solenoid which I will throw in if you want however it is shorted out and either needs a rebuild or a new noid all together, your choice on what you want to do.
Asking $250obo
Edelbrock TES Headers 1 5/8" Primaries, 2 1/2" Collectors with Y pipe dual 2 1/2" Inlets and Single 3" Outlet for single cat now also for sale.
Headers had AIR tubes but were cut off and welded closed (clean job).
200obo
Comes With
Asking $250obo
200obo
Only trade interested in is for a 00-03 GSX-R (motorcycle fellas ) frame/plastics/subframe/forks. Thanks yawll.
Will now also trade for a Forged 400 Crank must be 1 piece rear main seal and internally balanced.
Car: 87 Z28
200obo
200obo
Will trade for 00-03 gsxr 750 forks/frame and/or a small block chevy 400 forged crank with a 1 piece rear main seal and internally balanced. Depending on what there will be +/- money given/taken.
Well guys I just figured out why my motor hydrolocked the other nite. Got my heads off today and the #5 intake valve dropped. My piston is shattered and there is a huge hole in the cylinder wall. That bottom end had under 500 miles on it ) Anywayz the passenger side cylinder head is still fine and dandy except it looks like there is one weak spring on it because the valve isnt seating anymore. The driver side head is just as good except in cylinder #5 the combustion chamber is scard and there is a little dent with a crack in it that got threw to the water passage way in the head about half the size of a dime. Should be a very cheap/easy fix, however it does change things. If anybody were to buy these heads I would change all the valve springs just to be safe. New Price $350 for Intake/heads. Cam I cant even pull out right now. Will sell later if there is no damage to it.
$350 FOR Both Heads and Intake Manifold. My loss is your gain. Will try to get pics soon.
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
hey can u send me pics. do u have instructions too what about guages.
92firebirdchris
Exterior Parts for Sale
08-14-2015 11:56 AM
Firechicken86
08-12-2015 10:07 PM
